[PostGIS] #6028: Mis-shapen Empty Polygon Crashes Backend
trac at osgeo.org
Mon Dec 15 15:14:49 PST 2025
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone:
Component: postgis | Version: 3.2.x
Resolution: | Keywords:
Comment (by Paul Ramsey <pramsey@…>):
In [changeset:"119f8390a9c775ce97af2cab93643af7e3133994/git" 119f839/git]:
{{{#!CommitTicketReference repository="git"
revision="119f8390a9c775ce97af2cab93643af7e3133994"
Convert POLYGON(EMPTY) a polygon with an empty ring into
POLYGON EMPTY a polygon with no rings, in the WKB input
routine. Handle any existing POLYGON(EMPTY) in the
gserialized_is_empty routine. References #6028
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6028#comment:4>
