[PostGIS] #6023: Silent toplogy error in the result (face has multiple shells,mixed face labeling in ring)
trac at osgeo.org
Mon Dec 22 05:23:44 PST 2025
labeling in ring)
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Description changed by strk:
Old description:
> From a set of topology jobs we got a simple feature result table with
> 115930754 rows. But in this result table we did find both gaps and
> overlaps in 6677 quite small areas.
> We always run ValidateTopology so we did know that we had invalid
> topology i this areas also.
> So I created a simple test [https://gitlab.com/nibioopensource/resolve-
> overlap-and-gap/-/blob/118-topology-error-cause-overlap-in-result-mixed-
> face-labeling-in-ring-54-face-has-multiple-
> shells/src/test/sql/regress/rog_overlay_test_25.sql?ref_type=heads] for
> small problem area
> face has multiple shells | 3 | -25
> mixed face labeling in ring | 1 | [NULL]
> So from this test I created single sql file attached no_tolerance.sql to
> reproduce the error.
> If create the Topology with a tolerance almost all errors seems to go
> away, see file with_tolerance.sql.
> This is tested in
> PostgreSQL 16.10 (Homebrew) on aarch64-apple-darwin23.6.0, compiled by
> Apple clang version 16.0.0 (clang-1600.0.26.6), 64-bit
> POSTGIS="3.7.0dev 3.6.0rc2-152-g19e25a659" [EXTENSION] PGSQL="160"
> GEOS="3.14.0-CAPI-1.20.4" PROJ="9.7.0 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
> DATABASE_PATH=/opt/homebrew/Cellar/proj/9.7.0/share/proj/proj.db"
> (compiled against PROJ 9.7.0) LIBXML="2.13.0" LIBJSON="0.18" TOPOLOGY
> and
> PostgreSQL 16.4 (Ubuntu 16.4-1.pgdg20.04+1) on x86_64-pc-linux-gnu,
> compiled by gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0, 64-bit
> GEOS="3.14.0-CAPI-1.20.4" (compiled against GEOS 3.13.1) PROJ="8.2.1
> NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
> DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 8.2.1)
> LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
> (Internal)" TOPOLOGY
New description:
115,930,754 rows. But in this result table we did find both gaps and
We always run ValidateTopology so we did know that we had invalid topology
i this areas also.
small problem area
This is tested in
and
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6023#comment:3>
