[PostGIS] #5836: Different result with same table and same query in various PostGIS versions
trac at osgeo.org
Mon Jan 13 20:10:30 PST 2025
Reporter: zhangyijun | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Description changed by zhangyijun:
Old description:
> Hi! Have a nice day
> It seems we got different results with same table and same query,
> The TABLE is:
> [https://github.com/maplibre/martin/blob/935c6b624fde3a7ba48443ff66e4cf6312b6ef1e/tests/fixtures/tables/table_source.sql]
> you could execute this sql to init the table.
> The QUERY is :
> SELECT
> ST_AsMVT(tile, 'table_source', 4096, 'geom')
> FROM (
> SELECT
> ST_AsMVTGeom(
> ST_Transform(ST_CurveToLine("geom"::geometry), 3857),
> ST_TileEnvelope($1::integer, $2::integer, $3::integer),
> 4096, 64, true
> ) AS geom
> , "gid"
> FROM
> "public"."table_source"
> WHERE
> "geom" && ST_Transform(ST_TileEnvelope($1::integer, $2::integer,
> $3::integer, margin => 0.015625), 4326)
> ) AS tile;
> The RESULT is different with postgis/postgis:14-3.3 and
> postgis/postgis:14-3.5 DOCKER IMAGES.
> z 1 x 1 y 1 => (BLOB) 2 bytes with postgis/postgis:14-3.3
> z 1 x 1 y 1 => (BLOB) 607 bytes with postgis/postgis:14-3.5
> z 1 x 1 y 0 => (BLOB) 2 bytes with postgis/postgis:14-3.3
> z 1 x 1 y 0 => (BLOB) 1.18 KB with postgis/postgis:14-3.5
New description:
Hi! Have a nice day
The TABLE is:
The QUERY is :
SELECT
FROM (
SELECT
ST_AsMVTGeom(
4096, 64, true
) AS geom
, "gid"
FROM
WHERE
) AS tile;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5836#comment:1>
