[PostGIS] #5971: Option to build --without-tiger
trac at osgeo.org
Sun Aug 24 00:46:57 PDT 2025
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.6.0
Component: tiger geocoder | Version: master
Resolution: fixed | Keywords:
Changes (by Regina Obe <lr@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"3acef7da9c12e17496391b2fd8a10cb8dde0d052/git" 3acef7d/git]:
{{{#!CommitTicketReference repository="git"
revision="3acef7da9c12e17496391b2fd8a10cb8dde0d052"
- Add configure option --without-tiger to disable postgis_tiger_geocoder
extension suport
- Add to docs and remove no longer valid line about postgis_topology not
having a lib file
Closes #5971
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5971#comment:5>
