[PostGIS] #5817: CG_3DIntersection gives wrong result with LINESTRING and Solid
PostGIS trac at osgeo.org
Thu Jan 9 03:47:45 PST 2025
  Reporter:  nbvfgh    |      Owner:  lbartoletti
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.6.0
 Component:  sfcgal    |    Version:  3.5.x
Resolution:            |   Keywords:
Changes (by nbvfgh):
 * milestone:  PostGIS 3.5.2 => PostGIS 3.6.0
Old description:
> SELECT ST_IsClosed('POLYHEDRALSURFACE Z (
> ((-1 1 -1,1 1 -1,1 -1 -1,-1 -1 -1,-1 1 -1)),
> ((-1 1 1,-1 -1 1,1 -1 1,1 1 1,-1 1 1)),
> ((-1 1 -1,-1 1 1,1 1 1,1 1 -1,-1 1 -1)),
> ((1 1 -1,1 1 1,1 -1 1,1 -1 -1,1 1 -1)),
> ((1 -1 -1,1 -1 1,-1 -1 1,-1 -1 -1,1 -1 -1)),
> ((-1 -1 -1,-1 -1 1,-1 1 1,-1 1 -1,-1 -1 -1)))');
> -- result:{true}
> Then we make the closed POLYHEDRALSURFACE a Solid, and use
> CG_3DIntersection to get the Interaction with the Solid and Linestring,
> which we get the unexpected result.
> WITH solid AS (
>     SELECT
>         CG_MakeSolid('POLYHEDRALSURFACE Z (
>      geom
> SELECT
>         ST_AsText(CG_3DIntersection(
>         'LINESTRING (-2 0 0, 2 0 2)'::geometry,
>         solid.geom
>         'LINESTRING (-2 0 0,0 0 1,2 0 2)'::geometry,
>         solid.geom
> FROM solid;
> -- expected: {{LINESTRING Z (-1 0 0.5,0 0 1)},{LINESTRING Z (-1 0 0.5,0 0
> 1)}}
> -- actual  : {{POINT Z (-1 0 0.5)},{LINESTRING Z (-1 0 0.5,0 0 1)}}
> To verify that the issue is not caused by differences in the two
> Linestrings, we ran the following query:
> SELECT
>         'LINESTRING (-2 0 0,2 0 2)'::geometry,
>         'POLYHEDRALSURFACE Z (((-1 1 -1,1 1 -1,1 -1 -1,-1 -1 -1,-1 1
> -1)),((-1 1 1,-1 -1 1,1 -1 1,1 1 1,-1 1 1)),((-1 1 -1,-1 1 1,1 1 1,1 1
> -1,-1 1 -1)),((1 1 -1,1 1 1,1 -1 1,1 -1 -1,1 1 -1)),((1 -1 -1,1 -1 1,-1
> -1 1,-1 -1 -1,1 -1 -1)),((-1 -1 -1,-1 -1 1,-1 1 1,-1 1 -1,-1 -1 -1)))'
> -- expected: {{MULTIPOINT Z ((-1 0 0.5),(0 0 1))},{MULTIPOINT Z ((-1 0
> 0.5),(0 0 1))}
> -- actual  : {{MULTIPOINT Z ((-1 0 0.5),(0 0 1))},{MULTIPOINT Z ((-1 0
> 0.5),(0 0 1))}
> The intersection between the original POLYHEDRALSURFACE and these two
> linestrings yielded the same result, so there should be some bugs in the
> operation of the intersection between Solid and Linestring.
New description:
 -- result:{true}
 WITH solid AS (
     SELECT
      geom
 SELECT
         solid.geom
         solid.geom
 FROM solid;
 1)}}
 SELECT
 -1,-1 1 -1)),((1 1 -1,1 1 1,1 -1 1,1 -1 -1,1 1 -1)),((1 -1 -1,1 -1 1,-1 -1
 0.5),(0 0 1))}
 0.5),(0 0 1))}
 Version:{{{POSTGIS="3.6.0dev 3.5.0-91-g593df9088" [EXTENSION] PGSQL="170"
 GEOS="3.13.0-CAPI-1.19.0" SFCGAL="SFCGAL 1.5.2, CGAL 5.6.1, BOOST
 1.84.0"}}}
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5817#comment:2>
