[PostGIS] #5971: Error building from tar ball if building --without-topology and --without-raster (was: Error building from tar ball)
PostGIS trac at osgeo.org
Thu Aug 21 15:20:07 PDT 2025
raster
  Reporter:  robe            |      Owner:  robe
      Type:  defect          |     Status:  new
  Priority:  blocker         |  Milestone:  PostGIS 3.6.0
 Component:  tiger geocoder  |    Version:  master
Resolution:                  |   Keywords:
Changes (by robe):
 * summary:  Error building from tar ball =>
     --without-raster
Old description:
> MobilityDb folks after fix #5969 that they aren't getting that error
> anymore, but still getting
> ---- Making all in liblwgeom
> make[1]: Entering directory
> '/home/esteban/src/postgis-3.6.0rc1/liblwgeom'
> make[1]: Nothing to be done for 'all'.
> make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/liblwgeom'
> ---- Making all in deps
> make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/deps'
> make -C wagyu libwagyu.la
> make -C ryu libryu.la
> make -C flatgeobuf libflatgeobuf.la
> make[2]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/deps/ryu'
> make[2]: 'libryu.la' is up to date.
> make[2]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/deps/ryu'
> '/home/esteban/src/postgis-3.6.0rc1/deps/flatgeobuf'
> make[2]: 'libflatgeobuf.la' is up to date.
> '/home/esteban/src/postgis-3.6.0rc1/deps/wagyu'
> make[2]: 'libwagyu.la' is up to date.
> make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/deps'
> ---- Making all in libpgcommon
> '/home/esteban/src/postgis-3.6.0rc1/libpgcommon'
> ---- Making all in postgis
> make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/postgis'
> make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/postgis'
> ---- Making all in regress
> make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/regress'
> make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/regress'
> ---- Making all in doc
> make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/doc'
> make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/doc'
> ---- Making all in loader
> make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/loader'
> make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/loader'
> ---- Making all in utils
> make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/utils'
> make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/utils'
> ---- Making all in extensions
> '/home/esteban/src/postgis-3.6.0rc1/extensions'
> for DIR in postgis postgis_tiger_geocoder; do \
>         echo "---- Making all in ${DIR}"; \
>         make -C "${DIR}" all || exit 1; \
> done
> '/home/esteban/src/postgis-3.6.0rc1/extensions/postgis'
> make[2]: Nothing to be done for 'all'.
> ---- Making all in postgis_tiger_geocoder
> '/home/esteban/src/postgis-3.6.0rc1/extensions/postgis_tiger_geocoder'
> mkdir -p expected
> make[2]: *** No rule to make target
> '../../extras/tiger_geocoder/utility/utmzone.sql', needed by
> 'sql/tiger_geocoder.sql.in'.  Stop.
> make[2]: *** Waiting for unfinished jobs....
> make[1]: *** [Makefile:36: all] Error 1
> make: *** [GNUmakefile:36: all] Error 1
> esteban at P-ULB-PF59GXL3:~/src/postgis-3.6.0rc1$
> I have to investigate what the issue is here.  I think someone else was
> complaining about a sequencing issue so might be about that.
New description:
 I still need to try to replicate with tarball. I couldn't running from
 git.
 make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/liblwgeom'
 make[2]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/deps/wagyu'
 done
 mkdir -p expected
 make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/extensions'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5971#comment:2>
