[PostGIS] #5826: ST_OrderingEquals give results that are inconsistent with doc
trac at osgeo.org
Sun Jan 5 14:12:15 PST 2025
Reporter: nbvfgh | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.2
Component: documentation | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
I haven't forgotten about this, just trying to come up with a different
example that isn't comparing exact things.
At one point, ST_OrderingEquals used to return true for this, but I
presume somewhere along the line of GEOS development this behavior
changed. Maybe there is no longer a case where things are not exactly the
same where ST_OrderingEquals will return true and this is essentially
binary equality which is kinda depressing.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5826#comment:1>
