[PostGIS] #5974: Add matching finishGEOS() to all initGEOS()
trac at osgeo.org
Sun Aug 24 06:01:16 PDT 2025
Reporter: ezimanyi | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: postgis | Version: 3.5.x
Keywords: |
To avoid memory leaks when using GEOS without PostgreSQL, it is necessary
to add matching finishGEOS() with all calls to initGEOS(). In the current
source code of 3.6.0rc1 there are 5 occurrences of finishGEOS() in the
directory cunit while there are 78 occurrences of initGEOS().
The following PR
https://github.com/MobilityDB/postgis/commit/923c304394755ea31392970aaf38ea1d4d934d86
aims at ensuring that every time initGEOS() is called, a matching
finishGEOS() is always performed, whether there is a potential error
(i.e., in GEOS_FREE_AND_FAIL) or not (i.e., before the return of the
function where initGEOS() was called).
This PR is a first attempt toward this. Please notice that this was done
blindly, without building PostGIS, just to see how the code would look
like.
The PR only modified the files in the directories liblwgeom and raster, it
didn't modify the files in the postgis directory because this is not
formally needed for PostgreSQL.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5974>
