[PostGIS] #5826: ST_OrderingEquals give results that are inconsistent with doc
trac at osgeo.org
Fri Jan 10 15:42:47 PST 2025
Reporter: nbvfgh | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.2
Component: documentation | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
Okay it appears this function is not utilizing GEOS at all and as @dbaston
brought to my attention probably changed in
https://github.com/postgis/postgis/commit/55e902122cc7f057a77f5bb48726510843889d4b
to be simplified. This is pretty annoying to me.
I have to check previous versions to confirm the old did return the
documented answer.
Making this just be == check is kinda pointless since the = sign now does
that for us (before that used to be bounding box). Though I don't know if
it makes sense to change the behavior back in a micro. Probably will need
to wait for PostGIS 3.6.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5826#comment:2>
