[PostGIS] #6029: sfcgal-master branch failing garden test CG_ForceLHR
trac at osgeo.org
Mon Dec 15 21:14:39 PST 2025
Reporter: robe | Owner: Loïc Bartoletti
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS SFCGAL
Component: sfcgal | Version: master
Keywords: |
This crashes
SELECT CG_ForceLHR(ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1, 1 1, 2 4, 7
7, 9 9)), EMPTY)', 4326))
Trace from GHA:
https://github.com/Snowflake-
Labs/postgis/actions/runs/20250727656/job/58141922950#step:4:1409
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/local/pgsql/bin/postgres '''.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007f699894f519 in CGAL::Sign
CGAL::Polygon::internal::orientation_2_no_precondition<__gnu_cxx::__normal_iterator<CGAL::Point_2<CGAL::Epeck>
const*, std::vector<CGAL::Point_2<CGAL::Epeck>,
std::allocator<CGAL::Point_2<CGAL::Epeck> > > >,
CGAL::Epeck>(__gnu_cxx::__normal_iterator<CGAL::Point_2<CGAL::Epeck>
__gnu_cxx::__normal_iterator<CGAL::Point_2<CGAL::Epeck> const*,
std::allocator<CGAL::Point_2<CGAL::Epeck> > > >, CGAL::Epeck const&)
[clone .isra.0] () from /usr/local/lib/libSFCGAL.so.2
Thread 1 (Thread 0x7f69a4f50780 (LWP 11120)):
I just compiled in windows against sfcgal-master and had same error:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6029>
