[PostGIS] #5853: Bug in upgrade scripts for topology and tiger geocoder
trac at osgeo.org
Tue Feb 18 12:23:08 PST 2025
Reporter: sbrys | Owner: strk
Type: defect | Status: new
Priority: low | Milestone:
Component: upgrade | Version: master
Keywords: |
I have discovered a bug in the upgrade scripts of topology and tiger
geocoder.
The extension helper function, postgis_extension_remove_objects, had a bug
introduced with commit
[https://git.osgeo.org/gitea/postgis/postgis/commit/0b67924d22ec6ef5c095c41660d7cd9788027245
0b67924]. We incorrectly set var_class to ‘pg_catalog.pg_proc’
[https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/extensions/postgis_extension_helper.sql.in#L33
(line 33)], which is compared against the relname column of pg_class
[https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/extensions/postgis_extension_helper.sql.in#L67
(line 67)], ultimately failing as ‘pg_catalog.pg_proc’ != ‘pg_proc’,
leading us to not unpack any of the functions.
This seems to have gone under the radar, considering it’s been nearly
three years. I think a possible explanation is that since 2012 the
PostgreSQL community commit !08dd23c had enabled DROP FUNCTION to work
inside of an extension script without first dissociating the function from
the extension.
Now, the unfortunate part is that by fixing this bug we introduce
ourselves to the fallout of CVE-2022-2625, as the subsequent CREATE OR
REPLACE FUNCTION statements fail as the functions are no longer owned by
the extension (similar to #5209). These scripts relied on those CREATE OR
REPLACE FUNCTION statements to package them back into the extension, but
we can no longer do that.
Please correct me if I’m wrong, but since it seems ALTER EXTENSION DROP is
no longer needed, could we get rid of postgis_extension_remove_objects,
and subsequently remove_from_extension.sql.in?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5853>
