[PostGIS] #5818: CG_IsSolid(geom) gives the wrong result In PostGIS
PostGIS trac at osgeo.org
Thu Jan 9 03:54:22 PST 2025
  Reporter:  nbvfgh    |      Owner:  lbartoletti
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.6.0
 Component:  sfcgal    |    Version:  3.5.x
Resolution:            |   Keywords:
Changes (by nbvfgh):
 * milestone:  PostGIS SFCGAL => PostGIS 3.6.0
Old description:
> We perform the following query on a closed polyhedralsurface:
> WITH polyhedralsurface AS (
>     SELECT
>         'POLYHEDRALSURFACE Z (((-1 1 -1,1 1 -1,1 -1 -1,-1 -1 -1,-1 1
> -1)),
>                               ((-1 1 1,-1 -1 1,1 -1 1,1 1 1,-1 1 1)),
>                               ((-1 1 -1,-1 1 1,1 1 1,1 1 -1,-1 1 -1)),
>                               ((1 1 -1,1 1 1,1 -1 1,1 -1 -1,1 1 -1)),
>                               ((1 -1 -1,1 -1 1,-1 -1 1,-1 -1 -1,1 -1
> -1)),
>                               ((-1 -1 -1,-1 -1 1,-1 1 1,-1 1 -1,-1 -1
> -1)))'
>      geom
> SELECT
>     CG_IsSolid(geom),
>     ST_IsClosed(geom),
>     CG_Volume(geom)
> FROM polyhedralsurface
> -- result : {f,t,0}
> But when we converted this polyhedralsurface into a solid, we obtained an
> unexpected result
> WITH solid AS (
>     SELECT CG_MakeSolid(
> -1)),
> -1)),
> -1)))'
>     ) geom
> SELECT
>     CG_IsSolid(geom),
>     ST_IsClosed(geom),
>     CG_Volume(geom)
> FROM solid;
> -- expected : {t,t,8};
> -- actual   : {f,t,8};
> It should be noted that, CG_Volume(geom) computes the volume of a 3D
> solid,and if it applied to surface (even closed) geometries will return
> 0. Its return value is 8 here, indicating that geom is not a surface,
> while CG_IsSolid(geom) returns false. So what type of geometry is geom?
> Version Info:
> POSTGIS="3.5.0 3.5.0" [EXTENSION] PGSQL="170" GEOS="3.13.0-CAPI-1.19.0"
> SFCGAL="SFCGAL 1.5.2, CGAL 5.6.1, BOOST 1.84.0" PROJ="8.2.1
> NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=C:\WINDOWS\ServiceProfiles\NetworkService\AppData\Local/proj
> DATABASE_PATH=C:\Program
> Files\PostgreSQL\16\share\contrib\postgis-3.4\proj\proj.db" (compiled
> against PROJ 8.13.0) LIBXML="2.12.5" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
> WAGYU="0.5.0 (Internal)" TOPOLOGY
New description:
     SELECT
         'POLYHEDRALSURFACE Z (((-1 1 -1,1 1 -1,1 -1 -1,-1 -1 -1,-1 1 -1)),
                               ((1 -1 -1,1 -1 1,-1 -1 1,-1 -1 -1,1 -1 -1)),
 -1)))'
      geom
 SELECT
     CG_IsSolid(geom),
     ST_IsClosed(geom),
     CG_Volume(geom)
 -- result : {f,t,0}
 unexpected result
 WITH solid AS (
 -1)))'
     ) geom
 SELECT
     CG_IsSolid(geom),
     ST_IsClosed(geom),
     CG_Volume(geom)
 FROM solid;
 solid,and if it applied to surface (even closed) geometries will return 0.
 Its return value is 8 here, indicating that geom is not a surface, while
 Version Info:
 POSTGIS="3.6.0dev 3.5.0-91-g593df9088" [EXTENSION] PGSQL="170"
 GEOS="3.13.0-CAPI-1.19.0" SFCGAL="SFCGAL 1.5.2, CGAL 5.6.1, BOOST 1.84.0"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5818#comment:1>
