[PostGIS] #5968: Remove generated files in distclean target
trac at osgeo.org
Mon Aug 18 21:45:36 PDT 2025
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: build | Version: master
Keywords: |
The Debian package failed to build twice in a row because generated files
were not removed in the clean target:
dpkg-source: info: local changes detected, the modified files are:
source_dir/raster/test/regress/tests.mk
The attached patch fixes the issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5968>
