[SCM] PostGIS branch master updated. 3.6.0beta1-46-g785b53cd7
git at osgeo.org
git at osgeo.org
Sun Aug 17 23:10:35 PDT 2025
the project "PostGIS".
via 785b53cd7d2526f972ce12d1b305d0db968da951 (commit)
via 984724955929c49c8ff832d54a267f4880d48e58 (commit)
via 556eb64538bc5bd3ae1fb39f02fadd5ad9b11379 (commit)
via c3b29709e612bcdb9a2cf74172a569d30d763f7a (commit)
from 136e4f62cb0d4e3400ac2a97b903bdf1ecc5f075 (commit)
revisions in full, below.
commit 785b53cd7d2526f972ce12d1b305d0db968da951
Author: Regina Obe <lr at pcorp.us>
Date: Mon Aug 18 02:09:18 2025 -0400
PREP for 3.6.0rc1 release
- Clean up NEWS
- Update release_notes
- Update date and GEOS 3.14 dependences on README
- Update pot
- Update version numbers
diff --git a/NEWS b/NEWS
index 0346015d6..4f946b0ba 100644
--- a/NEWS
+++ b/NEWS
@@ -1,7 +1,7 @@
-PostGIS 3.6.0beta1
-2025/07/20
+PostGIS 3.6.0rc1
+2025/08/18
-This version requires PostgreSQL 12-18beta2, GEOS 3.8 or higher, and Proj 6.1+.
+This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
To take advantage of all features, GEOS 3.14+ is needed.
To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.
@@ -50,7 +50,7 @@ Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
- #5841, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)
- Add ST_CoverageClean to edge match and gap remove polygonal
coverages (Paul Ramsey) from GEOS 3.14 (Martin Davis)
- - Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)
- #3110, GT-242 [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)
- - #5963, add ST_IntersectionFractions (Paul Ramsey)
+ - [raster] Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)
+ - #5963, [raster] add ST_IntersectionFractions - Requires GEOS 3.14 (Paul Ramsey)
diff --git a/README.postgis b/README.postgis
index 7643c270d..51a1dff89 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.6.0beta1
-:Date: 2025-07-19
+:Version: 3.6.0rc1
+:Date: 2025-08-18
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
@@ -65,7 +65,7 @@ For apt-based systems you can run this command to install the below dependencies
https://proj.org
* GEOS (Required, Version 3.8 or higher)
- - 3.14+ for ST_CoverageClean
+ - 3.14+ for ST_CoverageClean, raster ST_IntersectionFractions
- 3.12+ for ST_CoverageSimplify and ST_CoverageInvalidEdges
- 3.11+ for improved ST_ConcaveHull, ST_lineMerge,
and new functions ST_SimplifyPolygonHull, ST_TriangulatePolygon
diff --git a/Version.config b/Version.config
index cf6d63e9f..bce44cdfe 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=6
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0rc1
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 94054b27a..d3b3227ca 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -23795,143 +23795,6 @@ msgid ""
"linkend=\"postgis_gdal_enabled_drivers\"/>"
msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"<refpurpose>Generates a set of vector contours from the provided raster "
-"band, using the <link xlink:href=\"https://gdal.org/api/gdal_alg.html?"
-"highlight=contour#_CPPv421GDALContourGenerateEx15GDALRasterBandHPv12CSLConstList16GDALProgressFuncPv\">GDAL "
-"contouring algorithm</link>.</refpurpose>"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<para>Generates a set of vector contours from the provided raster band, "
-"using the <link xlink:href=\"https://gdal.org/api/gdal_alg.html?"
-"contouring algorithm</link>.</para>"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"When the <varname>fixed_levels</varname> parameter is a non-empty array, the "
-"<varname>level_interval</varname> and <varname>level_base</varname> "
-"parameters are ignored."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Input parameters are:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "The raster to generate the contour of"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "The band to generate the contour of"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "The elevation interval between contours generated"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The \"base\" relative to which contour intervals are applied, this is "
-"normally zero, but could be different. To generate 10m contours at 5, 15, "
-"25, ... the LEVEL_BASE would be 5."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If <literal>true</literal>, contour polygons will be created, rather than "
-"polygon lines."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Return values are a set of records with the following attributes:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "The geometry of the contour line."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "A unique identifier given to the contour line by GDAL."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The raster value the line represents. For an elevation DEM input, this would "
-"be the elevation of the output contour."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Interpolates a gridded surface based on an input set of 3-d points, using "
-"the X- and Y-values to position the points on the grid and the Z-value of "
-"the points as the surface elevation."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"the points as the surface elevation. There are five interpolation algorithms "
-"available: inverse distance, inverse distance nearest-neighbor, moving "
-"average, nearest neighbor, and linear interpolation. See the <link xlink:"
-"href=\"https://gdal.org/programs/gdal_grid.html#interpolation-"
-"algorithms\">gdal_grid documentation</link> for more details on the "
-"algorithms and their parameters. For more information on how interpolations "
-"are calculated, see the <link xlink:href=\"https://gdal.org/tutorials/"
-"gdal_grid_tut.html\">GDAL grid tutorial</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The points to drive the interpolation. Any geometry with Z-values is "
-"acceptable, all points in the input will be used."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"A string defining the algorithm and algorithm options, in the format used by "
-"<link xlink:href=\"https://gdal.org/programs/gdal_grid.html#interpolation-"
-"algorithms\">gdal_grid</link>. For example, for an inverse-distance "
-"interpolation with a smoothing of 2, you would use \"invdist:smoothing=2.0\""
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"A raster template to drive the geometry of the output raster. The width, "
-"height, pixel size, spatial extent and pixel type will be read from this "
-"template."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"By default the first band in the template raster is used to drive the output "
-"raster, but that can be adjusted with this parameter."
-msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Change the SRID of all rasters in the user-specified column and table."
@@ -29339,6 +29202,143 @@ msgid ""
"linkend=\"RT_ST_Aspect\"/>"
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Interpolates a gridded surface based on an input set of 3-d points, using "
+"the X- and Y-values to position the points on the grid and the Z-value of "
+"the points as the surface elevation."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"the points as the surface elevation. There are five interpolation algorithms "
+"available: inverse distance, inverse distance nearest-neighbor, moving "
+"average, nearest neighbor, and linear interpolation. See the <link xlink:"
+"href=\"https://gdal.org/programs/gdal_grid.html#interpolation-"
+"algorithms\">gdal_grid documentation</link> for more details on the "
+"algorithms and their parameters. For more information on how interpolations "
+"are calculated, see the <link xlink:href=\"https://gdal.org/tutorials/"
+"gdal_grid_tut.html\">GDAL grid tutorial</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Input parameters are:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The points to drive the interpolation. Any geometry with Z-values is "
+"acceptable, all points in the input will be used."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A string defining the algorithm and algorithm options, in the format used by "
+"<link xlink:href=\"https://gdal.org/programs/gdal_grid.html#interpolation-"
+"algorithms\">gdal_grid</link>. For example, for an inverse-distance "
+"interpolation with a smoothing of 2, you would use \"invdist:smoothing=2.0\""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A raster template to drive the geometry of the output raster. The width, "
+"height, pixel size, spatial extent and pixel type will be read from this "
+"template."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"By default the first band in the template raster is used to drive the output "
+"raster, but that can be adjusted with this parameter."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"<refpurpose>Generates a set of vector contours from the provided raster "
+"band, using the <link xlink:href=\"https://gdal.org/api/gdal_alg.html?"
+"highlight=contour#_CPPv421GDALContourGenerateEx15GDALRasterBandHPv12CSLConstList16GDALProgressFuncPv\">GDAL "
+"contouring algorithm</link>.</refpurpose>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<para>Generates a set of vector contours from the provided raster band, "
+"using the <link xlink:href=\"https://gdal.org/api/gdal_alg.html?"
+"contouring algorithm</link>.</para>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"When the <varname>fixed_levels</varname> parameter is a non-empty array, the "
+"<varname>level_interval</varname> and <varname>level_base</varname> "
+"parameters are ignored."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The raster to generate the contour of"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The band to generate the contour of"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The elevation interval between contours generated"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The \"base\" relative to which contour intervals are applied, this is "
+"normally zero, but could be different. To generate 10m contours at 5, 15, "
+"25, ... the LEVEL_BASE would be 5."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If <literal>true</literal>, contour polygons will be created, rather than "
+"polygon lines."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Return values are a set of records with the following attributes:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The geometry of the contour line."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "A unique identifier given to the contour line by GDAL."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The raster value the line represents. For an elevation DEM input, this would "
+"be the elevation of the output contour."
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Raster Processing: Raster to Geometry"
@@ -29548,6 +29548,31 @@ msgid ""
"to always return multipolygon."
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Calculates the fraction of each raster cell that is covered by a given "
+"geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"geometry. The first argument is a raster, which defines the grid geometry to "
+"use for the calculation. The extent and cell size are read from the raster "
+"parameter. The second argument is a geometry, which is overlaid with the "
+"grid, and each grid populated based on overlaying the geometry on the grid. "
+"For polygons, the value returned for each cell is the proportion of its area "
+"that is covered by the geometry. For linestrings, the value returned for "
+"each cell is the length contained in the cell."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.6.0 Requires GEOS 3.14 or higher."
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Raster Operators"
@@ -35161,18 +35186,18 @@ msgstr ""
#. Tag: title
#, no-c-format
-msgid "PostGIS 3.6.0beta1"
+msgid "PostGIS 3.6.0rc1"
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/07/19"
+msgid "2025/08/18"
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"This version requires PostgreSQL 12-18beta2, GEOS 3.8 or higher, and Proj "
+"This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj "
"6.1+. To take advantage of all features, GEOS 3.14+ is needed. To take "
"advantage of all SFCGAL features, SFCGAL 2.2+ is needed."
msgstr ""
@@ -35244,11 +35269,30 @@ msgid ""
"Census Bureau)"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5359\">#5359</"
+"link>, <link xlink:href=\"https://trac.osgeo.org/postgis/"
+"ticket/5897\">#5897</link>, <link xlink:href=\"https://git.osgeo.org/gitea/"
+"postgis/postgis/pulls/260\">GT-260</link> [tiger_geocoder] Use @extschema:"
+"extension@ for PG >= 16 to schema qualify dependent extensions, switch to "
+"use typmod for tiger tables (Regina Obe)"
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Removed / Deprecate signatures"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5498\">#5498</link> "
+"Drop st_approxquantile(raster, double precision), wasn't usable as it "
+"triggered is not unique error when used (Regina Obe)"
+msgstr ""
#. Tag: title
#, no-c-format
msgid "New Features"
@@ -35347,7 +35391,17 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)"
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3110\">#3110</"
+"link>, <link xlink:href=\"https://git.osgeo.org/gitea/postgis/postgis/"
+"pulls/242\">GT-242</link> [topology] Support for bigint (Ayo Adesugba, U.S. "
+"Census Bureau)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"[raster] Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)"
msgstr ""
#. Tag: title
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 5e03e9723..cb43b7d44 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -3,9 +3,9 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<section>
- <title>PostGIS 3.6.0beta1</title>
- <para>2025/07/19</para>
- <para>This version requires PostgreSQL 12-18beta2, GEOS 3.8 or higher, and Proj 6.1+.
+ <title>PostGIS 3.6.0rc1</title>
+ <para>2025/08/18</para>
+ <para>This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.</para>
@@ -23,10 +23,14 @@
<para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/252">GT-252</link>, ST_NumGeometries/ST_GeometryN treat TIN and PolyhedralSurface as unitary geometries,
use ST_NumPatches/ST_PatchN for patch access (Loïc Bartoletti)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3110">#3110</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/242">GT-242</link>, [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5359">#5359</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5897">#5897</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/260">GT-260</link>
+ [tiger_geocoder] Use @extschema:extension@ for PG >= 16 to schema qualify dependent extensions, switch to use typmod for tiger tables (Regina Obe)</para>
</simplesect>
<simplesect><title>Removed / Deprecate signatures</title>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5498">#5498</link> Drop st_approxquantile(raster, double precision), wasn't usable as it triggered
+ is not unique error when used (Regina Obe)</para>
</simplesect>
<simplesect><title>New Features</title>
@@ -46,7 +50,8 @@
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5841">#5841</link>, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)</para>
<para>Add ST_CoverageClean to edge match and gap remove polygonal
coverages (Paul Ramsey) from GEOS 3.14 (Martin Davis)</para>
- <para>Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3110">#3110</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/242">GT-242</link> [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)</para>
+ <para>[raster] Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)</para>
</simplesect>
</section>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index e2734a44b..ca1f5d227 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -113,4 +113,5 @@ UPGRADEABLE_VERSIONS = \
3.5.2 \
3.5.3 \
3.6.0alpha1 \
- 3.6.0beta1
+ 3.6.0beta1 \
+ 3.6.0dev
commit 984724955929c49c8ff832d54a267f4880d48e58
Date: Mon Aug 18 01:12:49 2025 -0400
Flip berrie 32-bit to 3.12.4, see if that is any better
diff --git a/ci/berrie/configs.sh b/ci/berrie/configs.sh
index 5119fcccc..fae39a0af 100644
--- a/ci/berrie/configs.sh
+++ b/ci/berrie/configs.sh
@@ -1,5 +1,5 @@
export WORKSPACE=/home/jenkins/workspace
-export GEOS_VER=3.11.6
+export GEOS_VER=3.12.4
export OS_BUILD=32
export PG_VER=15
commit 556eb64538bc5bd3ae1fb39f02fadd5ad9b11379
Date: Mon Aug 18 00:05:12 2025 -0400
Change developer doc to markdown and rename to .md
This is for easier viewing on the repo
Also add more content about library guarding and terminology
diff --git a/doc/developer.md b/doc/developer.md
new file mode 100644
index 000000000..98f934a89
--- /dev/null
+++ b/doc/developer.md
@@ -0,0 +1,233 @@
+TITLE: PostGIS Developer How-To
+AUTHOR: Name: Regina Obe
+DATE: 2025-08-12
+CATEGORY: Development Docs
+Terminology
+* PostGIS versions are 3 digits separated by a period
+ Major.Minor.Patch
+ - 3.0.0 is a major version
+ - 3.6.0 is a minor version
+ - 3.5.3 is a patch version
+* SQL Api functions are functions that are exposed to the user in the database.
+ They are either SQL, plpgsql, or C backed functions.
+* C Api functions are library functions that back SQL Api functions.
+Naming of library files
+Since PostGIS 3.0 library files are major versioned. Prior to 3 they were minor versioned.
+This means you'll find in the wild the following - the extension .so will be different based on OS
+ - postgis-2.4.so, postgis_topology-2.4.so, rtpostgis-2.4.so
+ - postgis-2.5.so, postgis_topology-2.5.so, rtpostgis-2.5.so
+ - postgis-3.so, postgis_raster-3.so, postgis_sfcgal-3.so, postgis_topology-3.so
+PostGIS 3 was a bit rocky in that some things were missed in 3.0 release and fixed in 3.1.
+Namely, postgis_sfcgal prior to 3.1 was embedded in the postgis-*.so which meant not all postgis libs
+had the same set of functions, which was BAD. When 3.1 rolled around the siamese beast was separated to form
+postgis-3.so, postgis_sfcgal-3.so.
+Also in 3.0.0, the raster functionality was removed from the postgis extension and moved to an extension called postgis_raster.
+The libraries of these were always separate, however the name rtpostgis- that packaged all the raster functions, did not match the extension
+name so was renamed, but for all purposes rtpostgis of the past is equivalent to postgis_raster of the present.
+All these changes were made to ease upgrade pains with pg_upgrade.
+As a developer you still have the option of having your lib files minor versioned
+for easier testing in the same cluster.
+To take advantage of this feature, when configuring postgis compile, use the switch *--with-library-minor-version*
+Does and Don'ts
+* Don't introduce new SQL Api functions in a Patch release.
+* Don't change structure definitions e.g. geometry_columns, geometry/raster type
+ in a patch release.
+* Do introduce new SQL Api functions in a Minor release.
+* Functions that are not exposed via the SQL Api can be introduced any time.
+* Only major versions can remove SQL api functions
+ or C api functions without stubbing (which we will cover shortly).
+* Only major versions can introduce functionality that requires a pg_dump / pg_restore.
+When removing objects impacts upgrade
+There are several types of removals that impact user upgrades and should be carefully thought thru.
+* C Api functions
+* Types, Views, Tables are also exposed via SQL Api
+Functions internal to postgis that are never exposed and only used within postgis libraries
+can be shuffled around to your hearts content.
+UPGRADING C Api functions
+You should avoid ever removing C Api function in Minor and patch releases of PostGIS.
+If there is a C Api function that you badly want to remove you need to stub it so the signature still
+exists but throws an error.
+These functions should be removed from whatever file
+they were in and stubbed in a deprecation file. Ideally you should never do this in a micro. Only minor.
+For Major such as when PostGIS 4 comes out we could in theory skip the legacy file and just chuck the function entirely.
+We could even blank out all the legacy files.
+A function can be stubbed in 3.0.0, but not 3.0.1, though there are cases where you might as long as
+you carefully fix up the SQL signature exposing it. The reason to avoid not doing this in a micro is people often do not
+run ALTER EXTENSION or SELECT postgis_extensions_upgrade() in a micro, so taking these out will break production code.
+ * For the postgis extension, these should go in postgis/postgis_legacy.c the stub will look something like this.
+ POSTGIS_DEPRECATE("2.0.0", postgis_uses_stats)
+ Note the specification of the version it was removed and the name of the function
+ * For postgis_sfcgal, deprecated C api functions should go in sfcgal/postgis_sfcgal_legacy.c
+ * For postgis_raster, raster/rt_pg/rtpg_legacy.c
+ * postgis_topology extension has never had any deprecated functions so there is currently no legacy file for it.
+ If there comes a need to deprecate C functions, then a file topology/postgis_topology_legacy.c will be created to store these.
+ * postgis_tiger_geocoder is all sql and plpgsql so it has no C backing functions.
+Why do we even bother replacing a good function with a function that throws an error? Because of pg_upgrade tool used
+to upgrade PostgreSQL clusters. When pg_upgrade runs, it does not use the regular CREATE EXTENSION routine that loads function definitions from
+a file. Instead it uses a naked CREATE EXTENSION and then tries to load all functions /types /etc/ from the old databases as they existed
+meaning they point at the same .so, .dll, .dylib whatever. When it tries to load these in, it validates the library to make sure said
+functions exist in the library. If these functions don't it will bail and pg_upgrade will fail. It however will do fine
+not complain if the function exists even if all the function knows how to do is throw an error.
+WHY oh WHY does it use old signatures in an old database instead of a fresh CREATE EXTENSION install?
+Primarily because objects are referenced by object identifiers AKA oids in views, tables, you name it, and if you create new function
+from scratch, even if it has the same exact definition as the old, it does not have the same OID.
+As such all db internal references would be broken
+if you try to overlay the old def structures onto the new extension install.
+So this whole care of legacy functions is to appease pg_upgrade.
+UPGRADING SQL Api functions
+For most SQL Api functions, nothing special needs to be done beyond
+noting a CHANGED in version or AVAILABILITY in the respective .sql.in files.
+The SQL Api definitions are found in following places:
+* postgis extension, postgis/postgis_sql.in, geography.sql.in, postgis.bin.sql.in, or postgis_spgist.sql.in
+* postgis_raster extension raster/rt_pg/rtpostgis.sql.in
+* postgis_sfcgal extension sfcgal/sfcgal.sql.in
+* postgis_topology - topology/sql/*.sql.in
+We use perl scripts to stitch together these various SQL and
+read meta comments to determine what to do during an upgrade.
+The utils/create_upgrade.pl is the script that is tasked with creating upgrade scripts.
+The various notes you put in .sql.in files take the following form and precede the function/type/etc definition:
+* -- Availability: Is only informational 2.0.0 where 2.0.0 represents the version it was introduced in.
+* -- Changed: Is only informational. You'll often see an Availability comment followed by a changed comment.
+ e.g.
+ -- Availability: 0.1.0
+ -- Changed: 2.0.0 use gserialized selectivity estimators
+* -- Replaces: is both informational and also instructs the perl upgrade script to protect the user from some upgrade pains.
+ You use Replaces instead of just a simple Changed, if you are changing inputs to the function or changing
+ outputs of the function. So any change to the api
+ Such a comment would look something like:
+ -- Availability: 2.1.0
+ -- Changed: 3.1.0 - add zvalue=0.0 parameter
+ -- Replaces ST_Force3D(geometry) deprecated in 3.1.0
+ When utils/create_upgrade.pl script comes across a Replaces clause, the perl script will change the statement to do the following
+ 1) Finds the old definition
+ 2) renames the old definition to ST_Force3D_deprecated_by_postgis_310
+ 3) Installs the new version of the function.
+ 4) At the end of the upgrade script, it will try to drop the function. If the old function is bound
+ to user objects, it will leave the old function alone and warn the user as part of the upgrade, that they have objects bound to an old signature.
+ Why do we do this? Because all objects are bound by oids and not names. So if a user has a view or materialized view, it will be bound to
+ ST_Force3D_deprecated_by_postgis_310 and not the new ST_Force3D. We can't drop things bound to user objects without executing a
+ DROP ... CASCADE, which will destroy user objects.
+For some objects such as types and casts, comments are not sufficient to get create_upgrade.pl to do the right thing.
+In these cases you need to do this work yourself as needed.
+Case in point, if you are removing a signature and have no replacement for it. You just want to drop it.
+You'll put the code in the relevant **after_upgrade** script corresponding to the extension you are changing.
+If you need something dropped or need to make some system changes that would prevent new function from being installed, then you would put this in a **before_upgrade** script.
+The relevant files for each extension are as follows:
+* postgis - postgis/postgis_before_upgrade.sql , postgis/postgis_after_upgrade.sql
+* postgis_raster - raster/rtpostgis_drop.sql.in, rtpostgis_upgrade_cleanup.sql.in
+ (the rtpostgis_upgrade_cleanup.sql.in is equivalent to the after_ugprade script of other extensions)
+* postgis_sfcgal - sfcgal/sfcgal_before_upgrade.sql.in, sfcgal/sfcgal_after_upgrade.sql.in
+* postgis_topology - sfcgal/topology_before_upgrade.sql.in, sfcgal/topology_after_upgrade.sql.in
+Helper function calls you'll find in these scripts are the following and are defined in postgis/common_before_upgrade.sql and dropped in
+postgis/common_after_upgrade.sql
+* _postgis_drop_function_by_signature - generally you want to use this one as it only cares about input types of functions
+* _postgis_drop_function_by_identity - this one you'll want to use if for some awful reason, all you are doing is changing the names of input types.
+These ones are new in 3.6.0 to handle the very delicate major upgrade of topology which required changing of data types and tables
+* _postgis_drop_cast_by_types
+* _postgis_add_column_to_table
+Dependency Library Guarding
+On many occasions, we'll introduce functionality that can only be used if PostGIS is compiled
+with a dependency library higher than X? Where X is some version of a dependency library.
+Dependency guards need to be put in both the C library files and our test files.
+On some occassions where we need to do something different based on version of PostgreSQL,
+you'll see guards in the SQL files as well.
+We have guards in place in the code to handle these for dependency libraries
+* PostgreSQL
+ - sql, c: ``#if POSTGIS_PGSQL_VERSION >= 150``
+ - regress/../tests.mk.in
+* GEOS
+ - c: ``#if POSTGIS_GEOS_VERSION < 31000``
+ - tests: shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30900
+ * regress/../tests.mk.in
+ * raster/rt_pg/tests/tests.mi.in
+* SFCGAL
+ - c: ``#if POSTGIS_SFCGAL_VERSION >= 10400``
+ - tests: ``ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 10401),1)``
+ * sfcgal/regress/tests.mk.in
+* PROJ
+* GDAL
+Even if a user can't use a certain function, that function still needs to be exposed,
+but instead of doing something functional, will output an error that the extension needs to be compiled
+with lib xxx or higher. Also the function has to be available in the C lib, as such the guarding is always done
+on the C lib side and very rarely on the sql files.
diff --git a/doc/developer.txt b/doc/developer.txt
deleted file mode 100644
index 580ebe79e..000000000
--- a/doc/developer.txt
+++ /dev/null
@@ -1,143 +0,0 @@
-TITLE: PostGIS Developer How-To
-AUTHOR: Name: Regina Obe
-DATE: 2025-08-12
-CATEGORY: Development Docs
-When removing objects impacts upgrade
-There are two types of function removals that impact user upgrades and should be carefully thought thru.
-* SQL Api functions - these are functions that are exposed to the user in the database.
- They are either SQl, plpgsql, or C backed functions.
-* C Api functions -- these are postgis lib functions that back SQL Api functions
-* Types, Views are also exposed via SQL Api
-Functions internal to postgis that are never exposed and only used within postgis libraries
-can be shuffled around to your hearts content.
-UPGRADING C Api functions
-You should avoid ever removing C Api function in Minor and Micro releases of PostGIS.
-If there is a C Api function that you badly want to remove you need to stub it so the signature still
-exists but throws an error.
-These functions should be removed from whatever file
-they were in and stubbed in a deprecation file. Ideally you should never do this in a micro. Only minor.
-For Major such as when PostGIS 4 comes out we could in theory skip the legacy file and just chuck the function entirely.
-So a function can be stubbed in 3.0.0, but not 3.0.1, though there are cases where you might as long as
-you carefully fix up the SQL signature exposing it. The reason to avoid not doing this in a micro is people often do not
-run ALTER EXTENSION or SELECT postgis_extensions_upgrade() in a micro, so taking these out will break production code.
- * For the postgis extension, these should go in postgis/postgis_legacy.c the stub will look something like this.
- POSTGIS_DEPRECATE("2.0.0", postgis_uses_stats)
- Note the specification of the version it was removed and the name of the function
- * For postgis_sfcgal, deprecated C api functions should go in sfcgal/postgis_sfcgal_legacy.c
- * For postgis_raster, raster/rt_pg/rtpg_legacy.c
- * postgis_topology extension has never had any deprecated functions so there is currently no legacy file for it.
- If there comes a need to deprecate C functions, then a file topology/postgis_topology_legacy.c will be created to store these.
- * postgis_tiger_geocoder is all sql and plpgsql so it has no C backing functions.
-Why do we even bother replacing a good function with a function that throws an error? Because of pg_upgrade tool used
-to upgrade PostgreSQL clusters. When pg_upgrade runs, it does not use the regular CREATE EXTENSION routine that loads function definitions from
-a file. Instead it uses a naked CREATE EXTENSION and then tries to load all functions /types /etc/ from the old databases as they existed
-meaning they point at the same .so, .dll, .dylib whatever. When it tries to load these in, it validates the library to make sure said
-functions exist in the library. If these functions don't it will bail and pg_upgrade will fail. It however will do fine
-not complain if the function exists even if all the function knows how to do is throw an error.
-WHY oh WHY does it use old signatures in an old database instead of a fresh CREATE EXTENSION install?
-Primarily because objects are referenced by object identifiers AKA oids in views, tables, you name it, and if you create new function
-from scratch, even if it has the same exact definition as the old, it does not have the same OID.
-As such all db internal references would be broken
-if you try to overlay the old def structures onto the new extension install.
-So this whole care of legacy functions is to appease pg_upgrade.
-UPGRADING SQL Api functions
-For most SQL Api functions, nothing special needs to be done beyond
-noting a CHANGED in version or AVAILABILITY in the respective .sql.in files.
-The SQL Api definitions are found in following places:
-* postgis extension, postgis/postgis_sql.in, geography.sql.in, postgis.bin.sql.in, or postgis_spgist.sql.in
-* postgis_raster extension raster/rt_pg/rtpostgis.sql.in
-* postgis_sfcgal extension sfcgal/sfcgal.sql.in
-* postgis_topology - topology/sql/*.sql.in
-We use perl scripts to stitch together these various SQL and
-read meta comments to determine what to do during an upgrade.
-The utils/create_upgrade.pl is the script that is tasked with creating upgrade scripts.
-The various notes you put in .sql.in files take the following form and precede the function/type/etc definition:
-* -- Availability: Is only informational 2.0.0 where 2.0.0 represents the version it was introduced in.
-* -- Changed: Is only informational. You'll often see an Availability comment followed by a changed comment.
- e.g.
- -- Availability: 0.1.0
- -- Changed: 2.0.0 use gserialized selectivity estimators
-* -- Replaces: is both informational and also instructs the perl upgrade script to protect the user from some upgrade pains.
- You use Replaces instead of just a simple Changed, if you are changing inputs to the function or changing
- outputs of the function. So any change to the api
- Such a comment would look something like:
- -- Availability: 2.1.0
- -- Changed: 3.1.0 - add zvalue=0.0 parameter
- -- Replaces ST_Force3D(geometry) deprecated in 3.1.0
- When utils/create_upgrade.pl script comes across a Replaces clause, the perl script will change the statement to do the following
- 1) Finds the old definition
- 2) renames the old definition to ST_Force3D_deprecated_by_postgis_310
- 3) Installs the new version of the function.
- 4) At the end of the upgrade script, it will try to drop the function. If the old function is bound
- to user objects, it will leave the old function alone and warn the user as part of the upgrade, that they have objects bound to an old signature.
- Why do we do this? Because all objects are bound by oids and not names. So if a user has a view or materialized view, it will be bound to
- ST_Force3D_deprecated_by_postgis_310 and not the new ST_Force3D. We can't drop things bound to user objects without executing a
- DROP ... CASCADE, which will destroy user objects.
-For some objects such as types and casts, comments are not sufficient to get create_upgrade.pl to do the right thing.
-In these cases you need to do this work yourself as needed.
-Case in point, if you are removing a signature and have no replacement for it. You just want to drop it.
-In these cases you'll put code in the before_upgrade.sql or after_upgrade.sql corresponding to the extension you are changing.
-* postgis extension - postgis/postgis_before_upgrade.sql , postgis/postgis_after_upgrade.sql
-* postgis_sfcgal - sfcgal/sfcgal_before_upgrade.sql.in, sfcgal/sfcgal_after_upgrade.sql.in
-* postgis_topology - sfcgal/topology_before_upgrade.sql.in, sfcgal/topology_after_upgrade.sql.in
-Helper function calls you'll find in these scripts are the following and are defined in postgis/common_before_upgrade.sql and dropped in
-postgis/common_after_upgrade.sql
-* _postgis_drop_function_by_signature
-* _postgis_drop_function_by_identity
-# these ones are new in 3.6.0 to handle the very delicate major upgrade of topology
-* _postgis_drop_cast_by_types
-* _postgis_add_column_to_table
commit c3b29709e612bcdb9a2cf74172a569d30d763f7a
Date: Mon Aug 18 00:04:01 2025 -0400
Remove accidentally committed raster/regress/tests.mk
Also prevent it from being committed in future
diff --git a/.gitignore b/.gitignore
index e9e76c0a9..7b0df68ff 100644
--- a/.gitignore
+++ b/.gitignore
@@ -28,6 +28,10 @@ doc/images
doc/html/images/generator
doc/html/images/Makefile
regression.out
+raster/test/regress/tests.mk
+regress/core/tests.mk
+sfcgla/regress/tests.mk
# PNG images under doc/html/images
# should be either symlinks or generated
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 7bcdda63b..000000000
--- a/raster/test/regress/tests.mk
+++ /dev/null
@@ -1,156 +0,0 @@
-# * PostGIS - Spatial Types for PostgreSQL
-# * http://postgis.net
-# * Copyright (C) 2020 Sandro Santilli <strk at kbt.io>
-# * This is free software; you can redistribute and/or modify it under
-# * the terms of the GNU General Public Licence. See the COPYING file.
-POSTGIS_GEOS_VERSION=31400
-override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
-override RUNTESTFLAGS_INTERNAL := \
- --before-upgrade-script $(top_srcdir)/raster/test/regress/hooks/hook-before-upgrade-raster.sql \
- $(RUNTESTFLAGS_INTERNAL) \
- --after-upgrade-script $(top_srcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
-RASTER_TEST_FIRST = \
- $(top_srcdir)/raster/test/regress/check_gdal \
- $(top_srcdir)/raster/test/regress/loader/load_outdb
-RASTER_TEST_LAST = \
- $(top_srcdir)/raster/test/regress/clean
-RASTER_TEST_METADATA = \
- $(top_srcdir)/raster/test/regress/check_raster_columns \
- $(top_srcdir)/raster/test/regress/check_raster_overviews
-RASTER_TEST_IO = \
- $(top_srcdir)/raster/test/regress/rt_io
-RASTER_TEST_BASIC_FUNC = \
- $(top_srcdir)/raster/test/regress/rt_bytea \
- $(top_srcdir)/raster/test/regress/rt_wkb \
- $(top_srcdir)/raster/test/regress/box3d \
- $(top_srcdir)/raster/test/regress/rt_addband \
- $(top_srcdir)/raster/test/regress/rt_band \
- $(top_srcdir)/raster/test/regress/rt_tile
-RASTER_TEST_PROPS = \
- $(top_srcdir)/raster/test/regress/rt_dimensions \
- $(top_srcdir)/raster/test/regress/rt_scale \
- $(top_srcdir)/raster/test/regress/rt_pixelsize \
- $(top_srcdir)/raster/test/regress/rt_upperleft \
- $(top_srcdir)/raster/test/regress/rt_rotation \
- $(top_srcdir)/raster/test/regress/rt_georeference \
- $(top_srcdir)/raster/test/regress/rt_set_properties \
- $(top_srcdir)/raster/test/regress/rt_isempty \
- $(top_srcdir)/raster/test/regress/rt_hasnoband \
- $(top_srcdir)/raster/test/regress/rt_metadata \
- $(top_srcdir)/raster/test/regress/rt_rastertoworldcoord \
- $(top_srcdir)/raster/test/regress/rt_worldtorastercoord \
- $(top_srcdir)/raster/test/regress/rt_convexhull \
- $(top_srcdir)/raster/test/regress/rt_envelope
-RASTER_TEST_BANDPROPS = \
- $(top_srcdir)/raster/test/regress/rt_band_properties \
- $(top_srcdir)/raster/test/regress/rt_set_band_properties \
- $(top_srcdir)/raster/test/regress/rt_pixelaspolygons \
- $(top_srcdir)/raster/test/regress/rt_pixelaspoints \
- $(top_srcdir)/raster/test/regress/rt_pixelascentroids \
- $(top_srcdir)/raster/test/regress/rt_setvalues_array \
- $(top_srcdir)/raster/test/regress/rt_summarystats \
- $(top_srcdir)/raster/test/regress/rt_count \
- $(top_srcdir)/raster/test/regress/rt_histogram \
- $(top_srcdir)/raster/test/regress/rt_quantile \
- $(top_srcdir)/raster/test/regress/rt_valuecount \
- $(top_srcdir)/raster/test/regress/rt_valuepercent \
- $(top_srcdir)/raster/test/regress/rt_bandmetadata \
- $(top_srcdir)/raster/test/regress/rt_pixelvalue \
- $(top_srcdir)/raster/test/regress/rt_neighborhood \
- $(top_srcdir)/raster/test/regress/rt_nearestvalue \
- $(top_srcdir)/raster/test/regress/rt_pixelofvalue \
- $(top_srcdir)/raster/test/regress/rt_polygon \
- $(top_srcdir)/raster/test/regress/rt_setbandpath
-RASTER_TEST_UTILITY = \
- $(top_srcdir)/raster/test/regress/rt_utility \
- $(top_srcdir)/raster/test/regress/rt_fromgdalraster \
- $(top_srcdir)/raster/test/regress/rt_asgdalraster \
- $(top_srcdir)/raster/test/regress/rt_astiff \
- $(top_srcdir)/raster/test/regress/rt_asjpeg \
- $(top_srcdir)/raster/test/regress/rt_aspng \
- $(top_srcdir)/raster/test/regress/rt_reclass \
- $(top_srcdir)/raster/test/regress/rt_reclassexact \
- $(top_srcdir)/raster/test/regress/rt_gdalwarp \
- $(top_srcdir)/raster/test/regress/rt_gdalcontour \
- $(top_srcdir)/raster/test/regress/rt_asraster \
- $(top_srcdir)/raster/test/regress/rt_asrasteragg \
- $(top_srcdir)/raster/test/regress/rt_dumpvalues \
- $(top_srcdir)/raster/test/regress/rt_makeemptycoverage \
- $(top_srcdir)/raster/test/regress/rt_createoverview
-RASTER_TEST_MAPALGEBRA = \
- $(top_srcdir)/raster/test/regress/rt_mapalgebraexpr \
- $(top_srcdir)/raster/test/regress/rt_mapalgebrafct \
- $(top_srcdir)/raster/test/regress/rt_mapalgebraexpr_2raster \
- $(top_srcdir)/raster/test/regress/rt_mapalgebrafct_2raster \
- $(top_srcdir)/raster/test/regress/rt_mapalgebrafctngb \
- $(top_srcdir)/raster/test/regress/rt_mapalgebrafctngb_userfunc \
- $(top_srcdir)/raster/test/regress/rt_intersection \
- $(top_srcdir)/raster/test/regress/rt_clip \
- $(top_srcdir)/raster/test/regress/rt_mapalgebra \
- $(top_srcdir)/raster/test/regress/rt_mapalgebra_expr \
- $(top_srcdir)/raster/test/regress/rt_mapalgebra_mask \
- $(top_srcdir)/raster/test/regress/rt_union \
- $(top_srcdir)/raster/test/regress/rt_invdistweight4ma \
- $(top_srcdir)/raster/test/regress/rt_4ma \
- $(top_srcdir)/raster/test/regress/rt_setvalues_geomval \
- $(top_srcdir)/raster/test/regress/rt_elevation_functions \
- $(top_srcdir)/raster/test/regress/rt_colormap \
- $(top_srcdir)/raster/test/regress/rt_grayscale
-RASTER_TEST_SREL = \
- $(top_srcdir)/raster/test/regress/rt_gist_relationships \
- $(top_srcdir)/raster/test/regress/rt_intersects \
- $(top_srcdir)/raster/test/regress/rt_samealignment \
- $(top_srcdir)/raster/test/regress/rt_geos_relationships \
- $(top_srcdir)/raster/test/regress/rt_iscoveragetile
-RASTER_TEST_BUGS = \
- $(top_srcdir)/raster/test/regress/bug_test_car5 \
- $(top_srcdir)/raster/test/regress/permitted_gdal_drivers \
- $(top_srcdir)/raster/test/regress/tickets
-RASTER_TEST_LOADER = \
- $(top_srcdir)/raster/test/regress/loader/Basic \
- $(top_srcdir)/raster/test/regress/loader/Projected \
- $(top_srcdir)/raster/test/regress/loader/BasicCopy \
- $(top_srcdir)/raster/test/regress/loader/BasicFilename \
- $(top_srcdir)/raster/test/regress/loader/BasicOutDB \
- $(top_srcdir)/raster/test/regress/loader/Tiled10x10 \
- $(top_srcdir)/raster/test/regress/loader/Tiled10x10Copy \
- $(top_srcdir)/raster/test/regress/loader/Tiled8x8 \
- $(top_srcdir)/raster/test/regress/loader/TiledAuto \
- $(top_srcdir)/raster/test/regress/loader/TiledAutoSkipNoData \
- $(top_srcdir)/raster/test/regress/loader/TiledAutoCopyn
-RASTER_TESTS := $(RASTER_TEST_FIRST) \
- $(RASTER_TEST_METADATA) $(RASTER_TEST_IO) $(RASTER_TEST_BASIC_FUNC) \
- $(RASTER_TEST_PROPS) $(RASTER_TEST_BANDPROPS) \
- $(RASTER_TEST_UTILITY) $(RASTER_TEST_MAPALGEBRA) $(RASTER_TEST_SREL) \
- $(RASTER_TEST_BUGS) \
- $(RASTER_TEST_LOADER) \
- $(RASTER_TEST_LAST)
-TESTS += $(RASTER_TESTS)
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31400),1)
- TESTS += \
- $(top_srcdir)/raster/test/regress/rt_intersection_fractions
-endif
Summary of changes:
.gitignore | 4 +
NEWS | 10 +-
README.postgis | 6 +-
Version.config | 2 +-
ci/berrie/configs.sh | 2 +-
doc/developer.md | 233 +++++++++++++++++++++++++
doc/developer.txt | 143 ---------------
doc/po/templates/postgis-manual.pot | 336 +++++++++++++++++++++---------------
doc/release_notes.xml | 13 +-
extensions/upgradeable_versions.mk | 3 +-
raster/test/regress/tests.mk | 156 -----------------
11 files changed, 453 insertions(+), 455 deletions(-)
create mode 100644 doc/developer.md
delete mode 100644 doc/developer.txt
delete mode 100644 raster/test/regress/tests.mk
hooks/post-receive
