[PostGIS] #5939: regress/core/coverage failure on latest geos
trac at osgeo.org
Tue Jul 8 20:20:06 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 3.5.x
Keywords: |
Yah I know looks like wrong folder, I forgot to flip after 3.13, so issue
is real at anyrate.
Seems to have started a couple hours ago
16:23:01 -------------- Dependencies --------------
16:23:01 GEOS config:
/var/lib/jenkins/workspace/geos/rel-3.13w64/bin/geos-config
16:23:01 GEOS version: 3.14.0dev (31400)
16:23:01 GDAL config:
/var/lib/jenkins/workspace/gdal/rel-3.10w64/bin/gdal-config
16:23:01 GDAL version: 3.10.3dev (31003)
16:23:01 SFCGAL config: /usr/bin/sfcgal-config
16:23:01 SFCGAL version: 1.3.8
16:23:01 PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg15w64/bin/pg_config
16:23:01 PostgreSQL version: PostgreSQL 15.13
16:23:01 PROJ version: 7.2.1 (70201)
16:23:01 Libxml2 config: /usr/bin/xml2-config
16:23:01 Libxml2 version: 2.9.14
16:23:01 JSON-C support: yes
16:23:01 protobuf support: yes
16:23:01 protobuf-c version: 1003003
16:23:01 PCRE support: not found
16:23:01 Perl: /usr/bin/perl
16:28:07 regress/core/coverage .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/3_6_pg15w64/test_123_diff)
16:28:08
16:28:08 --- ./regress/core/coverage_expected 2025-05-28
06:12:08.308255786 +0000
16:28:08 +++
/var/lib/jenkins/workspace/postgis/tmp/3_6_pg15w64/test_123_out
2025-07-08 20:28:08.064891860 +0000
16:28:08 @@ -15,7 +15,7 @@
16:28:08 three partition b|1|200
16:28:08 three partition b|2|200
16:28:08 three partition b|3|
16:28:08 -union 2|2.05|ST_MultiPolygon
16:28:08 +ERROR: Error computing coverage union: TopologyException: side
location conflict at 1 0. This can occur if the input geometry is invalid.
16:28:08 union 3|2|ST_Polygon
16:28:08 grid lanes|0|110000
16:28:08 grid lanes|1|110000
16:28:08
16:28:08 regress/core/interrupt .. ok in 246 ms
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5939>
