[PostGIS] #5836: Different result with same table and same query in various PostGIS versions
trac at osgeo.org
Tue Jan 14 19:33:36 PST 2025
Reporter: zhangyijun | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by zhangyijun):
Test more. The result of postgis:14-3.4 is same with postgis:14-3.3.
Seems The result change is from the jump between 3.4 => 3.5.
The full version number is:
POSTGIS="3.4.3 0" [EXTENSION] PGSQL="140" GEOS="3.12.2-CAPI-1.18.2"
PROJ="9.4.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.12.7" LIBJSON="0.17"
LIBPROTOBUF="1.5.0" WAGYU="0.5.0 (Internal)" TOPOLOGY
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5836#comment:3>
