[PostGIS] #5832: Intersection test error with curved polygons
PostGIS trac at osgeo.org
Thu Jan 30 10:20:27 PST 2025
  Reporter:  aaime    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.5.3
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by pramsey):
 I am going to move this to PostGIS GEOS and leave dormant, as Dan Baston
 has been working on some improvements in GEOS to handle curves natively
 that would kill several birds with one stone. It's a long term solution.
 In the meanwhile, the workarounds are
 - know this is an issue and use distance == 0 as your intersects test as
 necessary
 or
 - know this is an issue and preempt the built-in linearizer by pre-
 linearizing your inputs at the level you would prefer
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5832#comment:2>
