[PostGIS] #5847: woodie failing on recent stable branches with lto-wrapper issue
    trac at osgeo.org
    Mon Feb  3 09:00:36 PST 2025
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.5.3
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 PG17 check run
 linux-gnu -lSFCGAL -lgmpxx -Wl,--exclude-libs,ALL  -lm -flto
 lto1: internal compiler error: resolution sub id 0xe4dae6eafbe92346 not in
 object file
 Please submit a full bug report,
 with preprocessed source if appropriate.
 See <file:///usr/share/doc/gcc-9/README.Bugs> for instructions.
 lto-wrapper: fatal error: gcc returned 1 exit status
 compilation terminated.
 /usr/bin/ld: error: lto-wrapper failed
 collect2: error: ld returned 1 exit status
 make[1]: ***
 [/usr/lib/postgresql/12/lib/pgxs/src/makefiles/../../src/Makefile.shlib:309:
 postgis-3.4.so] Error 1
 make[1]: Leaving directory
 '/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/build/pg12/postgis'
 make: *** [GNUmakefile:25: all] Error 1
 make: Leaving directory
 '/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/build/pg12'
 I'm not sure if we have any other bots running with lto-wrapper as it
 caused issues with otehr ci.
 https://woodie.osgeo.org/repos/30/pipeline/2827/10
 This seems to have started with pgsignal changes.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5847>
