[SCM] PostGIS branch master updated. 3.6.0rc2-5-gb451f94e0
git at osgeo.org
git at osgeo.org
Mon Aug 25 12:48:02 PDT 2025
the project "PostGIS".
via b451f94e08f0e740e5ef4b972f12cd47c2f9e932 (commit)
from 1de8c0571fcfa34ef1c8a474d2aa1c16fc89fa3a (commit)
revisions in full, below.
commit b451f94e08f0e740e5ef4b972f12cd47c2f9e932
Author: Daniel Nylander <daniel at danielnylander.se>
Date: Mon Aug 25 18:31:14 2025 +0000
Translated PostGIS Manual using Weblate (Swedish)
Currently translated at 100.0% (5857 of 5857 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/sv/
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index 8f9b908a7..43b79e458 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -5,10 +5,10 @@ msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-08-21 03:28+0000\n"
-"PO-Revision-Date: 2025-07-20 08:47+0000\n"
+"PO-Revision-Date: 2025-08-25 19:47+0000\n"
"Last-Translator: Daniel Nylander <daniel at danielnylander.se>\n"
-"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/sv/>\n"
+"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/sv/>\n"
"Language: sv\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
@@ -8756,12 +8756,12 @@ msgstr "Kompilera utan stöd för raster."
#. Tag: para
#, no-c-format
msgid "Disables tiger geocoder support."
-msgstr ""
+msgstr "Inaktiverar stöd för tiger geocoder."
#. Tag: para
#, no-c-format
msgid "Compile without topology support."
-msgstr ""
+msgstr "Kompilera utan topologistöd."
#. Tag: para
#, no-c-format
@@ -10574,7 +10574,7 @@ msgstr "David Techer"
#. Tag: member
#, no-c-format
msgid "Denys Kovshun"
-msgstr ""
+msgstr "Denys Kovshun"
#. Tag: member
#, no-c-format
@@ -37917,7 +37917,7 @@ msgstr ""
msgid ""
"Calculates the fraction of each raster cell that is covered by a given "
"geometry."
-msgstr ""
+msgstr "Beräknar den del av varje rastercell som täcks av en given geometri."
#. Tag: para
#, no-c-format
@@ -37931,11 +37931,19 @@ msgid ""
"that is covered by the geometry. For linestrings, the value returned for "
"each cell is the length contained in the cell."
msgstr ""
+"Beräknar den del av varje rastercell som täcks av en given geometri. Det "
+"första argumentet är en raster som definierar rutnätets geometri som ska "
+"användas för beräkningen. Omfattningen och cellstorleken läses från "
+"rasterparametern. Det andra argumentet är en geometri som läggs över "
+"rutnätet, och varje rutnät fylls i baserat på överlagringen av geometrin på "
+"rutnätet. För polygoner är det värde som returneras för varje cell andelen "
+"av dess area som täcks av geometrin. För linjesträngar är det värde som "
+"returneras för varje cell längden som ingår i cellen."
#. Tag: para
#, no-c-format
msgid "Availability: 3.6.0 Requires GEOS 3.14 or higher."
-msgstr ""
+msgstr "Tillgänglighet: 3.6.0 Kräver GEOS 3.14 eller högre."
#. Tag: title
#, no-c-format
@@ -45001,12 +45009,12 @@ msgstr "Anteckningar för release"
#. Tag: title
#, no-c-format
msgid "PostGIS 3.6.0rc2"
-msgstr ""
+msgstr "PostGIS 3.6.0rc2"
#. Tag: para
#, no-c-format
msgid "2025/08/25"
-msgstr ""
+msgstr "2025-08-25"
#. Tag: para
#, no-c-format
@@ -45015,6 +45023,9 @@ msgid ""
"6.1+. To take advantage of all features, GEOS 3.14+ is needed. To take "
"advantage of all SFCGAL features, SFCGAL 2.2+ is needed."
msgstr ""
+"Denna version kräver PostgreSQL 12-18beta3, GEOS 3.8 eller högre och Proj 6."
+"1+. För att kunna utnyttja alla funktioner krävs GEOS 3.14+. För att kunna "
+"utnyttja alla SFCGAL-funktioner krävs SFCGAL 2.2+."
#. Tag: para
#, no-c-format
@@ -45039,7 +45050,7 @@ msgstr "Dapeng Wang, Zuo Chenwei från HighGo (kinesiska teamet)"
#. Tag: para
#, no-c-format
msgid "Denys Kovshun (Ukrainian Team)"
-msgstr ""
+msgstr "Denys Kovshun (Ukrainska teamet)"
#. Tag: title
#, no-c-format
@@ -45115,6 +45126,12 @@ msgid ""
"extension@ for PG >= 16 to schema qualify dependent extensions, switch to "
"use typmod for tiger tables (Regina Obe)"
msgstr ""
+"<link xlink:href=”https://trac.osgeo.org/postgis/ticket/5359”>#5359</link>, "
+"<link xlink:href=”https://trac.osgeo.org/postgis/ticket/5897”>#5897</link>, "
+"<link xlink:href=”https://git.osgeo.org/gitea/postgis/postgis/pulls/"
+"260”>GT-260</link> [tiger_geocoder] Använd @extschema:extension@ för PG >"
+"= 16 för att schema-kvalificera beroende tillägg, byt till typmod för tiger-"
+"tabeller (Regina Obe)"
#. Tag: title
#, no-c-format
@@ -45128,6 +45145,10 @@ msgid ""
"Drop st_approxquantile(raster, double precision), wasn't usable as it "
"triggered is not unique error when used (Regina Obe)"
msgstr ""
+"<link xlink:href=”https://trac.osgeo.org/postgis/ticket/5498”>#5498</link> "
+"Ta bort st_approxquantile(raster, double precision), kunde inte användas "
+"eftersom det utlöste ett felmeddelande om att det inte var unikt när det "
+"användes (Regina Obe)"
#. Tag: title
#, no-c-format
@@ -45275,6 +45296,8 @@ msgstr ""
msgid ""
"[raster] Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)"
msgstr ""
+"[raster] Lägg till ST_ReclassExact för att snabbt ommappa värden i raster ("
+"Paul Ramsey)"
#. Tag: title
#, no-c-format
Summary of changes:
doc/po/sv/postgis-manual.po | 45 ++++++++++++++++++++++++++++++++++-----------
1 file changed, 34 insertions(+), 11 deletions(-)
hooks/post-receive
