[SCM] PostGIS branch master updated. 3.6.0rc2-264-ga12775a18
git at osgeo.org
git at osgeo.org
Mon Dec 22 04:56:57 PST 2025
the project "PostGIS".
via a12775a18c6d89c1c825795c51df6fb80d9bcc8b (commit)
from e936c74a8139d68beb081c2c55c131e8aa6d16e8 (commit)
revisions in full, below.
commit a12775a18c6d89c1c825795c51df6fb80d9bcc8b
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Dec 22 13:42:26 2025 +0100
Fix RemoveUnusedPrimitives without "topology" in search_path
Includes regression test.
References #6027 in master branch (3.7.0dev)
diff --git a/topology/sql/cleanup/RemoveUnusedPrimitives.sql.in b/topology/sql/cleanup/RemoveUnusedPrimitives.sql.in
index 8c3f497ad..288655a5b 100644
--- a/topology/sql/cleanup/RemoveUnusedPrimitives.sql.in
+++ b/topology/sql/cleanup/RemoveUnusedPrimitives.sql.in
@@ -41,7 +41,7 @@ DECLARE
moreMergedFaces BIGINT[];
BEGIN
- topo := findTopology(atopology);
+ topo := topology.findTopology(atopology);
IF topo.id IS NULL THEN
RAISE EXCEPTION 'Could not find topology "%"', atopology;
END IF;
diff --git a/topology/test/regress/removeunusedprimitives.sql b/topology/test/regress/removeunusedprimitives.sql
index 1abb4953e..23817d0c6 100644
--- a/topology/test/regress/removeunusedprimitives.sql
+++ b/topology/test/regress/removeunusedprimitives.sql
@@ -1,4 +1,5 @@
set client_min_messages to WARNING;
+set search_path to public,pg_catalog;
\i :top_builddir/topology/test/load_topology.sql
\i ../load_features.sql
@@ -74,7 +75,7 @@ WITH deleted AS (
DELETE FROM features.city_streets WHERE feature_name IN ( 'R1' )
RETURNING feature
), clear AS (
- SELECT clearTopoGeom(feature) FROM deleted
+ SELECT topology.clearTopoGeom(feature) FROM deleted
) SELECT NULL FROM clear;
--set client_min_messages to DEBUG;
@@ -88,7 +89,7 @@ WITH deleted AS (
DELETE FROM features.traffic_signs WHERE feature_name IN ( 'S3' )
RETURNING feature
), clear AS (
@@ -102,7 +103,7 @@ WITH deleted AS (
DELETE FROM features.traffic_signs WHERE feature_name IN ( 'S4' )
RETURNING feature
), clear AS (
@@ -124,16 +125,16 @@ start_point AS (
FROM deleted
clear AS (
- SELECT sp, clearTopoGeom(feature)
+ SELECT sp, topology.clearTopoGeom(feature)
FROM start_point
INSERT INTO features.traffic_signs ( feature_name, feature )
SELECT
'TS1',
- toTopoGeom(
+ topology.toTopoGeom(
sp,
'city_data',
- layer_id(findLayer('features', 'traffic_signs', 'feature')),
+ layer_id(topology.findLayer('features', 'traffic_signs', 'feature')),
0
FROM clear;
@@ -174,12 +175,12 @@ WITH node AS (
FROM features.traffic_signs WHERE feature_name = 'S1'
triangle_right AS (
- SELECT TopoGeo_addLineString( 'city_data',
+ SELECT topology.TopoGeo_addLineString( 'city_data',
features.triangle(g, 4, 4)
) FROM node
triangle_left AS (
features.triangle(g, -4, 4)
) FROM node
@@ -194,7 +195,7 @@ WITH deleted AS (
RETURNING feature
clear AS (
FROM deleted
@@ -207,7 +208,7 @@ SELECT 't6', 'invalidity', * FROM topology.ValidateTopology('city_data');
-- See https://trac.osgeo.org/postgis/ticket/5289
SELECT NULL FROM (
- SELECT toTopoGeom(
+ SELECT topology.toTopoGeom(
ST_MakeLine(
ST_EndPoint( ST_GeometryN(feature,1) ),
ST_StartPoint( ST_GeometryN(feature,1) )
@@ -230,7 +231,7 @@ SELECT '#5289', 'invalidity', * FROM topology.ValidateTopology('city_data');
-- being required as endpoint of closed edge 2) while
-- edges themselves would still be both used by R4 feature.
UPDATE features.city_streets
-SET feature = TopoGeom_addElement(feature, ARRAY[2, 2])
+SET feature = topology.TopoGeom_addElement(feature, ARRAY[2, 2])
WHERE feature_name = 'R4';
UPDATE features.city_streets SET geom = feature::geometry
@@ -243,6 +244,6 @@ SELECT '#5303', 'invalidity', * FROM topology.ValidateTopology('city_data');
-- Cleanup
-SELECT NULL FROM DropTopology('city_data');
+SELECT NULL FROM topology.DropTopology('city_data');
DROP SCHEMA features CASCADE;
+RESET search_path;
Summary of changes:
topology/sql/cleanup/RemoveUnusedPrimitives.sql.in | 2 +-
topology/test/regress/removeunusedprimitives.sql | 27 +++++++++++-----------
2 files changed, 15 insertions(+), 14 deletions(-)
hooks/post-receive
