[PostGIS] #5977: WARNING: nonstandard use of escape in a string literal
trac at osgeo.org
Wed Aug 27 03:50:19 PDT 2025
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.3.9
Component: upgrade/soft | Version: 3.3.x
Resolution: fixed | Keywords:
Changes (by strk):
* resolution: => fixed
* status: new => closed
Comment:
I'm going to close this out as it's not really easy to have a downgrade
path for 3.0 as the PostGIS version which started installing the ANY paths
requires a PostgreSQL version which is not supported by older PostGIS
versions...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5977#comment:14>
