[SCM] PostGIS branch master updated. 3.5.0-423-gf02bf2981
git at osgeo.org
git at osgeo.org
Thu Jul 3 16:44:52 PDT 2025
the project "PostGIS".
via f02bf29814d44a57e38ff8e30febe74590ef57a6 (commit)
from 7e8f5920e3fccf79246fae15f970a834065ba0bc (commit)
revisions in full, below.
commit f02bf29814d44a57e38ff8e30febe74590ef57a6
Author: Even Rouault <even.rouault at spatialys.com>
Date: Sat May 31 14:33:16 2025 +0200
Doc: replace outdated referances to trac.osgeo.org/gdal by current gdal.org ones
Closes https://github.com/postgis/postgis/pull/810
References https://github.com/postgis/postgis/pull/810
diff --git a/doc/po/da/postgis-manual.po b/doc/po/da/postgis-manual.po
index 68b5595e9..7b0c50afe 100644
--- a/doc/po/da/postgis-manual.po
+++ b/doc/po/da/postgis-manual.po
@@ -14579,7 +14579,7 @@ msgstr ""
#, no-c-format
msgid ""
"Additional information about GDAL_DATA is available at GDAL's <link xlink:"
-"href=\"http://trac.osgeo.org/gdal/wiki/ConfigOptions\">Configuration "
+"href=\"https://gdal.org/user/configoptions.html\">Configuration "
"Options</link>."
msgstr ""
@@ -14678,7 +14678,7 @@ msgstr ""
#, no-c-format
msgid ""
"Additional information about GDAL_SKIP is available at GDAL's <link xlink:"
"Options</link>."
msgstr ""
@@ -14777,8 +14777,8 @@ msgstr ""
#, no-c-format
msgid ""
"A string configuration to set options used when working with an out-db "
-"raster. <link xlink:href=\"http://trac.osgeo.org/gdal/wiki/"
-"ConfigOptions\">Configuration options</link> control things like how much "
+"raster. <link xlink:href=\"https://gdal.org/user/"
+"configoptions.html\">Configuration options</link> control things like how much "
"space GDAL allocates to local data cache, whether to read overviews, and "
"what access keys to use for remote out-db data sources."
msgstr ""
@@ -28453,8 +28453,8 @@ msgstr ""
#, no-c-format
msgid ""
"Examples utilize the katrina raster loaded as a single tile described in "
-"<link xlink:href=\"http://trac.osgeo.org/gdal/wiki/frmts_wtkraster."
-"html\">http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html</link> and then "
+"<link xlink:href=\"https://gdal.org/user/drivers/raster/postgisraster."
+"html\">https://gdal.org/user/drivers/raster/postgisraster.html</link> and then "
"prepared in the <xref linkend=\"RT_ST_Rescale\"/> examples"
msgstr ""
@@ -29967,8 +29967,8 @@ msgstr ""
#, no-c-format
msgid ""
"To control this behavior, GDAL provides the following environment variable: "
-"<link xlink:href=\"https://trac.osgeo.org/gdal/wiki/"
-"ConfigOptions#GDAL_DISABLE_READDIR_ON_OPEN\">GDAL_DISABLE_READDIR_ON_OPEN</"
+"<link xlink:href=\"https://gdal.org/user/"
+"configoptions.html#config-GDAL_DISABLE_READDIR_ON_OPEN\">GDAL_DISABLE_READDIR_ON_OPEN</"
"link>. Set <varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> to <varname>TRUE</"
"varname> to disable directory scanning."
msgstr ""
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index f8af1107f..e99c2ed97 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -19064,12 +19064,12 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"Zusätzliche Informationen über GDAL_DATA ist unter den <link xlink:"
-"href=\"http://trac.osgeo.org/gdal/wiki/"
-"ConfigOptions\">Konfigurationsmöglichkeiten</link> für GDAL zu finden."
+"href=\"https://gdal.org/user/"
+"configoptions.html\">Konfigurationsmöglichkeiten</link> für GDAL zu finden."
#. Tag: para
#, no-c-format
@@ -19195,11 +19195,11 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"Weiterführende Informationen über GDAL_SKIP ist auf GDAL's <link xlink:"
"Options</link> zu finden."
#. Tag: para
@@ -19328,13 +19328,13 @@ msgstr ""
#, fuzzy, no-c-format
msgid ""
msgstr ""
-"<link xlink:href=\"http://trac.osgeo.org/gdal/wiki/"
-"ConfigOptions\">Konfigurationsoptionen</link> steuern z.B. wie viel Platz "
+"configoptions.html\">Konfigurationsoptionen</link> steuern z.B. wie viel Platz "
"GDAL dem lokalen Datencache zuweist, ob Übersichten gelesen werden sollen "
"und welche Zugriffsschlüssel für entfernte Out-DB-Datenquellen verwendet "
"werden sollen."
@@ -37550,13 +37550,13 @@ msgstr "Übergabewerte für die benutzerdefinierte Funktion."
#, no-c-format
msgid ""
msgstr ""
"Die Beispiele nutzen den Raster \"Katrina\", der als einzelne Kachel geladen "
-"wird, wie unter <link xlink:href=\"http://trac.osgeo.org/gdal/wiki/"
-"frmts_wtkraster.html\">http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html</"
+"wird, wie unter <link xlink:href=\"https://gdal.org/user/"
+"frmts_wtkraster.html\">https://gdal.org/user/drivers/raster/postgisraster.html</"
"link> beschrieben; und in den Beispielen von <xref linkend=\"RT_ST_Rescale\"/"
"> aufbereitet wurde."
@@ -39571,14 +39571,14 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
"Dieses Verhalten kann durch folgende Umgebungsvariable von GDAL beeinflusst "
-"werden: <link xlink:href=\"https://trac.osgeo.org/gdal/wiki/"
+"werden: <link xlink:href=\"https://gdal.org/user/"
"link>. Setzen Sie <varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> auf "
"<varname>TRUE</varname> um das Scannen von Verzeichnissen zu verhindern."
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index cb2b41279..64ce3ab17 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -16268,7 +16268,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -16367,7 +16367,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -16466,8 +16466,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -30562,8 +30562,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -32076,8 +32076,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 0cb8c8246..3589c12c7 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -18994,12 +18994,12 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"Des informations complémentaires sur GDAL_DATA sont disponibles dans la "
-"description des <link xlink:href=\"http://trac.osgeo.org/gdal/wiki/"
-"ConfigOptions\">Options de configuration</link>."
+"description des <link xlink:href=\"https://gdal.org/user/"
+"configoptions.html\">Options de configuration</link>."
#. Tag: para
#, no-c-format
@@ -19127,12 +19127,12 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"Des informations supplémentaires sur GDAL_SKIP sont disponibles sur le site "
-"GDAL <link xlink:href=\"http://trac.osgeo.org/gdal/wiki/"
-"ConfigOptions\">Configuration Options</link>."
+"GDAL <link xlink:href=\"https://gdal.org/user/"
+"configoptions.html\">Configuration Options</link>."
#. Tag: para
#, no-c-format
@@ -19263,14 +19263,14 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
"Une chaîne de configuration pour définir les options utilisées lors de "
"l'utilisation d'un raster out-db. <link xlink:href=\"http://trac.osgeo.org/"
-"gdal/wiki/ConfigOptions\">Les options de configuration</link> contrôlent des "
+"gdal/wiki/configoptions.html\">Les options de configuration</link> contrôlent des "
"éléments tels que l'espace alloué par GDAL au cache des données locales, la "
"lecture ou non des aperçus et les clés d'accès à utiliser pour les sources "
"de données out-db distantes."
@@ -37345,13 +37345,13 @@ msgstr "Arguments à transmettre à la fonction utilisateur."
#, no-c-format
msgid ""
msgstr ""
"Les exemples utilisent le raster katrina chargé comme une seule tuile, tel "
-"que décrit dans <link xlink:href=\"http://trac.osgeo.org/gdal/wiki/"
+"que décrit dans <link xlink:href=\"https://gdal.org/user/"
"link> et ensuite traitée dans les exemples <xref linkend=\"RT_ST_Rescale\"/>"
#. Tag: para
@@ -39359,14 +39359,14 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
"Pour contrôler ce comportement, GDAL fournit la variable d'environnement "
-"suivante : <link xlink:href=\"https://trac.osgeo.org/gdal/wiki/"
+"suivante : <link xlink:href=\"https://gdal.org/user/"
"link>. Définissez <varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> à "
"<varname>TRUE</varname> pour désactiver l'analyse des répertoires."
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 9994f06c6..ac0731c38 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -16273,7 +16273,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -16372,7 +16372,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -16471,8 +16471,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -31112,8 +31112,8 @@ msgstr "argomenti da passare alla funzione utente."
#, no-c-format
msgid ""
msgstr ""
@@ -32632,8 +32632,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 5ffccc7d7..12d51e9c1 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -18124,11 +18124,11 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"GDAL_DATAに関する追加情報報は、GDALの<link xlink:href=\"http://trac.osgeo."
-"org/gdal/wiki/ConfigOptions\">Configuration Options</link>にあります。"
+"org/gdal/wiki/configoptions.html\">Configuration Options</link>にあります。"
#. Tag: para
#, no-c-format
@@ -18251,11 +18251,11 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"GDAL_SKIPに関する追加情報は、GDALの<link xlink:href=\"http://trac.osgeo.org/"
-"gdal/wiki/ConfigOptions\">Configuration Options</link>にあります。"
+"gdal/wiki/configoptions.html\">Configuration Options</link>にあります。"
#. Tag: para
#, no-c-format
@@ -18380,14 +18380,14 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
"データベース外ラスタを操作する時に使用するオプションを設定するためのコンフィ"
-"ギュレーション。<link xlink:href=\"http://trac.osgeo.org/gdal/wiki/"
-"ConfigOptions\">Configuration options</link>によって、どれだけGDALがローカル"
+"ギュレーション。<link xlink:href=\"https://gdal.org/user/"
+"configoptions.html\">Configuration options</link>によって、どれだけGDALがローカル"
"データキャッシュを確保するか、オーバビューを読むかどうか、リモートのデータ"
"ベース外データソースを使う際のアクセスキー等を制御します。"
@@ -35495,12 +35495,12 @@ msgstr "ユーザ定義関数に渡される引数です。"
#, no-c-format
msgid ""
msgstr ""
"単一タイルとしてロードされたカトリーナのラスタを使った例です。<link xlink:"
-"href=\"http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html\">http://trac."
+"href=\"https://gdal.org/user/drivers/raster/postgisraster.html\">http://trac."
"osgeo.org/gdal/wiki/frmts_wtkraster.html</link>に説明があります。また、<xref "
"linkend=\"RT_ST_Rescale\"/>の例で準備を行っています"
@@ -37405,14 +37405,14 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
"この振る舞いを制御するために、GDALには<link xlink:href=\"https://trac.osgeo."
"org/gdal/wiki/"
"link>という環境変数があります。<varname>GDAL_DISABLE_READDIR_ON_OPEN</"
"varname>を<varname>TRUE</varname>に設定すると、ディレクトリのスキャンを無効に"
"します。"
diff --git a/doc/po/ka/postgis-manual.po b/doc/po/ka/postgis-manual.po
index 7382e4a1e..026effafa 100644
--- a/doc/po/ka/postgis-manual.po
+++ b/doc/po/ka/postgis-manual.po
@@ -14562,7 +14562,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14661,7 +14661,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14760,8 +14760,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -28436,8 +28436,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -29950,8 +29950,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index 1e5ca2aa3..9848aeb0d 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
@@ -16523,10 +16523,10 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
-"GDAL의 <link xlink:href=\"http://trac.osgeo.org/gdal/wiki/ConfigOptions\">설"
+"GDAL의 <link xlink:href=\"https://gdal.org/user/configoptions.html\">설"
"정 옵션</link> 페이지에서 GDAL_DATA에 대한 추가 정보를 찾아볼 수 있습니다."
#. Tag: para
@@ -16652,11 +16652,11 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"GDAL_SKIP에 대한 추가 정보는 GDAL의 <link xlink:href=\"http://trac.osgeo.org/"
-"gdal/wiki/ConfigOptions\">Configuration Options</link> 에서 찾아볼 수 있습니"
+"gdal/wiki/configoptions.html\">Configuration Options</link> 에서 찾아볼 수 있습니"
"다."
#. Tag: para
@@ -16771,8 +16771,8 @@ msgstr "DB 외부 래스터 밴드에 접근할 수 있게 해주는 불 설정
#, no-c-format
msgid ""
msgstr ""
@@ -32498,12 +32498,12 @@ msgstr "사용자 함수로 넘겨줄 인수들"
#, no-c-format
msgid ""
msgstr ""
-"다음 예시는 <link xlink:href=\"http://trac.osgeo.org/gdal/wiki/"
+"다음 예시는 <link xlink:href=\"https://gdal.org/user/"
"link> 에서 설명하는 대로 단일 타일로 불러온 다음 <xref "
"linkend=\"RT_ST_Rescale\"/> 예시 대로 준비한 카트리나 래스터를 활용합니다."
@@ -34405,8 +34405,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index c1ec28b4e..96b2ba8a2 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
@@ -14644,7 +14644,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14743,7 +14743,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14842,8 +14842,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -28630,8 +28630,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -30144,8 +30144,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index e20ce1d2e..a2c7278e6 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
@@ -16673,11 +16673,11 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"Informação adicional sobre o GDAL_DATA está disponível em GDAL's <link xlink:"
"Options</link>."
#. Tag: para
@@ -16803,11 +16803,11 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"Informações adicionais sobre GDAL_SKIP estão disponíveis em <link xlink:"
-"href=\"http://trac.osgeo.org/gdal/wiki/ConfigOptions\">Opções de "
+"href=\"https://gdal.org/user/configoptions.html\">Opções de "
"Configuração</link>. "
#. Tag: para
@@ -16925,8 +16925,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -32858,13 +32858,13 @@ msgstr "Argumentos para passar dentro da função usuário. "
#, no-c-format
msgid ""
msgstr ""
"Exemplos utilizam o raster katrina carregado como única tile descrita em "
-"html\">http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html</link> e "
+"html\">https://gdal.org/user/drivers/raster/postgisraster.html</link> e "
"preparada nos exemplos <xref linkend=\"RT_ST_Rescale\"/>"
#. Tag: para
@@ -34813,8 +34813,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index 0324b6e08..bb65e4943 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
@@ -14597,7 +14597,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14696,7 +14696,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14795,8 +14795,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -28471,8 +28471,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -29985,8 +29985,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index ae7edff74..3b0ea7c84 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
@@ -14614,7 +14614,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14713,7 +14713,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14812,8 +14812,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -28488,8 +28488,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -30002,8 +30002,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index dd6beb79b..7e9b18a3a 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -14560,7 +14560,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14659,7 +14659,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14758,8 +14758,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -28434,8 +28434,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -29948,8 +29948,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 4773d757e..7a5d1baea 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
@@ -14564,7 +14564,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14663,7 +14663,7 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
@@ -14762,8 +14762,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -28438,8 +28438,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
@@ -29952,8 +29952,8 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 492d4b0f2..bfc94575b 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -17009,11 +17009,11 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"有关 GDAL_DATA 的其他信息可在 GDAL 的<link xlink:href=\"http://trac.osgeo."
-"org/gdal/wiki/ConfigOptions\">配置选项</link>中找到。"
+"org/gdal/wiki/configoptions.html\">配置选项</link>中找到。"
#. Tag: para
#, no-c-format
@@ -17133,11 +17133,11 @@ msgstr ""
#, no-c-format
msgid ""
"Options</link>."
msgstr ""
"有关 GDAL_SKIP 的其他信息可在 GDAL 的<link xlink:href=\"http://trac.osgeo."
#. Tag: para
#, no-c-format
@@ -17250,13 +17250,13 @@ msgstr "用于设置处理外部数据库栅格时使用的选项的字符串配
#, no-c-format
msgid ""
msgstr ""
"用于设置处理外部数据库栅格时使用的选项的字符串配置。 <link xlink:"
-"href=\"http://trac.osgeo.org/gdal/wiki/ConfigOptions\">配置选项</link>控制诸"
+"href=\"https://gdal.org/user/configoptions.html\">配置选项</link>控制诸"
"如 GDAL 分配给本地数据缓存的空间大小、是否读取概述以及对远程 out-db 数据源使"
"用哪些访问键等内容。"
@@ -33501,12 +33501,12 @@ msgstr "要传递给用户函数的参数。"
#, no-c-format
msgid ""
msgstr ""
-"示例利用 <link xlink:href=\"http://trac.osgeo.org/gdal/wiki/frmts_wtkraster."
-"html\">http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html</link> 中描述的作"
+"示例利用 <link xlink:href=\"https://gdal.org/user/drivers/raster/postgisraster."
+"html\">https://gdal.org/user/drivers/raster/postgisraster.html</link> 中描述的作"
"为单个图块加载的卡特里娜栅格,然后在 <xref linkend=\"RT_ST_Rescale\"/> 示例中"
"准备"
@@ -35322,14 +35322,14 @@ msgstr ""
#, no-c-format
msgid ""
msgstr ""
"为了控制此行为,GDAL 提供了以下环境变量: <link xlink:href=\"https://trac."
"osgeo.org/gdal/wiki/"
"link>。 将 <varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> 设置为<varname> "
"TRUE </varname>以禁用目录扫描。"
diff --git a/doc/reference_guc.xml b/doc/reference_guc.xml
index 6e423ebbf..615150ed6 100644
--- a/doc/reference_guc.xml
+++ b/doc/reference_guc.xml
@@ -35,7 +35,7 @@ These can be set globally, by database, by session or by transaction. Best set a
<note>
<para>
- Additional information about GDAL_DATA is available at GDAL's <link xlink:href="http://trac.osgeo.org/gdal/wiki/ConfigOptions">Configuration Options</link>.
+ Additional information about GDAL_DATA is available at GDAL's <link xlink:href="https://gdal.org/user/configoptions.html">Configuration Options</link>.
</para>
</note>
@@ -114,7 +114,7 @@ SET postgis.gdal_datapath = 'C:/Program Files/PostgreSQL/9.3/gdal-data';</progra
<note>
<para>
- Additional information about GDAL_SKIP is available at GDAL's <link xlink:href="http://trac.osgeo.org/gdal/wiki/ConfigOptions">Configuration Options</link>.
+ Additional information about GDAL_SKIP is available at GDAL's <link xlink:href="https://gdal.org/user/configoptions.html">Configuration Options</link>.
</para>
</note>
@@ -241,7 +241,7 @@ SELECT pg_reload_conf();
<refsection>
<title>Description</title>
<para>
- A string configuration to set options used when working with an out-db raster. <link xlink:href="http://trac.osgeo.org/gdal/wiki/ConfigOptions">Configuration options</link> control things like how much space GDAL allocates to local data cache, whether to read overviews, and what access keys to use for remote out-db data sources.
+ A string configuration to set options used when working with an out-db raster. <link xlink:href="https://gdal.org/user/configoptions.html">Configuration options</link> control things like how much space GDAL allocates to local data cache, whether to read overviews, and what access keys to use for remote out-db data sources.
</para>
<para role="availability" conformance="3.2.0">Availability: 3.2.0</para>
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index d73950455..e283dd77c 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -12272,7 +12272,7 @@ SELECT ST_MapAlgebraFct(m1.rast, 1, m1.rast, 3,
<refsection>
<title>Examples</title>
- <para>Examples utilize the katrina raster loaded as a single tile described in <link xlink:href="http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html">http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html</link> and then prepared in the <xref linkend="RT_ST_Rescale"/> examples </para>
+ <para>Examples utilize the katrina raster loaded as a single tile described in <link xlink:href="https://gdal.org/user/drivers/raster/postgisraster.html">https://gdal.org/user/drivers/raster/postgisraster.html</link> and then prepared in the <xref linkend="RT_ST_Rescale"/> examples </para>
<programlisting>
@@ -16057,7 +16057,7 @@ SELECT r1.rid, r2.rid, ST_DFullyWithin(r1.rast, 1, r2.rast, 1, 3.14) FROM dummy_
When GDAL opens a file, GDAL eagerly scans the directory of that file to build a catalog of other files. If this directory contains many files (e.g. thousands, millions), opening that file becomes extremely slow (especially if that file happens to be on a network drive such as NFS).
</para>
<para>
- To control this behavior, GDAL provides the following environment variable: <link xlink:href="https://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_DISABLE_READDIR_ON_OPEN">GDAL_DISABLE_READDIR_ON_OPEN</link>. Set <varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> to <varname>TRUE</varname> to disable directory scanning.
+ To control this behavior, GDAL provides the following environment variable: <link xlink:href="https://gdal.org/user/configoptions.html#config-GDAL_DISABLE_READDIR_ON_OPEN">GDAL_DISABLE_READDIR_ON_OPEN</link>. Set <varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> to <varname>TRUE</varname> to disable directory scanning.
</para>
<para>
Summary of changes:
doc/po/da/postgis-manual.po | 16 ++++++++--------
doc/po/de/postgis-manual.po | 34 +++++++++++++++++-----------------
doc/po/es/postgis-manual.po | 16 ++++++++--------
doc/po/fr/postgis-manual.po | 34 +++++++++++++++++-----------------
doc/po/it_IT/postgis-manual.po | 16 ++++++++--------
doc/po/ja/postgis-manual.po | 28 ++++++++++++++--------------
doc/po/ka/postgis-manual.po | 16 ++++++++--------
doc/po/ko_KR/postgis-manual.po | 24 ++++++++++++------------
doc/po/pl/postgis-manual.po | 16 ++++++++--------
doc/po/pt_BR/postgis-manual.po | 24 ++++++++++++------------
doc/po/ro/postgis-manual.po | 16 ++++++++--------
doc/po/ru/postgis-manual.po | 16 ++++++++--------
doc/po/templates/postgis-manual.pot | 16 ++++++++--------
doc/po/uk/postgis-manual.po | 16 ++++++++--------
doc/po/zh_Hans/postgis-manual.po | 28 ++++++++++++++--------------
doc/reference_guc.xml | 6 +++---
doc/reference_raster.xml | 4 ++--
17 files changed, 163 insertions(+), 163 deletions(-)
hooks/post-receive
