[SCM] PostGIS branch master updated. 3.6.0rc2-241-gab560b38d
git at osgeo.org
git at osgeo.org
Tue Dec 2 03:47:53 PST 2025
the project "PostGIS".
via ab560b38d7cee7e4ca569f32a55b73e52563f789 (commit)
from 6fea7a21681c0c4d488fe071cba776babdbf37f1 (commit)
revisions in full, below.
commit ab560b38d7cee7e4ca569f32a55b73e52563f789
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date: Tue Dec 2 09:49:48 2025 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 98.9% (5832 of 5893 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index ea7d5b6e0..2e273283b 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2025-12-01 10:47+0000\n"
+"PO-Revision-Date: 2025-12-02 11:47+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/ja/>\n"
@@ -27696,19 +27696,19 @@ msgid "This function strips the M dimension."
msgstr "この関数はM値を取り除きます。"
#. Tag: title
-#, no-c-format
+#, fuzzy, no-c-format
msgid "Cardinality 2"
-msgstr ""
+msgstr "次数2"
#. Tag: para
-#, no-c-format
msgid "Nodes with cardinality 2 are merged away."
-msgstr ""
+msgstr "次数2のノードはマージされます。"
#. Tag: title
-#, no-c-format
msgid "Cardinality 3 or More"
-msgstr ""
+msgstr "次数3以上"
#. Tag: para
#, no-c-format
@@ -32851,6 +32851,13 @@ msgid ""
"and set it to <varname>libproj.dll</varname>. You'll have to restart your "
"PostgreSQL service/daemon after this change."
msgstr ""
+"変換しようとしてうまくいかない場合には、環境変数PROJSOを使用しているPostGISの"
+"ビルドが使用している投影ライブラリに設定する必要があるかも知れません。ファイ"
+"ル名を指定します。Windowsではコントロールパネル -> システム -> "
+"システムの詳細設定 -> 詳細設定タブ -> 環境変数 で "
+"<varname>PROJSO</varname>というシステム変数を追加して<varname>libproj.dll</va"
+"rname>へのパスを指定します。変更後はPostgreSQLサービス/デーモンを再起動する必"
+"要があります。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 21 ++++++++++++++-------
1 file changed, 14 insertions(+), 7 deletions(-)
hooks/post-receive
