[PostGIS] #5832: Intersection test error with curved polygons
trac at osgeo.org
Tue Jan 7 02:35:27 PST 2025
Reporter: aaime | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.2
Component: postgis | Version: 3.4.x
Keywords: |
As reported on the user list, I'm encountering a precision problem with an
intersection test involving curve polygons.
Test data can be found in this Github Gist:
https://gist.github.com/aaime/dcf55b635c5bd09c2b9ebb31a2ab083a
Test for intersection with a point returns two polygons, while only one
polygon actually contains the point:
SELECT ogc_fid FROM testdata WHERE ST_Intersects(geom,
ST_GeomFromText('POINT (25492818 6677399.98)', 3879));
ogc_fid
1258
12875
(2 rows)
The issue has been verified with:
* postgis 3.2 and postgresql 14.15
* postgis 3.5 and postgresql 17.2 (latest postgis docker image)
After discussion we found the issue is that the are linearized before the
intersection test with GEOS, and that using a native curve operator like
distance offers instead the correct result:
SELECT ogc_fid, ST_Distance(ST_GeomFromText('POINT (25492818 6677399.98)',
3879), geom) FROM testdata;
ogc_fid | st_distance
1258 | 0.01234572446598792
12875 | 0
(2 rows)
It looks like the issue could be addressed in a few ways:
* Native curve support for intersection (hard)
* For more practical applications, maybe allow control of the tolerance
used in linearization? Someone knowing the accuracy of their data could
set a variable declaring the desired precision
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5832>
