[PostGIS] #6028: Mis-shapen Empty Polygon Crashes Backend
trac at osgeo.org
Mon Dec 15 09:07:01 PST 2025
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone:
Component: postgis | Version: 3.2.x
Resolution: | Keywords:
Description changed by pramsey:
Old description:
> From the mailing list
> drop table if exists fault;
> create table fault (fid integer, geom geometry(Polygon,5015));
> CREATE INDEX fault_geom_index ON fault USING GIST (geom);
> INSERT INTO fault (fid, geom) VALUES (1,
> '0103000020971300000100000000000000'::GEOMETRY);
> The polygon in the WKB is a polygon with one ring, which has zero points.
> This is legal WKB, but not really distinct from an empty polygon
> represented with zero rings, from a spatial logic point of view. It still
> covers no space and is a polygon.
> When parsing this input WKB, it makes sense to just convert the input
> into a standard empty polygon.
New description:
When parsing this input WKB, it makes sense to just convert the input into
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6028#comment:1>
