[SCM] PostGIS branch stable-3.6 updated. 3.6.1-9-gf71e8d8a6
git at osgeo.org
git at osgeo.org
Mon Dec 22 05:05:25 PST 2025
the project "PostGIS".
The branch, stable-3.6 has been updated
via f71e8d8a682cfaf72330ae70bdc24c1e1bbd7802 (commit)
from e66e98318c84c325d7d327dccaa0695dc777439a (commit)
revisions in full, below.
commit f71e8d8a682cfaf72330ae70bdc24c1e1bbd7802
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Dec 22 14:05:10 2025 +0100
Fix some spelling typos
diff --git a/NEWS b/NEWS
index 222a49a9e..7fde115d8 100644
--- a/NEWS
+++ b/NEWS
@@ -228,7 +228,7 @@ PostGIS 3.4.0
This version requires PostgreSQL 12-16, GEOS 3.6 or higher, and Proj 6.1+.
To take advantage of all features, GEOS 3.12+ is needed.
-To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
+To take advantage of all SFCGAL features, SFCGAL 1.4.1+ is needed.
Many thanks to our translation teams, in particular:
@@ -414,7 +414,7 @@ with the new fast index build that requires PG14,
we have decided to disable the feature by default
until we get more user testing
as to the true impact of real-world queries.
-If you are running PG14+, you can reenable it by doing
+If you are running PG14+, you can re-enable it by doing
ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
ADD FUNCTION 11 (geometry)
@@ -559,7 +559,7 @@ Additional features are enabled if you are running GEOS 3.9.
- #4710, ST_ClusterKMeans now works with 3D geometries (Darafei Praliaskouski)
- #4801, ST_ClusterKMeans supports weights in POINT[Z]M geometries
- - #4805, _ST_SortableHash exposed to work around parallel soring performance issue
+ - #4805, _ST_SortableHash exposed to work around parallel sorting performance issue
in Postgres. If your table is huge, use ORDER BY _ST_SortableHash(geom)
instead of ORDER BY geom to make parallel sort faster (Darafei Praliaskouski)
- #4625, Correlation statistics now calculated.
@@ -571,7 +571,7 @@ Additional features are enabled if you are running GEOS 3.9.
- #4789, Sped up TopoJSON output for areal TopoGeometry with
many holes (Sandro Santilli)
- #4758, Improved topology noding robustness (Sandro Santilli)
- - Make ST_Subdivide interruptable (Sandro Santilli)
+ - Make ST_Subdivide interruptible (Sandro Santilli)
- #4660, Changes in double / coordinate printing (Raúl Marín)
- Use the shortest representation (enough to guarantee roundtrip).
- Uses scientific notation for absolute numbers smaller than 1e-8.
@@ -634,7 +634,7 @@ and GEOS 3.8.0
and postgis.backend switch (Darafei Praliaskouski)
- #4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)
- #4268, Bump minimum SFCGAL version to 1.3.1 (Darafei Praliaskouski)
- - #4331, ST_3DMakeBox now returns error instead of a miniscule box (Regina Obe)
+ - #4331, ST_3DMakeBox now returns error instead of a minuscule box (Regina Obe)
- #4342, Removed "versioned" variants of ST_AsGeoJSON and ST_AsKML (Paul Ramsey)
- #4356, ST_Accum removed. Use array_agg instead. (Darafei Praliaskouski)
- #4414, Include version number in address_standardizer lib (Raúl Marín)
@@ -1524,7 +1524,7 @@ PostGIS 2.1.0
- #2026, ST_Union(raster) now unions all bands of all rasters
- #2089, liblwgeom: lwgeom_set_handlers replaces lwgeom_init_allocators.
- #2150, regular_blocking is no longer a constraint. column of same name
- in raster_columns now checks for existance of spatially_unique
+ in raster_columns now checks for existence of spatially_unique
and coverage_tile constraints
- ST_Intersects(raster, geometry) behaves in the same manner as
ST_Intersects(geometry, raster).
@@ -1610,8 +1610,8 @@ PostGIS 2.1.0
- #2302, ST_Roughness for raster (Nathaniel Clay)
- #2290, ST_ColorMap(raster) to generate RGBA bands
- #2254, Add SFCGAL backend support.
- (Backend selection throught postgis.backend var)
- Functions available both throught GEOS or SFCGAL:
+ (Backend selection through postgis.backend var)
+ Functions available both through GEOS or SFCGAL:
ST_Intersects, ST_3DIntersects, ST_Intersection, ST_Area,
ST_Distance, ST_3DDistance
New functions available only with SFCGAL backend:
@@ -1953,7 +1953,7 @@ PostGIS 2.0.0
(eg CREATE TABLE t (g GEOMETRY(Polgyon, 4326)))
- ST_AsBinary and ST_AsText now return 3D/4D results in ISO SQL/MM
format when called on 3D/4D features.
- - The "unknonwn SRID" is now 0, not -1.
+ - The "unknown SRID" is now 0, not -1.
(eg ST_SRID(ST_GeomFromText('POINT(0 0)')) returns 0)
- ST_NumGeometries returns 1 for singletons. ST_GeometryN returns the
the geometry for singletons.
@@ -2386,7 +2386,7 @@ PostGIS 1.3.1
PostGIS 1.3.0
2007/08/09
- - Began migration of functions to the SQL-MM-centric naming convension
+ - Began migration of functions to the SQL-MM-centric naming convention
using the spatial type (SP) prefix
- Performance enhancements:
- Created cached and indexed point-in-polygon short-circuits
@@ -2495,7 +2495,7 @@ PostGIS 1.1.3
PostGIS 1.1.2
2006/03/30
- - Regress tests can now be run *before* postgis intallation
+ - Regress tests can now be run *before* postgis installation
- BUGFIX in SnapToGrid() computation of output bounding box
- More portable ./configure script
- Changed ./run_test script to have more sane default behaviour
@@ -2545,7 +2545,7 @@ PostGIS 1.1.0
- Bug fixes:
- Fixed memory leak in polygonize()
- - Fixed bug in lwgeom_as_anytype cast funcions
+ - Fixed bug in lwgeom_as_anytype cast functions
- Fixed USE_GEOS, USE_PROJ and USE_STATS elements
of postgis_version() output to always reflect
library state.
@@ -2555,7 +2555,7 @@ PostGIS 1.1.0
- Changed Z() function to return NULL if requested
dimension is not available
- - Peformance improvements:
+ - Performance improvements:
- Much faster transform() function, caching proj4 objects
- Removed automatic call to fix_geometry_columns() in
AddGeometryColumns() and update_geometry_stats()
@@ -2675,7 +2675,7 @@ PostGIS 1.0.0
- NEW -p flag for shp2pgsql
- BUGFIX in transform() releasing random memory address
- BUGFIX in force_3dm() allocating less memory then required
- - NEW chapter about OGC compliancy enforcement
+ - NEW chapter about OGC compliance enforcement
- BUGFIX in shp2pgsql escape of values starting with "'" or "\t"
- NEW autoconf support for JTS lib
- BUGFIX in estimator testers (support for LWGEOM and schema parsing)
@@ -2704,7 +2704,7 @@ PostGIS 1.0.0RC4
- jdbc2: code cleanups, Makefile improvements
- FLEX & YACC variables set *after* pgsql Makefile.global
is included and only if the pgsql *stripped* version
- evaulates to the empty string
+ evaluates to the empty string
- added already generated parser in release
- build scripts refinements
- MultiLine handling BUG fix in loader and dumper
@@ -2774,10 +2774,10 @@ PostGIS 1.0.0RC1
- Objects are all now "lightweight" with a smaller disk
and index representation. Large databases should see a moderate
to large performance increase.
- - Objects now have a hexidecimal canonical representation.
+ - Objects now have a hexadecimal canonical representation.
To see a "user friendly" version of the objects use the
AsText() function.
- - The loader and dumper use the hexidecimal canonical representation,
+ - The loader and dumper use the hexadecimal canonical representation,
so coordinate drift due to floating point string parsing is now
eliminated.
- New functions: UpdateGeometrySRID(), AsGML(), SnapToGrid(),
@@ -2933,7 +2933,7 @@ PostGIS 0.7.0
- xmin(),ymin(),zmin(),xmax(),ymax(),zmax() functions
- Bug Fixes
- transform() more graceful when grid shifts are missing
- - setsrid() made cachable
+ - setsrid() made cacheable
- patches to loader/dumper
diff --git a/doc/developer.md b/doc/developer.md
index 3c51f4cab..95da8837f 100644
--- a/doc/developer.md
+++ b/doc/developer.md
@@ -203,7 +203,7 @@ On many occasions, we'll introduce functionality that can only be used if PostGI
with a dependency library higher than X? Where X is some version of a dependency library.
Dependency guards need to be put in both the C library files and our test files.
-On some occassions where we need to do something different based on version of PostgreSQL,
+On some occasions where we need to do something different based on version of PostgreSQL,
you'll see guards in the SQL files as well.
We have guards in place in the code to handle these for dependency libraries
Summary of changes:
NEWS | 36 ++++++++++++++++++------------------
doc/developer.md | 2 +-
2 files changed, 19 insertions(+), 19 deletions(-)
hooks/post-receive
