[SCM] PostGIS branch master updated. 3.5.0-212-gae7be624b
Mon Feb 24 16:34:21 PST 2025
the project "PostGIS".
       via  ae7be624b433fff989ccf9e0ff129892c535e4ae (commit)
      from  202d59f44f2e3690038821f889e6506c3b553abf (commit)
revisions in full, below.
commit ae7be624b433fff989ccf9e0ff129892c535e4ae
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Feb 24 16:34:17 2025 -0800
    Fix index binding for ST_DFullyWithin, closes #5855
diff --git a/postgis/gserialized_supportfn.c b/postgis/gserialized_supportfn.c
index 4431ed50c..b6fe6dbba 100644
--- a/postgis/gserialized_supportfn.c
+++ b/postgis/gserialized_supportfn.c
@@ -85,7 +85,7 @@ static const int16 GeometryStrategies[] = {
 	[ST_OVERLAPS_IDX]               = RTOverlapStrategyNumber,
 	[ST_COVERS_IDX]                 = RTContainsStrategyNumber,
 	[ST_CROSSES_IDX]                = RTOverlapStrategyNumber,
-	[ST_DFULLYWITHIN_IDX]           = RTContainsStrategyNumber,
+	[ST_DFULLYWITHIN_IDX]           = RTContainedByStrategyNumber,
 	[ST_3DDWITHIN_IDX]              = RTOverlapStrategyNumber,
 	[ST_3DDFULLYWITHIN_IDX]         = RTOverlapStrategyNumber,
 	[ST_LINECROSSINGDIRECTION_IDX]  = RTOverlapStrategyNumber,
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 8228e59ca..913970d4b 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1561,3 +1561,17 @@ SELECT '#5677',
 SELECT '#5686', ST_NumInteriorRings('TRIANGLE (( -71.0821 42.3036, -71.0821 42.3936, -71.0901 42.3036, -71.0821 42.3036))'::geometry);
 SELECT '#5747', ST_Length('MULTISURFACE (((0 0, 1 0, 1 1, 0 1, 0 0)), CURVEPOLYGON (CIRCULARSTRING (10 10, 11 11, 12 10, 11 9, 10 10)))'::geometry);
+-- #5855
+CREATE TEMP TABLE TEST (street text, extent geometry(Polygon,32633));
+INSERT INTO test VALUES ('Knosesmauet','0103000020797F0000010000000500000010B2468761BDDFC06390523AA1B0594110B2468761BDDFC030554D9BC3B0594107992AF50799DFC030554D9BC3B0594107992AF50799DFC06390523AA1B0594110B2468761BDDFC06390523AA1B05941');
+SET enable_seqscan=false;
+CREATE INDEX test_idx ON test USING GIST ( extent );
+SELECT '#5855', street
+FROM test
+WHERE ST_DFullyWithin(
+    ST_SetSRID(ST_GeomFromText('POINT(-32356 6734606)'), 32633),
+    extent,
+    1700
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index e81b530ef..27d415dba 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -482,3 +482,4 @@ ERROR:  Geometry contains invalid coordinates
 #5677|POLYGON((0 0,0 10,20 22,20 30,30 30,30 20,22 20,10 0,0 0))
 #5686|0
 #5747|0
+#5855|Knosesmauet
Summary of changes:
 postgis/gserialized_supportfn.c |  2 +-
 regress/core/tickets.sql        | 14 ++++++++++++++
 regress/core/tickets_expected   |  1 +
 3 files changed, 16 insertions(+), 1 deletion(-)
hooks/post-receive
