[PostGIS] #5830: Bug in ST_Equals for large data volumes
PostGIS trac at osgeo.org
Mon Jan 6 01:25:46 PST 2025
 Reporter:  hhinrichs        |      Owner:  pramsey
     Type:  defect           |     Status:  new
 Priority:  high             |  Milestone:  PostGIS 3.5.2
Component:  postgis          |    Version:  3.5.x
 Keywords:  st_within, llvm  |
 Hello,
 I ran into an issue running a query that processes a large data volume.
 I suspect the issue is related to https://lists.osgeo.org/pipermail
 /postgis-users/2024-November/046606.html.
 Dummy query that fails:
 SELECT 1 FROM communities c1, communities c2 WHERE ST_Equals(c1.geom,
 c2.geom)
 Dummy query that runs:
 c2.geom) AND c1.gisco_code = 'DE_01001000'
 The error my postgres container logs:
 error: Unknown attribute kind (86) (Producer: 'LLVM16.0.6' Reader: 'LLVM
 15.0.6')
 I tried to run the failing query on our staging environment where we have
 PostGis 3.4.0 and it runs without any error.
 I was unable to install 3.4.x locally as older versions seem to get
 deleted from the apt repository and installing it from source was pain and
 did not work in the end.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5830>
