[SCM] PostGIS branch master updated. 3.6.0rc1-22-g577574c8f
Wed Aug 20 20:59:21 PDT 2025
the project "PostGIS".
       via  577574c8f3998712b2297e5f7f8fa5b1bc43907f (commit)
      from  a2d0be448a4a505c0eb28a9ece8144adaa0a9945 (commit)
revisions in full, below.
commit 577574c8f3998712b2297e5f7f8fa5b1bc43907f
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Aug 20 23:56:10 2025 -0400
    Fix issue with building --without-topology
     - Closes #5969 for PostGIS 3.6.0
     - Have winnie regress test --without-topology
       References #5956
       This will prevent that failing winnie topology test
       and also server to test building --without-topology
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 44b64af18..08e1759c3 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -83,6 +83,7 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS
   --with-gui --with-gettext=no \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
   --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version \
+  --without-topology \
   ${EXTRA_CONFIGURE_ARGS}
diff --git a/utils/Makefile.in b/utils/Makefile.in
index db9f33186..329bbd3b1 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -71,6 +71,9 @@ $(top_builddir)/raster/rt_pg/uninstall_rtpostgis.sql:
 $(top_builddir)/raster/rt_pg/rtpostgis_upgrade.sql:
 	$(MAKE) -C ../raster/rt_pg rtpostgis_upgrade.sql
+$(top_builddir)/topology/topology_upgrade.sql:
+	$(MAKE) -C ../topology/ topology_upgrade.sql
 $(top_builddir)/topology/uninstall_topology.sql:
 	$(MAKE) -C ../topology/ uninstall_topology.sql
Summary of changes:
 ci/winnie/regress_postgis.sh | 1 +
 utils/Makefile.in            | 3 +++
 2 files changed, 4 insertions(+)
hooks/post-receive
