[PostGIS] #5836: Different result with same table and same query in various PostGIS versions
trac at osgeo.org
Tue Jan 14 08:14:40 PST 2025
Reporter: zhangyijun | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
Wrapping your example in a function:
CREATE OR REPLACE FUNCTION test_mvt(param_1 integer, param_2 integer,
param_3 integer) RETURNS bytea
AS $$SELECT
ST_AsMVT(tile, 'table_source', 4096, 'geom')
FROM (
SELECT
ST_AsMVTGeom(
ST_Transform(ST_CurveToLine("geom"::geometry), 3857),
ST_TileEnvelope($1::integer, $2::integer, $3::integer),
4096, 64, true
) AS geom
, "gid"
FROM
"public"."table_source"
WHERE
"geom" && ST_Transform(ST_TileEnvelope($1::integer, $2::integer,
$3::integer, margin => 0.015625), 4326)
) AS tile$$ language sql;
and then running these tests
SELECT length(test_mvt(1,1,1));
SELECT length(test_mvt(1,1,0));
On my: SELECT postgis_full_version() || ' ' || version();
POSTGIS="3.6.0dev 3.5.0-186-gff6fc3b6c" [EXTENSION] PGSQL="170"
GEOS="3.13.0-CAPI-1.19.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=C:\Users\lr\AppData\Local/proj
DATABASE_PATH=C:\ming64gcc81\projects\proj\rel-
proj-8.2.1w64gcc81/share/proj/proj.db" (compiled against PROJ 8.2.1)
LIBXML="2.12.5" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
(Internal)" PostgreSQL 17.2 on x86_64-w64-mingw32, compiled by gcc.exe
(x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
Yields the same answers as you have for your 3.5
607
1204/1024 = 1.175 kb
Still need to check the older versions. I don't remember off hand if we
made changes between PostGIS 3.3 and 3.5 of MVT or curvetoline support.
But I would presume that would be where changes might arise. I think the
WAGYU version might impact things, but I don't think we updated the WAGYU
between 3.3 and 3.5
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5836#comment:2>
