[SCM] PostGIS branch stable-3.1 updated. 3.1.11-15-ge6e6439aa
    git at osgeo.org
    git at osgeo.org
    Sun Jan  5 01:50:40 PST 2025
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  e6e6439aad1e874860a7521b9876ed24b7f873aa (commit)
      from  302a87729f44ed971d1e0bbcebcd96bb23432448 (commit)
revisions in full, below.
commit e6e6439aad1e874860a7521b9876ed24b7f873aa
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Jan 5 04:50:34 2025 -0500
    Upgrade winnie scripts
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 720f0c198..24efa2044 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,105 +1,27 @@
 #!/usr/bin/env bash
-set -e
-if  [[ "${OVERRIDE}" == '' ]] ; then
-	export GEOS_VER=3.8.1
-	export GDAL_VER=3.0.4
-	export PROJ_VER=6.3.2
-	export SFCGAL_VER=1.3.8
-	export CGAL_VER=5.0
-	export ICON_VER=1.16
-	export ZLIB_VER=1.2.11
-  export PROTOBUF_VER=3.2.0
-	export PROTOBUFC_VER=1.2.1
-	export JSON_VER=0.12
-	export PROJSO=libproj-15.dll
-fi;
-export PROTOBUF_VER=3.2.0
-export PROTOBUFC_VER=1.2.1
-export JSON_VER=0.12
-export PCRE_VER=8.33
-if  [[ "${ICON_VER}" == '' ]] ; then
-  export ICON_VER=1.15
-fi;
-echo "ICON_VER ${ICON_VER}"
-#set to something even if override is on but not set
-if  [[ "${ZLIB_VER}" == '' ]] ; then
-fi;
-if  [[ "${LIBXML_VER}" == '' ]] ; then
-  export LIBXML_VER=2.7.8
-fi;
-if  [[ "${CGAL_VER}" == '' ]] ; then
-  export CGAL_VER=4.11
-fi;
-#export GDAL_VER=2.4.0
-#export PROJ_VER=5.2.0
-echo "ZLIB_VER $ZLIB_VER"
-echo "PROJ_VER $PROJ_VER"
-echo "LIBXML_VER $LIBXML_VER"
-echo "CGAL_VER $CGAL_VER"
-export PROJECTS=/projects
-export MINGPROJECTS=/projects
-export PATHOLD=$PATH
-if [ "$OS_BUILD" == "64" ] ; then
-	export MINGHOST=x86_64-w64-mingw32
-else
-	export MINGHOST=i686-w64-mingw32
-fi;
-echo PATH AFTER: $PATH
-#export PG_VER=9.2beta2
-export PGWINVER=${PG_VER}edb
-export WORKSPACE=`pwd`
-echo PATH BEFORE: $PATH
-#export PGHOST=localhost
-#export PGPORT=8442
-export PGUSER=postgres
-#export GEOS_VER=3.4.0dev
-#export GDAL_VER=1.9.1
-export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
-export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
-export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
-export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
+. $(dirname $0)/winnie_common.sh
 if [ -n "$SOURCE_FOLDER" ]; then
   export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
+  cd ${POSTGIS_SRC}
 else
   if [[ "$POSTGIS_MICRO_VERSION"  == *SVN* || "$POSTGIS_MICRO_VERSION"  == *dev* ]] ; then
     export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_VER}
   else
     #tagged version -- official release
     export POSTGIS_SRC=${PROJECTS}/postgis/tags/${POSTGIS_VER}.${POSTGIS_MICRO_VERSION}
+    INCLUDE_MINOR_LIB=0
   fi;
 fi;
-#export POSTGIS_SRC=${PROJECTS}/postgis/trunk
-export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
+export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
+#export POSTGIS_SRC=${PROJECTS}/postgis/trunk
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
-export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
-export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
-CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
-#add protobuf
-export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
@@ -116,9 +38,12 @@ echo PORT IS $PGPORT
 echo PGIS_REG_TMPDIR IS $PGIS_REG_TMPDIR
 export XSLTPROCFLAGS=
 cd ${POSTGIS_SRC}
-if [ -e ./GNUMakefile ]; then
-	make distclean
-fi
+# if [ -e ./GNUMakefile ]; then
+# 	make distclean
+# fi
+git clean -dxf # ensure we start fresh
+git describe --long --all --tags # Report where we are at
 sh autogen.sh
@@ -126,47 +51,34 @@ if [ -n "$PCRE_VER" ]; then
     export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 fi
-if [ -n "$SFCGAL_VER" ]; then
-	##hard code versions of cgal etc. for now
-	BOOST_VER=1.53.0
-	#BOOST_VER_WU=1_49_0
-	export BOOST_VER_WU=1_53_0
-	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+if [$INCLUDE_MINOR_LIB == "1"]; then
 #CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
 #CFLAGS="-Wall -fno-omit-frame-pointer"
 #LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
-LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
+LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
 ./configure \
   --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
   --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
-  --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
   --with-gui --with-gettext=no \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
-  --without-interrupt-tests \
-  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
+  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version
   #exit
 else
-CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
-CFLAGS="-Wall -fno-omit-frame-pointer" \
-LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
-  --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
+./configure \
+  --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
-  --with-gui --with-gettext=no \
+  --with-gui --with-gettext=no \
+  --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
 fi;
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index f61eb291b..6c3196a89 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -1,4 +1,6 @@
-#### $Id: package_postgis210.sh 10291 2012-09-15 05:37:23Z robe $
+#!/usr/bin/env bash
 ### this script is used to zip up the compiled binaries
 ## PostgreSQL, OS_BUILD denote the last build to be packaged
 ## and are passed in by the jenkins job process
@@ -12,53 +14,6 @@
 #export OS_BUILD=32
 #export GCC_TYPE=
-#if no override is set - use these values
-#otherwise use the ones jenkins passes thru
-#!/usr/bin/env bash
-	export PROJ_VER=7.2.1
-	export PROJSO=libproj-13.dll
-	export CURL_VER=7.73
-fi;
-fi;
-if  [[ "${CURL_VER}" == '' ]] ; then
-fi;
-fi;
-  export LIBXML_VER=2.9.9
-fi;
-fi;
@@ -104,7 +59,6 @@ export REL_PGVER=${PG_VER//./} #strip the period
 export RELDIR=${PROJECTS}/postgis/builds/${POSTGIS_MINOR_VER}
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}${GCC_TYPE}
 #PATH="${PGPATH}/bin:${PGPATH}/lib:${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gtkw${OS_BUILD}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
 #echo PATH AFTER: $PATH
 outdir="${RELDIR}/${RELVERDIR}"
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 320e815f2..a822a928c 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,76 +1,14 @@
 #!/usr/bin/env bash
-set -e
-	export CGAL_VER=5.0.2
-fi;
-fi;
-fi;
-fi;
-fi;
-else
-fi;
+echo "MSYS2_ARG_CONV_EXCL=$MSYS2_ARG_CONV_EXCL"
@@ -79,6 +17,7 @@ export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POS
+	cd $POSTGIS_SRC
 else
@@ -88,22 +27,16 @@ else
   fi;
 fi;
+export POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+echo "Version ${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
-#needed for proj.db to be found during cunit - for some reason on winnie it doesn't set
-export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
-#add protobuf
@@ -132,21 +65,15 @@ fi
-	#export CGAL_VER=4.11
-	BOOST_VER=1.59.0
-	export BOOST_VER_WU=1_59_0
+if [ $INCLUDE_MINOR_LIB == "1" ]; then
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
 ./configure \
@@ -155,25 +82,23 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   #exit
 else
+./configure \
 fi;
-make clean
+#make distclean
 #patch liblwgeom generated make to get rid of dynamic linking
 #sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
@@ -189,24 +114,57 @@ if [ "$MAKE_EXTENSION" == "1" ]; then
  echo "Postgis src dir is ${POSTGIS_SRC}"
  strip postgis/postgis-*.dll
  strip raster/rt_pg/postgis_raster-*.dll
+ strip sfcgal/*.dll
  cp topology/*.dll ${PGPATHEDB}/lib
  cp postgis/postgis*.dll ${PGPATHEDB}/lib
  cp sfcgal/*.dll ${PGPATHEDB}/lib
  cp raster/rt_pg/postgis_raster-*.dll ${PGPATHEDB}/lib
- cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
- cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}next.sql ${PGPATHEDB}/share/extension
- cp -r ${PGPATH}/share/extension/address_standardizer*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
+export POSTGIS_MINOR_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+export POSTGIS_MINOR_MAX_VER="ANY"
+#export UPGRADE_VER_FILE="extensions/upgradeable_versions.mk"
+value=$(<extensions/upgradeable_versions.mk)
+export value=${value//\\/}
+value=${value//UPGRADEABLE_VERSIONS = /}
+#echo $value
+export UPGRADEABLE_VERSIONS=$value
+export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.2.0 2.2.3 2.3.0 2.3.7 2.4.0 2.4.4"
+#echo "Versions are:  $UPGRADEABLE_VERSIONS"
+for EXTNAME in postgis postgis_raster postgis_topology postgis_sfcgal postgis_tiger_geocoder address_standardizer; do
+	cp extensions/$EXTNAME/sql/*  ${PGPATHEDB}/share/extension
+	cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/$EXTNAME--$POSTGIS_MICRO_VER--${POSTGIS_MINOR_MAX_VER}.sql;
+	if test "$EXTNAME" = "address_standardizer"; then #repeat for address_standardizer_data_us
+		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
+		cp extensions//$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
+		cp extensions/$EXTNAME/sql/${EXTNAME}--TEMPLATED--TO--ANY.sql ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--$POSTGIS_MICRO_VER--ANY.sql;
+	fi
+	for OLD_VERSION in $UPGRADEABLE_VERSIONS; do \
+		if [ "$OLD_VERSION" > "2.5" ] || [ "$OLD_VERSION" in $WIN_RELEASED_VERSIONS ]; then
+			cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/$EXTNAME--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
+				cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
+			fi
+		fi
+	done
+done
+ #cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
+ #cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}next.sql ${PGPATHEDB}/share/extension
+ #cp -r ${PGPATH}/share/extension/address_standardizer*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
  cp -r extensions/*/*.control ${PGPATHEDB}/share/extension
  cp -r extensions/*/*.dll ${PGPATHEDB}/lib
  make check RUNTESTFLAGS="--extension -v"
- ##test address standardizer
+ #test address standardizer
  cd ${POSTGIS_SRC}
  cd extensions/address_standardizer
  make installcheck
- ##test tiger geocoder
+ #test tiger geocoder
  cd ${POSTGIS_SRC}
  cd extensions/postgis_tiger_geocoder
  make installcheck
@@ -215,8 +173,8 @@ if [ "$MAKE_EXTENSION" == "1" ]; then
  fi
 fi
-if [ "$DUMP_RESTORE" = "1" ]; then
- echo "Dum restore test"
+if [ "$DUMP_RESTORE" == "1" ]; then
+ echo "Dump restore test"
  make install
  make check RUNTESTFLAGS="-v --dumprestore"
  if [ "$?" != "0" ]; then
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
new file mode 100644
index 000000000..48dad063e
--- /dev/null
+++ b/ci/winnie/winnie_common.sh
@@ -0,0 +1,143 @@
+# Common code for all winnie scripts
+# TODO: add more shared code, I guess
+set -e
+export PROJECTS=/projects
+# Don't convert paths
+# See https://trac.osgeo.org/postgis/ticket/5436#comment:5
+export MSYS2_ARG_CONV_EXCL=/config/tags
+if  [[ "${OVERRIDE}" == '' ]] ; then
+	export GEOS_VER=3.12.1
+	export GDAL_VER=3.9.2
+	export PROJ_VER=8.2.1
+	export SFCGAL_VER=1.5.2
+	export CGAL_VER=6.0.1
+	export ICON_VER=1.17
+	export ZLIB_VER=1.2.13
+	export PROTOBUF_VER=3.2.0
+	export PROTOBUFC_VER=1.2.1
+	export JSON_VER=0.12
+	export PROJSO=libproj_8_2.dll
+	export LZ4_VER=1.9.3
+fi;
+export PROTOBUF_VER=3.2.0
+export PROTOBUFC_VER=1.2.1
+export JSON_VER=0.12
+export PCRE_VER=8.45
+#export OS_BUILD=64
+#export PGPORT=8442
+#export OS_BUILD=32
+#export GCC_TYPE=
+#if no override is set - use these values
+#otherwise use the ones jenkins passes thru
+if  [[ "${ICON_VER}" == '' ]] ; then
+fi;
+echo "ICON_VER ${ICON_VER}"
+#set to something even if override is on but not set
+if  [[ "${ZLIB_VER}" == '' ]] ; then
+fi;
+if  [[ "${LIBXML_VER}" == '' ]] ; then
+  export LIBXML_VER=2.9.14
+fi;
+if  [[ "${CGAL_VER}" == '' ]] ; then
+  export CGAL_VER=6.0.2
+fi;
+##hard code versions of cgal etc. for now
+export CGAL_VER=6.0.2
+BOOST_VER=1.84.0
+export BOOST_VER_WU=1_84_0
+export LZ4_PATH=${PROJECTS}/lz4/rel-lz4-${LZ4_VER}w${OS_BUILD}${GCC_TYPE}
+export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
+#export GDAL_VER=2.4.0
+#export PROJ_VER=5.2.0
+echo "ZLIB_VER $ZLIB_VER"
+echo "PROJ_VER $PROJ_VER"
+echo "LIBXML_VER $LIBXML_VER"
+echo "CGAL_VER $CGAL_VER"
+export MINGPROJECTS=/projects
+export PATHOLD=$PATH
+if [ "$OS_BUILD" == "64" ] ; then
+	export MINGHOST=x86_64-w64-mingw32
+else
+	export MINGHOST=i686-w64-mingw32
+fi;
+#needed for proj.db to be found during cunit - for some reason on winnie it doesn't set
+if [ -d "${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj" ]; then
+export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+export PROJ_PATH=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}
+else
+export PROJ_LIB=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+export PROJ_PATH=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}
+fi
+#export PG_VER=9.2beta2
+export PGWINVER=${PG_VER}edb
+export WORKSPACE=`pwd`
+echo PATH BEFORE: $PATH
+#export PGHOST=localhost
+export PGUSER=postgres
+#export GEOS_VER=3.4.0dev
+#export GDAL_VER=1.9.1
+export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
+export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
+export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
+export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
+#add protobuf
+export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+#add lz4
+export PATH="${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
+echo $PATH
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${LZ4_PATH}/lib/pkgconfig"
+#add protobuf
+echo "PATH AFTER: $PATH"
+if  [[ "${INCLUDE_MINOR_LIB}" == "" ]] ; then
+	export INCLUDE_MINOR_LIB=1
+fi;
Summary of changes:
 ci/winnie/build_postgis.sh   | 130 ++++++-----------------------------
 ci/winnie/package_postgis.sh |  52 +-------------
 ci/winnie/regress_postgis.sh | 158 ++++++++++++++++---------------------------
 ci/winnie/winnie_common.sh   | 143 +++++++++++++++++++++++++++++++++++++++
 4 files changed, 225 insertions(+), 258 deletions(-)
 create mode 100644 ci/winnie/winnie_common.sh
hooks/post-receive
