[SCM] PostGIS branch master updated. 3.6.0rc2-14-g7609db888
Wed Aug 27 03:34:29 PDT 2025
the project "PostGIS".
       via  7609db888c9615e3d8a8d4ab93a6a3276dedc05a (commit)
      from  74a2b2fd328dd5e436a63a21172e1add8d36954d (commit)
revisions in full, below.
commit 7609db888c9615e3d8a8d4ab93a6a3276dedc05a
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 27 12:33:09 2025 +0200
    Make sure "make check" is unbuffered during upgrade checks
    Fixes some cases of unexpected content in log file
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 04471616d..db3ba0424 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -178,7 +178,7 @@ compatible_upgrade()
 check_downgrade()
   RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
-  ${MAKE} -C ${REGDIR} check "TESTS=${SRCDIR}/regress/core/regress.sql" ${MAKE_ARGS} > ${TMPDIR}/log 2>&1
+  unbuffer ${MAKE} -C ${REGDIR} check "TESTS=${SRCDIR}/regress/core/regress.sql" ${MAKE_ARGS} > ${TMPDIR}/log 2>&1
   if test $? = 0; then
     echo "FAIL: ${test_label} did not error out:"
     tail ${TMPDIR}/log
Summary of changes:
 utils/check_all_upgrades.sh | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
