[SCM] PostGIS branch master updated. 3.5.0-428-ga4886d858
git at osgeo.org
git at osgeo.org
Fri Jul 4 21:00:24 PDT 2025
the project "PostGIS".
via a4886d8581d307a132ac19a3f7c5052e6de65657 (commit)
from c8de602d6025adc6c16644d348e90e039dc5629f (commit)
revisions in full, below.
commit a4886d8581d307a132ac19a3f7c5052e6de65657
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jul 4 20:59:19 2025 -0700
Handle case in new GEOS prepared ST_Relate code where the
order of operands changes based on which operand is cachable,
requiring the inversion of the DE9IM matrix to match the
new order. Closes #5938
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index a97d82216..1cd9cbba0 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -880,6 +880,19 @@ Datum coveredby(PG_FUNCTION_ARGS)
PG_RETURN_BOOL(result);
+ * Flip the DE9IM matrix around the diagonal to
+ * account for flipping the order of the operands
+ * to the GEOSPreparedRelatePattern function.
+static void
+imInvert(char *im)
+ char t;
+ t = im[1]; im[1] = im[3]; im[3] = t;
+ t = im[2]; im[2] = im[6]; im[6] = t;
+ t = im[5]; im[5] = im[7]; im[7] = t;
PG_FUNCTION_INFO_V1(relate_pattern);
Datum relate_pattern(PG_FUNCTION_ARGS)
@@ -890,11 +903,11 @@ Datum relate_pattern(PG_FUNCTION_ARGS)
const GSERIALIZED *geom2 = shared_gserialized_get(shared_geom2);
/* Ensure DE9IM pattern is no more than 9 chars */
- text *patt = DatumGetTextP(DirectFunctionCall2(text_left,
+ text *imPtr = DatumGetTextP(DirectFunctionCall2(text_left,
PG_GETARG_DATUM(2), Int32GetDatum(9)));
- char *pstr = text_to_cstring(patt);
+ char *im = text_to_cstring(imPtr);
char result;
- size_t i;
+ uint32_t i;
#if POSTGIS_GEOS_VERSION >= 31300
PrepGeomCache *prep_cache;
#endif
@@ -904,11 +917,8 @@ Datum relate_pattern(PG_FUNCTION_ARGS)
** Need to make sure 't' and 'f' are upper-case before handing to GEOS
- for ( i = 0; i < strlen(pstr); i++ )
- if ( pstr[i] == 't' ) pstr[i] = 'T';
- if ( pstr[i] == 'f' ) pstr[i] = 'F';
+ for (i = 0; i < strlen(im); i++)
+ im[i] = toupper(im[i]);
initGEOS(lwpgnotice, lwgeom_geos_error);
@@ -916,11 +926,19 @@ Datum relate_pattern(PG_FUNCTION_ARGS)
prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, shared_geom2);
if ( prep_cache && prep_cache->prepared_geom )
- GEOSGeometry *g = prep_cache->gcache.argnum == 1
- ? POSTGIS2GEOS(geom2)
- : POSTGIS2GEOS(geom1);
+ GEOSGeometry *g = NULL;
+ if (prep_cache->gcache.argnum == 1)
+ g = POSTGIS2GEOS(geom2);
+ else
+ g = POSTGIS2GEOS(geom1);
+ imInvert(im);
if (!g) HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
- result = GEOSPreparedRelatePattern(prep_cache->prepared_geom, g, pstr);
+ result = GEOSPreparedRelatePattern(prep_cache->prepared_geom, g, im);
GEOSGeom_destroy(g);
else
@@ -935,12 +953,12 @@ Datum relate_pattern(PG_FUNCTION_ARGS)
HANDLE_GEOS_ERROR("Second argument geometry could not be converted to GEOS");
GEOSGeom_destroy(g1);
- result = GEOSRelatePattern(g1, g2, pstr);
+ result = GEOSRelatePattern(g1, g2, im);
GEOSGeom_destroy(g2);
- pfree(pstr);
+ pfree(im);
if (result == 2) HANDLE_GEOS_ERROR("GEOSRelatePattern");
Summary of changes:
postgis/lwgeom_geos_predicates.c | 46 ++++++++++++++++++++++++++++------------
1 file changed, 32 insertions(+), 14 deletions(-)
hooks/post-receive
