[PostGIS] #5956: winnie failing on topology regress
trac at osgeo.org
Wed Aug 20 20:59:26 PDT 2025
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: QA/buildbots | Version: master
Resolution: | Keywords:
Comment (by Regina Obe <lr@…>):
In [changeset:"577574c8f3998712b2297e5f7f8fa5b1bc43907f/git" 577574c/git]:
{{{#!CommitTicketReference repository="git"
revision="577574c8f3998712b2297e5f7f8fa5b1bc43907f"
Fix issue with building --without-topology
- Closes #5969 for PostGIS 3.6.0
- Have winnie regress test --without-topology
References #5956
This will prevent that failing winnie topology test
and also server to test building --without-topology
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5956#comment:9>
