[SCM] PostGIS branch master updated. 3.5.0-426-g784f21a1f
git at osgeo.org
git at osgeo.org
Thu Jul 3 23:14:30 PDT 2025
the project "PostGIS".
via 784f21a1fd90246aba1c250a2729ccf2de29b7f1 (commit)
from b1655479417ce4e6a633e6f4ed0ace5f6bd1990b (commit)
revisions in full, below.
commit 784f21a1fd90246aba1c250a2729ccf2de29b7f1
Author: Daniel Nylander <daniel at danielnylander.se>
Date: Fri Jul 4 05:33:36 2025 +0000
Translated PostGIS Manual using Weblate (Swedish)
Currently translated at 100.0% (5807 of 5807 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/sv/
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index d87984d9c..8219ad861 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -5,10 +5,10 @@ msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-05-18 00:48+0000\n"
-"PO-Revision-Date: 2025-06-19 21:47+0000\n"
+"PO-Revision-Date: 2025-07-04 06:14+0000\n"
"Last-Translator: Daniel Nylander <daniel at danielnylander.se>\n"
-"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/sv/>\n"
+"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/sv/>\n"
"Language: sv\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
@@ -18551,6 +18551,9 @@ msgid ""
"href=\"https://gdal.org/user/configoptions.html\">Configuration Options</"
"link>."
msgstr ""
+"Ytterligare information om GDAL_DATA finns på GDAL:s <link "
+"xlink:href=”https://gdal.org/user/configoptions."
+"html”>konfigurationsalternativ</link>."
#. Tag: para
#, no-c-format
@@ -18680,6 +18683,9 @@ msgid ""
"link>."
msgstr ""
+"Ytterligare information om GDAL_SKIP finns på GDAL:s <link "
#. Tag: para
#, no-c-format
@@ -18813,6 +18819,11 @@ msgid ""
"allocates to local data cache, whether to read overviews, and what access "
"keys to use for remote out-db data sources."
msgstr ""
+"En strängkonfiguration för att ställa in alternativ som används när du "
+"arbetar med en out-db-raster. <link xlink:href=”https://gdal.org/user/"
+"configoptions.html”>Konfigurationsalternativ</link> styr saker som hur "
+"mycket utrymme GDAL tilldelar lokal datacache, om översikter ska läsas och "
+"vilka åtkomstnycklar som ska användas för fjärranslutna out-db-datakällor."
#. Tag: para
#, no-c-format
@@ -36463,6 +36474,10 @@ msgid ""
"html\">https://gdal.org/user/drivers/raster/postgisraster.html</link> and "
"then prepared in the <xref linkend=\"RT_ST_Rescale\"/> examples"
msgstr ""
+"Exemplen använder katrina-raster som lästs in som en enda bricka som "
+"beskrivs i <link xlink:href=”https://gdal.org/user/drivers/raster/"
+"postgisraster.html”>https://gdal.org/user/drivers/raster/postgisraster.html</"
+"link> och sedan förberetts i exemplen <xref linkend=\"RT_ST_Rescale\"/>"
#. Tag: para
#, no-c-format
@@ -38425,6 +38440,11 @@ msgid ""
"<varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> to <varname>TRUE</varname> "
"to disable directory scanning."
msgstr ""
+"För att kontrollera detta beteende tillhandahåller GDAL följande "
+"miljövariabel: <link xlink:href=”https://gdal.org/user/configoptions.html"
+"#config-GDAL_DISABLE_READDIR_ON_OPEN”>GDAL_DISABLE_READDIR_ON_OPEN</link>. "
+"Ställ in <varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> till <varname>TRUE</"
+"varname> för att inaktivera katalogsökning."
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/sv/postgis-manual.po | 26 +++++++++++++++++++++++---
1 file changed, 23 insertions(+), 3 deletions(-)
hooks/post-receive
