[SCM] PostGIS branch master updated. 3.6.0beta1-49-g6fd251315
git at osgeo.org
git at osgeo.org
Sun Aug 17 23:49:54 PDT 2025
the project "PostGIS".
via 6fd251315b8c90c10cd9f56c540de6a460773207 (commit)
from 85d49ec074ff9e1026bde63ea57a4a4d7b9bc261 (commit)
revisions in full, below.
commit 6fd251315b8c90c10cd9f56c540de6a460773207
Author: Regina Obe <lr at pcorp.us>
Date: Mon Aug 18 02:48:34 2025 -0400
Missed in last commit
- Really remove load_large_topology**.sql files
- Put them in .gitignore so they are not accidentally committed again
References #5963 for PostGIS 3.6.0
diff --git a/.gitignore b/.gitignore
index 1bdc4ca0b..a20a6f16b 100644
--- a/.gitignore
+++ b/.gitignore
@@ -196,6 +196,8 @@ topology/Makefile
topology/test/Makefile
topology/test/load_topology-4326.sql
topology/test/load_topology.sql
+topology/test/load_large_topology-4326.sql
+topology/test/load_large_topology.sql
topology/test/topo_predicates.sql
topology/topology_after_upgrade.sql
topology/topology_before_upgrade.sql
diff --git a/topology/test/load_large_topology-4326.sql b/topology/test/load_large_topology-4326.sql
deleted file mode 100644
index 3cd5aae96..000000000
--- a/topology/test/load_large_topology-4326.sql
+++ /dev/null
@@ -1,204 +0,0 @@
--- From examples in chapter 1.12.1 of
--- "Spatial Topology and Network Data Models" (Oracle manual)
--- Modified to use postgis-based topology model.
--- Loads the whole topology represented in Figure 1-1 of the
--- manual
---ORA---------------------------------------------------------------------
---ORA---- Main steps for using the topology data model with a topology
---ORA---- built from edge, node, and face data
---ORA---- 1. Create a topology.
---ORA---- 2. Load (normally bulk-load) topology data
---ORA---- (node, edge, and face tables).
-BEGIN;
--- 1. Create the topology.
--- NOTE:
--- Returns topology id... which depend on how many
--- topologies where created in the regress database
--- so we just check it is a number greater than 0
-SELECT NULL FROM topology.CreateTopology('large_city_data', 4326, 0, false, 0, true);
--- 2. Load topology data (node, edge, and face tables).
--- Use INSERT statements here instead of a bulk-load utility.
--- 2A. Insert data into <topology_name>.FACE table.
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000001); -- F1
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000002); -- F2
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000003); -- F3
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000004); -- F4
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000005); -- F5
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000006); -- F6
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000007); -- F7
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000008); -- F8
-INSERT INTO large_city_data.face(face_id) VALUES(1000000000009); -- F9
--- UPDATE Face id sequence
-SELECT NULL FROM setval('large_city_data.face_face_id_seq', 1000000000009);
--- 2B. Insert data into <topology_name>.NODE table.
--- N1
-INSERT INTO large_city_data.node(node_id, geom, containing_face)
- VALUES(1000000000001, 'SRID=4326;POINT(8 30)', NULL);
--- N2
- VALUES(1000000000002, 'SRID=4326;POINT(25 30)', NULL);
--- N3
- VALUES(1000000000003, 'SRID=4326;POINT(25 35)', NULL);
--- N4
- VALUES(1000000000004, 'SRID=4326;POINT(20 37)', 1000000000002);
--- N5
- VALUES(1000000000005, 'SRID=4326;POINT(36 38)', NULL);
--- N6
- VALUES(1000000000006, 'SRID=4326;POINT(57 33)', NULL);
--- N7
- VALUES(1000000000007, 'SRID=4326;POINT(41 40)', NULL);
--- N8
- VALUES(1000000000008, 'SRID=4326;POINT(9 6)', NULL);
--- N9
- VALUES(1000000000009, 'SRID=4326;POINT(21 6)', NULL);
--- N10
- VALUES(1000000000010, 'SRID=4326;POINT(35 6)', NULL);
--- N11
- VALUES(1000000000011, 'SRID=4326;POINT(47 6)', NULL);
--- N12
- VALUES(1000000000012, 'SRID=4326;POINT(47 14)', NULL);
--- N13
- VALUES(1000000000013, 'SRID=4326;POINT(35 14)', NULL);
--- N14
- VALUES(1000000000014, 'SRID=4326;POINT(21 14)', NULL);
--- N15
- VALUES(1000000000015, 'SRID=4326;POINT(9 14)', NULL);
--- N16
- VALUES(1000000000016, 'SRID=4326;POINT(9 22)', NULL);
--- N17
- VALUES(1000000000017, 'SRID=4326;POINT(21 22)', NULL);
--- N18
- VALUES(1000000000018, 'SRID=4326;POINT(35 22)', NULL);
--- N19
- VALUES(1000000000019, 'SRID=4326;POINT(47 22)', NULL);
--- N20
- VALUES(1000000000020, 'SRID=4326;POINT(4 31)', NULL);
--- N21
- VALUES(1000000000021, 'SRID=4326;POINT(9 35)', NULL);
--- N22
- VALUES(1000000000022, 'SRID=4326;POINT(13 35)', NULL);
--- UPDATE Node id sequence
-SELECT NULL FROM setval('large_city_data.node_node_id_seq', 1000000000022);
--- 2C. Insert data into <topology_name>.EDGE table.
--- E1
-INSERT INTO large_city_data.edge VALUES(1000000000001, 1000000000001, 1000000000001, 1000000000001, -1000000000001, 1000000000001, 0,
- 'SRID=4326;LINESTRING(8 30, 16 30, 16 38, 3 38, 3 30, 8 30)');
--- E2
-INSERT INTO large_city_data.edge VALUES(1000000000002, 1000000000002, 1000000000002, 1000000000003, -1000000000002, 1000000000002, 0,
- 'SRID=4326;LINESTRING(25 30, 31 30, 31 40, 17 40, 17 30, 25 30)');
--- E3
-INSERT INTO large_city_data.edge VALUES(1000000000003, 1000000000002, 1000000000003, -1000000000003, 1000000000002, 1000000000002, 1000000000002,
- 'SRID=4326;LINESTRING(25 30, 25 35)');
--- E4
-INSERT INTO large_city_data.edge VALUES(1000000000004, 1000000000005, 1000000000006, -1000000000005, 1000000000004, 0, 0,
- 'SRID=4326;LINESTRING(36 38, 38 35, 41 34, 42 33, 45 32, 47 28, 50 28, 52 32, 57 33)');
--- E5
-INSERT INTO large_city_data.edge VALUES(1000000000005, 1000000000007, 1000000000006, -1000000000004, 1000000000005, 0, 0,
- 'SRID=4326;LINESTRING(41 40, 45 40, 47 42, 62 41, 61 38, 59 39, 57 36, 57 33)');
--- E6
-INSERT INTO large_city_data.edge VALUES(1000000000006, 1000000000016, 1000000000017, 1000000000007, -1000000000021, 0, 1000000000003,
- 'SRID=4326;LINESTRING(9 22, 21 22)');
--- E7
-INSERT INTO large_city_data.edge VALUES(1000000000007, 1000000000017, 1000000000018, 1000000000008, -1000000000019, 0, 1000000000004,
- 'SRID=4326;LINESTRING(21 22, 35 22)');
--- E8
-INSERT INTO large_city_data.edge VALUES(1000000000008, 1000000000018, 1000000000019, -1000000000015, -1000000000017, 0, 1000000000005,
- 'SRID=4326;LINESTRING(35 22, 47 22)');
--- E9
-INSERT INTO large_city_data.edge VALUES(1000000000009, 1000000000015, 1000000000014, 1000000000019, -1000000000022, 1000000000003, 1000000000006,
- 'SRID=4326;LINESTRING(9 14, 21 14)');
--- E10
-INSERT INTO large_city_data.edge VALUES(1000000000010, 1000000000013, 1000000000014, -1000000000020, 1000000000017, 1000000000007, 1000000000004,
- 'SRID=4326;LINESTRING(35 14, 21 14)');
--- E11
-INSERT INTO large_city_data.edge VALUES(1000000000011, 1000000000013, 1000000000012, 1000000000015, -1000000000018, 1000000000005, 1000000000008,
- 'SRID=4326;LINESTRING(35 14, 47 14)');
--- E12
-INSERT INTO large_city_data.edge VALUES(1000000000012, 1000000000008, 1000000000009, 1000000000020, 1000000000022, 1000000000006, 0,
- 'SRID=4326;LINESTRING(9 6, 21 6)');
--- E13
-INSERT INTO large_city_data.edge VALUES(1000000000013, 1000000000009, 1000000000010, 1000000000018, -1000000000012, 1000000000007, 0,
- 'SRID=4326;LINESTRING(21 6, 35 6)');
--- E14
-INSERT INTO large_city_data.edge VALUES(1000000000014, 1000000000010, 1000000000011, 1000000000016, -1000000000013, 1000000000008, 0,
- 'SRID=4326;LINESTRING(35 6, 47 6)');
--- E15
-INSERT INTO large_city_data.edge VALUES(1000000000015, 1000000000012, 1000000000019, -1000000000008, -1000000000016, 1000000000005, 0,
- 'SRID=4326;LINESTRING(47 14, 47 22)');
--- E16
-INSERT INTO large_city_data.edge VALUES(1000000000016, 1000000000011, 1000000000012, -1000000000011, -1000000000014, 1000000000008, 0,
- 'SRID=4326;LINESTRING(47 6, 47 14)');
--- E17
-INSERT INTO large_city_data.edge VALUES(1000000000017, 1000000000013, 1000000000018, -1000000000007, 1000000000011, 1000000000004, 1000000000005,
- 'SRID=4326;LINESTRING(35 14, 35 22)');
--- E18
-INSERT INTO large_city_data.edge VALUES(1000000000018, 1000000000010, 1000000000013, 1000000000010, 1000000000014, 1000000000007, 1000000000008,
- 'SRID=4326;LINESTRING(35 6, 35 14)');
--- E19
-INSERT INTO large_city_data.edge VALUES(1000000000019, 1000000000014, 1000000000017, -1000000000006, -1000000000010, 1000000000003, 1000000000004,
- 'SRID=4326;LINESTRING(21 14, 21 22)');
--- E20
-INSERT INTO large_city_data.edge VALUES(1000000000020, 1000000000009, 1000000000014, -1000000000009, 1000000000013, 1000000000006, 1000000000007,
- 'SRID=4326;LINESTRING(21 6, 21 14)');
--- E21
-INSERT INTO large_city_data.edge VALUES(1000000000021, 1000000000015, 1000000000016, 1000000000006, 1000000000009, 0, 1000000000003,
- 'SRID=4326;LINESTRING(9 14, 9 22)');
--- E22
-INSERT INTO large_city_data.edge VALUES(1000000000022, 1000000000008, 1000000000015, 1000000000021, 1000000000012, 0, 1000000000006,
- 'SRID=4326;LINESTRING(9 6, 9 14)');
--- E25
-INSERT INTO large_city_data.edge VALUES(1000000000025, 1000000000021, 1000000000022, -1000000000025, 1000000000025, 1000000000001, 1000000000001,
- 'SRID=4326;LINESTRING(9 35, 13 35)');
--- E26
-INSERT INTO large_city_data.edge VALUES(1000000000026, 1000000000020, 1000000000020, 1000000000026, -1000000000026, 1000000000009, 1000000000001,
- 'SRID=4326;LINESTRING(4 31, 7 31, 7 34, 4 34, 4 31)');
--- UPDATE Edge id sequence
-SELECT NULL FROM setval('large_city_data.edge_data_edge_id_seq', 1000000000026);
--- Set face minimum bounding rectangle
-UPDATE large_city_data.face set mbr = ST_SetSRID( ( select st_extent(geom) from large_city_data.edge where left_face = face_id or right_face = face_id ), 4326 ) where face_id != 0;
--- Validate the loaded topology
-SELECT 'load_validation', *
-FROM ValidateTopology('large_city_data')
-WHERE error IS NOT NULL;
-END;
diff --git a/topology/test/load_large_topology.sql b/topology/test/load_large_topology.sql
index 9290b5091..000000000
--- a/topology/test/load_large_topology.sql
+++ /dev/null
@@ -1,204 +0,0 @@
--- manual
-BEGIN;
--- NOTE:
-SELECT NULL FROM topology.CreateTopology('large_city_data', -1, 0, false, 0, true);
--- N1
- VALUES(1000000000001, 'SRID=-1;POINT(8 30)', NULL);
--- N2
- VALUES(1000000000002, 'SRID=-1;POINT(25 30)', NULL);
--- N3
- VALUES(1000000000003, 'SRID=-1;POINT(25 35)', NULL);
--- N4
- VALUES(1000000000004, 'SRID=-1;POINT(20 37)', 1000000000002);
--- N5
- VALUES(1000000000005, 'SRID=-1;POINT(36 38)', NULL);
--- N6
- VALUES(1000000000006, 'SRID=-1;POINT(57 33)', NULL);
--- N7
- VALUES(1000000000007, 'SRID=-1;POINT(41 40)', NULL);
--- N8
- VALUES(1000000000008, 'SRID=-1;POINT(9 6)', NULL);
--- N9
- VALUES(1000000000009, 'SRID=-1;POINT(21 6)', NULL);
--- N10
- VALUES(1000000000010, 'SRID=-1;POINT(35 6)', NULL);
--- N11
- VALUES(1000000000011, 'SRID=-1;POINT(47 6)', NULL);
--- N12
- VALUES(1000000000012, 'SRID=-1;POINT(47 14)', NULL);
--- N13
- VALUES(1000000000013, 'SRID=-1;POINT(35 14)', NULL);
--- N14
- VALUES(1000000000014, 'SRID=-1;POINT(21 14)', NULL);
--- N15
- VALUES(1000000000015, 'SRID=-1;POINT(9 14)', NULL);
--- N16
- VALUES(1000000000016, 'SRID=-1;POINT(9 22)', NULL);
--- N17
- VALUES(1000000000017, 'SRID=-1;POINT(21 22)', NULL);
--- N18
- VALUES(1000000000018, 'SRID=-1;POINT(35 22)', NULL);
--- N19
- VALUES(1000000000019, 'SRID=-1;POINT(47 22)', NULL);
--- N20
- VALUES(1000000000020, 'SRID=-1;POINT(4 31)', NULL);
--- N21
- VALUES(1000000000021, 'SRID=-1;POINT(9 35)', NULL);
--- N22
- VALUES(1000000000022, 'SRID=-1;POINT(13 35)', NULL);
--- E1
- 'SRID=-1;LINESTRING(8 30, 16 30, 16 38, 3 38, 3 30, 8 30)');
--- E2
- 'SRID=-1;LINESTRING(25 30, 31 30, 31 40, 17 40, 17 30, 25 30)');
--- E3
- 'SRID=-1;LINESTRING(25 30, 25 35)');
--- E4
- 'SRID=-1;LINESTRING(36 38, 38 35, 41 34, 42 33, 45 32, 47 28, 50 28, 52 32, 57 33)');
--- E5
- 'SRID=-1;LINESTRING(41 40, 45 40, 47 42, 62 41, 61 38, 59 39, 57 36, 57 33)');
--- E6
- 'SRID=-1;LINESTRING(9 22, 21 22)');
--- E7
- 'SRID=-1;LINESTRING(21 22, 35 22)');
--- E8
- 'SRID=-1;LINESTRING(35 22, 47 22)');
--- E9
- 'SRID=-1;LINESTRING(9 14, 21 14)');
--- E10
- 'SRID=-1;LINESTRING(35 14, 21 14)');
--- E11
- 'SRID=-1;LINESTRING(35 14, 47 14)');
--- E12
- 'SRID=-1;LINESTRING(9 6, 21 6)');
--- E13
- 'SRID=-1;LINESTRING(21 6, 35 6)');
--- E14
- 'SRID=-1;LINESTRING(35 6, 47 6)');
--- E15
- 'SRID=-1;LINESTRING(47 14, 47 22)');
--- E16
- 'SRID=-1;LINESTRING(47 6, 47 14)');
--- E17
- 'SRID=-1;LINESTRING(35 14, 35 22)');
--- E18
- 'SRID=-1;LINESTRING(35 6, 35 14)');
--- E19
- 'SRID=-1;LINESTRING(21 14, 21 22)');
--- E20
- 'SRID=-1;LINESTRING(21 6, 21 14)');
--- E21
- 'SRID=-1;LINESTRING(9 14, 9 22)');
--- E22
- 'SRID=-1;LINESTRING(9 6, 9 14)');
--- E25
- 'SRID=-1;LINESTRING(9 35, 13 35)');
--- E26
- 'SRID=-1;LINESTRING(4 31, 7 31, 7 34, 4 34, 4 31)');
-UPDATE large_city_data.face set mbr = ST_SetSRID( ( select st_extent(geom) from large_city_data.edge where left_face = face_id or right_face = face_id ), -1 ) where face_id != 0;
-END;
Summary of changes:
.gitignore | 2 +
topology/test/load_large_topology-4326.sql | 204 -----------------------------
topology/test/load_large_topology.sql | 204 -----------------------------
3 files changed, 2 insertions(+), 408 deletions(-)
delete mode 100644 topology/test/load_large_topology-4326.sql
delete mode 100644 topology/test/load_large_topology.sql
hooks/post-receive
