[PostGIS] #5848: expose a lower level function of TopoGeo_AddLineString that returns more info
trac at osgeo.org
Wed Feb 5 09:25:43 PST 2025
info
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.5.3
Component: topology | Version: 3.4.x
Resolution: | Keywords:
Comment (by strk):
I'm open the the introduction of a method to report all side-effects.
How to encode the return code is non-trivial.
Addition of a line may:
0. Add one or more edges
1. Split one or more edges
2. Modify one or more edges shape (due to snapping)
3. Remove one or more edges (experimental edge merging, since 3.5.0)
4. Split one or more faces
5. Turn a previously isolated node into a non-isolated node
A lot of things to report ! Maybe it could be a table-returning function,
so that the return set could be appended to a log table by the caller, if
needed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5848#comment:5>
