[PostGIS] #6026: Distance operator <-> returns "tuple order" error
PostGIS trac at osgeo.org
Wed Dec 10 04:32:30 PST 2025
  Reporter:  dirc     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:
 Component:  postgis  |    Version:  3.5.x
Resolution:           |   Keywords:  distance, operator, tuple, order
Description changed by dirc:
Old description:
> Since Postgis v3.5 the distance operator sometimes returns:
> "ERROR:  index returned tuples in wrong order"
> In Postgis v3.4 we do not get this error.
> The issue can be reproduced with this small table of 5 rows contain a
> Polygon. The table index. We want to order the Polygons by distance to a
> given Point.
> For some Points it returns the above error.
> I have added two points, one that works and one with the error.
> Reproduce:
> {{{#!sql
> CREATE TABLE reproduce (
>     id SERIAL PRIMARY KEY,
>     geometry GEOMETRY(POLYGON, 28992)
> INSERT INTO reproduce (geometry) VALUES
>     (ST_GeomFromText('POLYGON ((133894.531 490000, 132700 490000, 132460
> 490000, 131703.958 489011.71, 131695 489000, 132880 489000, 132880
> 488416.725, 133206.605 488583.011, 134029.81 489022.36, 133917.695
> 490000, 133894.531 490000))', 28992)),
>     (ST_GeomFromText('POLYGON ((138000 492000, 141276.49 492000, 141050
> 492550, 140967.11 492751.305, 139951.651 495217.42, 139490.072 495217.42,
> 136358.892 495217.42, 135900 495217.42, 135301.1 495217.42, 135118.887
> 495296.573, 135115.873 495264.338, 135106.301 495164.456, 135098.485
> 495065.802, 135090.476 494967.014, 135085.764 494917.296, 135078.439
> 494866.459, 135070.381 494817.483, 135060.353 494767.172, 135036.351
> 494674.319, 135017.779 494615.505, 134991.438 494544.049, 134972.66
> 494501.055, 134948.148 494446.666, 134922.544 494398.914, 134872.859
> 494311.273, 134859.929 494292.444, 134843.402 494264.587, 134815.107
> 494200.454, 134770.855 494120.756, 134728.422 494053.048, 134932.74
> 493923.77, 133708.3 491825.92, 133917.695 490000, 134029.81 489022.36,
> 138000 492000))', 28992)),
>     (ST_GeomFromText('POLYGON ((131215.201 487105.005, 134029.81
> 486992.15, 134029.81 489022.36, 133206.605 488583.011, 132880 488416.725,
> 132198.685 488069.845, 131375.721 487651.916, 131199.012 487560.733,
> 131198.76 487560.603, 131215.201 487105.005))', 28992)),
>     (ST_GeomFromText('POLYGON ((134029.81 489022.36, 136889.1 488581.7,
> 138000 492000, 134029.81 489022.36))', 28992)),
>     (ST_GeomFromText('POLYGON ((133917.695 490000, 133708.3 491825.92,
> 133541.312 491951.805, 133460 491840, 132820 491000, 132210 490190,
> 132460 490000, 132700 490000, 133894.531 490000, 133917.695 490000))',
> 28992));
> --- create index
> CREATE INDEX idx_reproduce_geometry
> ON reproduce USING GIST(geometry);
> --- Query without error, that uses the index
> SET enable_seqscan = OFF; --- Disable the use of Quicksort algoritm, to
> ensure the index is used.
> explain analyse
> SELECT id
> FROM reproduce
> ORDER BY geometry <-> ST_SetSRID(ST_MakePoint(133000, 489000), 28992)
> LIMIT 4;
> --- Reproduce error
> explain analyse
> SELECT id
> FROM reproduce
> ORDER BY geometry <-> ST_SetSRID(ST_MakePoint(133718, 489222), 28992)
> LIMIT 4;
> To be complete, here is the postgis we use in production:
> SELECT version();
> SELECT postgis_full_version();
> POSTGIS="3.5.2 0" [EXTENSION] PGSQL="160" GEOS="3.13.0-CAPI-1.19.0"
> PROJ="9.0.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
> (compiled against PROJ 9.0.1) LIBXML="2.10.4" LIBJSON="0.15"
> LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
> I reproduced it on different postgis version using postgis docker images:
> postgis/postgis:16-3.4 -> no errors
> postgis/postgis:16-3.5 -> gives error
> postgis/postgis:18-3.6 -> gives error
> TAG=16-3.4
> PORT=${TAG//[^0-9]/}
> docker run --rm -d --name postgis-$TAG -e POSTGRES_PASSWORD=postgres -p
> $PORT:5432  postgis/postgis:$TAG
> psql -h localhost -p $PORT -U postgres -W postgres
> #pwd: postgres
New description:
 The issue can be reproduced with this small table of 5 rows together with
 an index as shown below. We want to order the Polygons by distance to a
 given Point.
 Reproduce:
 {{{#!sql
 488416.725, 133206.605 488583.011, 134029.81 489022.36, 133917.695 490000,
 133541.312 491951.805, 133460 491840, 132820 491000, 132210 490190, 132460
 490000, 132700 490000, 133894.531 490000, 133917.695 490000))', 28992));
 --- create index
 explain analyse
 SELECT id
 FROM reproduce
 LIMIT 4;
 --- Reproduce error
 explain analyse
 SELECT id
 FROM reproduce
 LIMIT 4;
 SELECT version();
 TAG=16-3.4
 #pwd: postgres
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6026#comment:1>
