[SCM] PostGIS branch master updated. 3.6.0rc1-31-g7c3829c39
git at osgeo.org
git at osgeo.org
Sun Aug 24 00:46:55 PDT 2025
the project "PostGIS".
via 7c3829c39ccf940302c52f44c9225da1ff750ed2 (commit)
via 93e9200a062eb7bc19024be0f58b7e47bb5544cf (commit)
via 3acef7da9c12e17496391b2fd8a10cb8dde0d052 (commit)
via ee15461766420913b0820f84b42299235a9994a7 (commit)
from 534dcbd601c826f13c4a8f6341c5d5ccd577be03 (commit)
revisions in full, below.
commit 7c3829c39ccf940302c52f44c9225da1ff750ed2
Author: Regina Obe <lr at pcorp.us>
Date: Sun Aug 24 03:30:13 2025 -0400
Prepping for RC2
diff --git a/NEWS b/NEWS
index 0cc68d6b5..be2c04e53 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,24 @@
+PostGIS 3.6.0rc2
+2025/08/xx
+This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
+To take advantage of all features, GEOS 3.14+ is needed.
+To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.
+Many thanks to our translation teams, in particular:
+Teramoto Ikuhiro (Japanese Team)
+Daniel Nylander (Swedish Team)
+Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
+Denys Kovshun (Ukrainian Team)
+CHANGES since PostGIS 3.6.0rc1
+ - Doc updates
+ - #5968, Remove raster generated files in distclean target (Bas Couwenberg)
+ - #5969, Fix issue when building --without-topology (Regina Obe)
+ - #5971, Option to build --without-tiger (Regina Obe)
PostGIS 3.6.0
2025/xx/xx
commit 93e9200a062eb7bc19024be0f58b7e47bb5544cf
Date: Sun Aug 24 03:29:42 2025 -0400
More cleanup of winnie scripts and ability to build with pcre2
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index f410e720e..20db15c43 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -48,10 +48,6 @@ git describe --long --all --tags # Report where we are at
sh autogen.sh
-if [ -n "$PCRE_VER" ]; then
- export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-fi
export LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib"
if [$INCLUDE_MINOR_LIB == "1"]; then
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 27fda2311..bb4f1fc4c 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -107,7 +107,7 @@ if [ "$POSTGIS_MAJOR_VERSION" > "1" ] ; then
cp -rp ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal $outdir/gdal-data
# needed for address standardizer
- cp -p ${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/bin/libpcre-1*.dll $outdir/bin
+ cp -p ${PCRE_PATH}/bin/*.dll $outdir/bin
fi;
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index b6d26ece7..10aa48c0e 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -101,24 +101,29 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS
make -j 4
make install
-make check RUNTESTFLAGS=-v
+# don't run tests twice. Only run regular if extension test is not asked for
+if [ "$MAKE_EXTENSION" == "" ]; then
+ make check RUNTESTFLAGS=-v
+fi
if [ "$MAKE_EXTENSION" == "1" ]; then
export PGUSER=postgres
#need to copy install files to EDB install (since not done by make install
cd ${POSTGIS_SRC}
echo "Postgis src dir is ${POSTGIS_SRC}"
- strip postgis/postgis-*.dll
- strip raster/rt_pg/postgis_raster-*.dll
- strip sfcgal/*.dll
+ #strip postgis/postgis-*.dll
+ #strip raster/rt_pg/postgis_raster-*.dll
+ #strip sfcgal/*.dll
- if [ $REGRESS_WITHOUT_TOPOLOGY == ""]; then
+ if [ $REGRESS_WITHOUT_TOPOLOGY == "" ]; then
cp -r topology/*.dll ${PGPATHEDB}/lib
fi
cp postgis/postgis*.dll ${PGPATHEDB}/lib
cp sfcgal/*.dll ${PGPATHEDB}/lib
- if [ $REGRESS_WITHOUT_RASTER == ""]; then
+ if [ $REGRESS_WITHOUT_RASTER == "" ]; then
cp raster/rt_pg/postgis_raster-*.dll ${PGPATHEDB}/lib
fi
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index b629ce201..e81b946f0 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -26,12 +26,25 @@ if [[ "${OVERRIDE}" == '' ]] ; then
export LZ4_VER=1.9.3
fi;
+if [[ ${PCRE_VER} == '' ]]; then
+ PCRE_VER=10.40
+fi;
export PROTOBUF_VER=3.2.0
export PROTOBUFC_VER=1.2.1
export JSON_VER=0.12
-export PCRE_VER=8.45
+if [ -d "${PROJECTS}/pcre2/rel-pcre2-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}" ]; then
+export PCRE_PATH=${PROJECTS}/pcre2/rel-pcre2-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}
+else
+export PCRE_PATH=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}
+fi
+echo "PCRE_PATH is $PCRE_PATH"
#export OS_BUILD=64
#export PGPORT=8442
@@ -123,7 +136,7 @@ export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/
export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PCRE_PATH}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
@@ -144,6 +157,11 @@ CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}
#add protobuf
export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+# add pcre for address_standardizer
+if [ -n "$PCRE_PATH" ]; then
+ export PATH="${PCRE_PATH}/include:${PCRE_PATH}/lib:${PATH}"
+fi
echo "PATH AFTER: $PATH"
if [[ "${INCLUDE_MINOR_LIB}" == '' ]] ; then
commit 3acef7da9c12e17496391b2fd8a10cb8dde0d052
Date: Sun Aug 24 02:35:57 2025 -0400
- Add configure option --without-tiger to disable postgis_tiger_geocoder extension suport
- Add to docs and remove no longer valid line about postgis_topology not having a lib file
Closes #5971
diff --git a/configure.ac b/configure.ac
index ac2d805c0..61ab6bbf2 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1488,6 +1488,23 @@ fi
AC_SUBST([ADDRESS_STANDARDIZER])
+dnl ====================================
+dnl tiger_geocoder stuff
+AC_ARG_WITH([tiger],
+ [AS_HELP_STRING([--without-tiger],
+ [Disable the tiger geocoder extension])],
+if test "x$with_tiger" != "xno"; then
+ TIGER="tiger"
+ AC_MSG_RESULT([TIGER: Tiger geocoder support requested])
+else
+ AC_MSG_RESULT([TIGER: Tiger geocoder support disabled])
+fi
+AC_SUBST([TIGER])
CPPFLAGS="$PGSQL_CPPFLAGS $GEOS_CPPFLAGS $PROJ_CPPFLAGS $PROTOBUF_CPPFLAGS $XML2_CPPFLAGS $SFCGAL_CPPFLAGS $JSON_CPPFLAGS $PCRE_CPPFLAGS $CPPFLAGS"
dnl AC_MSG_RESULT([CPPFLAGS: $CPPFLAGS])
@@ -1529,7 +1546,6 @@ fi
AC_SUBST([INTERRUPTTESTS])
dnl ===========================================================================
dnl SRID stuff
@@ -2028,6 +2044,12 @@ else
AC_MSG_RESULT([ Address Standardizer support: disabled])
fi
+if test "x$TIGER" = "xtiger"; then
+ AC_MSG_RESULT([ PostGIS Tiger Geocoder: enabled])
+else
+ AC_MSG_RESULT([ PostGIS Tiger Geocoder: disabled])
+fi
AC_MSG_RESULT()
AC_MSG_RESULT([ -------- Documentation Generation -------- ])
AC_MSG_RESULT([ xsltproc: ${XSLTPROC}])
diff --git a/doc/installation.xml b/doc/installation.xml
index 85bdfb3eb..e7ff09792 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -497,12 +497,19 @@ sh autogen.sh
</para>
</listitem>
</varlistentry>
+ <varlistentry>
+ <term><option>--without-tiger</option></term>
+ <listitem>
+ <para>
+ Disables tiger geocoder support.
+ </para>
+ </listitem>
+ </varlistentry>
<varlistentry>
<term><option>--without-topology</option></term>
<listitem>
<para>
- Disable topology support. There is no corresponding library
- as all logic needed for topology is in postgis-&last_release_version; library.
+ Compile without topology support.
</para>
</listitem>
</varlistentry>
diff --git a/extensions/Makefile.in b/extensions/Makefile.in
index 6510dd82a..32a4c50a5 100644
--- a/extensions/Makefile.in
+++ b/extensions/Makefile.in
@@ -17,7 +17,10 @@ VPATH := $(srcdir)
SCRIPTS_BUILT = postgis_extension_helper.sql
SUBDIRS = postgis
-SUBDIRS += postgis_tiger_geocoder
+ifeq (@TIGER@,tiger)
+ SUBDIRS += postgis_tiger_geocoder
+endif
ifeq (@RASTER@,raster)
SUBDIRS += postgis_raster
endif
commit ee15461766420913b0820f84b42299235a9994a7
Date: Sun Aug 24 02:09:10 2025 -0400
Logic for winnie to conditionally compile with raster and topology
index 08e1759c3..b6d26ece7 100644
@@ -68,6 +68,14 @@ if [ $INCLUDE_MINOR_LIB == "1" ]; then
EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --with-library-minor-version"
fi
+if [ $REGRESS_WITHOUT_TOPOLOGY == "1" ]; then
+ EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-topology"
+fi
+if [ $REGRESS_WITHOUT_RASTER == "1" ]; then
+ EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-raster"
+fi
#CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
#CFLAGS="-Wall -fno-omit-frame-pointer"
@@ -83,7 +91,6 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS
--with-gui --with-gettext=no \
--with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
--prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version \
- --without-topology \
@@ -104,10 +111,17 @@ if [ "$MAKE_EXTENSION" == "1" ]; then
strip sfcgal/*.dll
- cp topology/*.dll ${PGPATHEDB}/lib
+ if [ $REGRESS_WITHOUT_TOPOLOGY == ""]; then
+ cp -r topology/*.dll ${PGPATHEDB}/lib
+ fi
- cp raster/rt_pg/postgis_raster-*.dll ${PGPATHEDB}/lib
+ if [ $REGRESS_WITHOUT_RASTER == ""]; then
+ cp raster/rt_pg/postgis_raster-*.dll ${PGPATHEDB}/lib
+ fi
export POSTGIS_MINOR_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
export POSTGIS_MINOR_MAX_VER="ANY"
@@ -120,8 +134,20 @@ value=${value//UPGRADEABLE_VERSIONS = /}
#echo $value
export UPGRADEABLE_VERSIONS=$value
export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.2.0 2.2.3 2.3.0 2.3.7 2.4.0 2.4.4"
+export extensions_to_install="postgis postgis_sfcgal postgis_tiger_geocoder address_standardizer"
+if [ $REGRESS_WITHOUT_TOPOLOGY == "" ]; then
+ extensions_to_install="${extensions_to_install} postgis_topology"
+fi
+if [ $REGRESS_WITHOUT_RASTER == "" ]; then
+ extensions_to_install="${extensions_to_install} postgis_raster"
+fi
#echo "Versions are: $UPGRADEABLE_VERSIONS"
-for EXTNAME in postgis postgis_raster postgis_sfcgal postgis_tiger_geocoder address_standardizer postgis_topology; do
+for EXTNAME in $extensions_to_install; do
cp extensions/$EXTNAME/sql/* ${PGPATHEDB}/share/extension
cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql ${PGPATHEDB}/share/extension/$EXTNAME--$POSTGIS_MICRO_VER--${POSTGIS_MINOR_MAX_VER}.sql;
@@ -143,10 +169,10 @@ done
#cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
#cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}next.sql ${PGPATHEDB}/share/extension
#cp -r ${PGPATH}/share/extension/address_standardizer*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
- cp -r extensions/*/*.control ${PGPATHEDB}/share/extension
- cp -r extensions/*/*.dll ${PGPATHEDB}/lib
+cp -r extensions/*/*.control ${PGPATHEDB}/share/extension
+cp -r extensions/*/*.dll ${PGPATHEDB}/lib
- make check RUNTESTFLAGS="--extension -v"
+make check RUNTESTFLAGS="--extension -v"
if [ "$UPGRADE_TEST" == "1" ]; then
export CURRENTVERSION=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
Summary of changes:
NEWS | 21 ++++++++++++++++++
ci/winnie/build_postgis.sh | 4 ----
ci/winnie/package_postgis.sh | 2 +-
ci/winnie/regress_postgis.sh | 53 +++++++++++++++++++++++++++++++++++---------
ci/winnie/winnie_common.sh | 22 ++++++++++++++++--
configure.ac | 24 +++++++++++++++++++-
doc/installation.xml | 11 +++++++--
extensions/Makefile.in | 5 ++++-
8 files changed, 120 insertions(+), 22 deletions(-)
hooks/post-receive
