[PostGIS] #5829: SELECT geometry_columns returns unexpected error when there are constraints after SRID constraint.
trac at osgeo.org
Sun Jan 5 23:54:15 PST 2025
Reporter: nbvfgh | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.6.0
Component: postgis | Version: 3.5.x
Keywords: |
DROP TABLE IF EXISTS test;
create table test (geom geometry);
ALTER TABLE test ADD CONSTRAINT c1 CHECK (ST_SRID(geom)=4326 and
ST_IsValid(geom));
SELECT * FROM geometry_columns;
-- ERROR: invalid type integer input syntax: "4326 AND st_isvalidgeom"
If the order of the two constraints is reversed:
ALTER TABLE test ADD CONSTRAINT c1 CHECK (ST_IsValid(geom) and
ST_SRID(geom)=4326);
-- normal result
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5829>
