[PostGIS] #5977: WARNING: nonstandard use of escape in a string literal
PostGIS trac at osgeo.org
Mon Aug 25 09:30:19 PDT 2025
  Reporter:  strk          |      Owner:  strk
      Type:  defect        |     Status:  new
  Priority:  medium        |  Milestone:  PostGIS 3.6.0
 Component:  upgrade/soft  |    Version:  master
Resolution:                |   Keywords:
Comment (by strk):
 I've pushed a branch 5977-standard-conforming-strings-in-upgrade to have
 bots check it.
 There seem to be only woodie setting `standard_conforming_strings = off`
 during upgrade, and indeed it's where we see the problem
 > .woodpecker/regress.yml:      --after-create-db-script
 $${CI_WORKSPACE}/regress/hooks/standard-conforming-strings-off.sql"
 I guess it only affects the downgrade protection and NONE of our CI is
 testing for downgrade protection
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5977#comment:1>
