[PostGIS] #5849: Doc building failing
trac at osgeo.org
Tue Feb 4 06:20:44 PST 2025
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: QA/buildbots | Version: 3.4.x
Keywords: |
Looks like debbie's make dist which also builds the docs has been failing
since Jan 27th with this error
16:05:50 ln -fs html/images .; # work around
https://trac.osgeo.org/postgis/ticket/5422
16:05:50 /usr/bin/dbtoepub -c
"/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/cc75b983ed9e36b4124e108141e5c638f4da1a6a/doc/html/style.css"
16:05:50 -o postgis-3.6.0dev-en.epub \
16:05:50 postgis-out.xml
16:05:51 Note: namesp. cut : stripped namespace before processing
PostGIS 3.6.0dev Manual
16:07:59 /usr/lib/ruby/2.7.0/rexml/parsers/baseparser.rb:520:in `block in
unnormalize': uninitialized constant REXML::Parsers::BaseParser::Security
(NameError)
16:07:59 Did you mean? SecurityError
16:07:59 from
/usr/lib/ruby/2.7.0/rexml/parsers/baseparser.rb:513:in `each'
16:07:59 from
/usr/lib/ruby/2.7.0/rexml/parsers/baseparser.rb:513:in `unnormalize'
16:07:59 from /usr/lib/ruby/2.7.0/rexml/parsers/pullparser.rb:79:in
`pull'
16:07:59 from /usr/lib/ruby/vendor_ruby/dbtoepub/docbook.rb:217:in
`get_image_refs'
16:07:59 from /usr/lib/ruby/vendor_ruby/dbtoepub/docbook.rb:178:in
`copy_images'
16:07:59 from /usr/lib/ruby/vendor_ruby/dbtoepub/docbook.rb:112:in
`bundle_epub'
16:07:59 from /usr/lib/ruby/vendor_ruby/dbtoepub/docbook.rb:54:in
`render_to_file'
16:07:59 from /usr/bin/dbtoepub:72:in `block in <main>'
16:07:59 from /usr/bin/dbtoepub:61:in `each'
16:07:59 from /usr/bin/dbtoepub:61:in `<main>'
16:07:59 make: *** [Makefile:462: postgis-3.6.0dev-en.epub] Error 1
16:07:59 Build step 'Execute shell' marked build as failure
16:07:59 [Gitea] do not publish assets due to build being non-Successfully
16:07:59 Finished: FAILURE
I don't recall having run any patch updates in that time, but it's
possible
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5849>
