[SCM] PostGIS branch master updated. 3.5.0-434-g17e9f112c
Tue Jul 8 20:47:47 PDT 2025
the project "PostGIS".
       via  17e9f112cff88f5f484414843d686da18c2f393b (commit)
       via  304913cc087a140f58f8aef129d1f732f2440bd4 (commit)
      from  3724e0f256c8bd19828eda9ea0b89e330ba1ab0b (commit)
revisions in full, below.
commit 17e9f112cff88f5f484414843d686da18c2f393b
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Jul 8 23:47:10 2025 -0400
    Take out coverage test failing in GEOS 3.14 because of behavior change
    References #5939 for PostGIS 3.6.0
diff --git a/regress/core/coverage.sql b/regress/core/coverage.sql
index f0d1f5a9b..9c456410c 100644
--- a/regress/core/coverage.sql
+++ b/regress/core/coverage.sql
@@ -53,7 +53,7 @@ SELECT 'three partition b' AS test,
 FROM coverage GROUP BY id ORDER BY id;
-TRUNCATE coverage;
+/**TRUNCATE coverage;
 INSERT INTO coverage VALUES
 (4, 1, 'POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))'),
 (4, 2, 'POLYGON ((1 0, 0.9 1, 2 1, 2 0, 1 0))');
@@ -63,7 +63,7 @@ WITH u AS (
 SELECT 'union 2' AS test,
   ST_Area(geom), ST_GeometryType(geom)
-FROM u;
+FROM u;**/
 TRUNCATE coverage;
diff --git a/regress/core/coverage_expected b/regress/core/coverage_expected
index 5d19e968a..2b456107a 100644
--- a/regress/core/coverage_expected
+++ b/regress/core/coverage_expected
@@ -15,7 +15,6 @@ three partition a|3|2|||
 three partition b|1|200
 three partition b|2|200
 three partition b|3|
-union 2|2.05|ST_MultiPolygon
 union 3|2|ST_Polygon
 grid lanes|0|110000
 grid lanes|1|110000
commit 304913cc087a140f58f8aef129d1f732f2440bd4
Date:   Tue Jul 8 23:44:49 2025 -0400
    update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 7e9b18a3a..0275c2945 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -8021,6 +8021,11 @@ msgstr ""
 msgid "Dane Springmeyer"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Daniel Nylander"
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "Dapeng Wang"
@@ -8236,6 +8241,11 @@ msgstr ""
 msgid "Kris Jurka"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Laurențiu Nicola"
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "Laurenz Albe"
@@ -8266,6 +8276,11 @@ msgstr ""
 msgid "Lucas C. Villa Real"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Maksim Korotkov"
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "Maria Arias de Reyna"
@@ -8688,6 +8703,11 @@ msgstr ""
 msgid "Paragon Corporation"
 msgstr ""
+#. Tag: link
+#, no-c-format
+msgid "Postgres Pro"
+msgstr ""
 #. Tag: link
 #, no-c-format
 msgid "R3 GIS"
@@ -12871,8 +12891,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"ST_CoverageUnion\"/>, <xref "
-"linkend=\"ST_CoverageSimplify\"/>"
+", <xref linkend=\"ST_CoverageUnion\"/>, <xref linkend=\"ST_CoverageClean\"/"
+">, <xref linkend=\"ST_CoverageSimplify\"/>"
 msgstr ""
 #. Tag: refpurpose
@@ -12926,6 +12946,12 @@ msgstr ""
 msgid "Simplified coverage"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_CoverageUnion\"/>, <xref linkend=\"ST_CoverageClean\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -12961,6 +12987,84 @@ msgstr ""
 msgid "Union result"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_CoverageSimplify\"/>, <xref "
+"linkend=\"ST_CoverageClean\"/>, <xref linkend=\"ST_Union\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Computes a clean (edge matched, non-overlapping, gap-cleared) polygonal "
+"coverage, given a non-clean input."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A window function which alters the edges of a polygonal coverage to ensure "
+"that none of the polygons overlap, that small gaps are snapped away, and "
+"that all shared edges are exactly identical. The result is a clean coverage "
+"that will pass validation tests like <xref "
+"linkend=\"ST_CoverageInvalidEdges\"/>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <parameter>gapMaximumWidth</parameter> controls the cleaning of gaps "
+"between polygons. Gaps smaller than this tolerance will be closed."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <parameter>snappingDistance</parameter> controls the node snapping step, "
+"when nearby vertices are snapped together. The default setting (-1) applies "
+"an automatic snapping distance based on an analysis of the input. Set to 0.0 "
+"to turn off all snapping."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <parameter>overlapMergeStrategy</parameter> controls the algorithm used "
+"to determine which neighboring polygons to merge overlapping areas into."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<code>MERGE_LONGEST_BORDER</code> chooses polygon with longest common border"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<code>MERGE_MAX_AREA</code> chooses polygon with maximum area"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<code>MERGE_MIN_AREA</code> chooses polygon with minimum area"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<code>MERGE_MIN_INDEX</code> chooses polygon with smallest input index"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.6.0 - requires GEOS >= 3.14.0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_Union\"/> <xref linkend=\"ST_CoverageSimplify\"/>"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Geometry Editors"
@@ -14560,8 +14664,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Additional information about GDAL_DATA is available at GDAL's <link xlink:"
-"href=\"https://gdal.org/user/configoptions.html\">Configuration "
-"Options</link>."
+"href=\"https://gdal.org/user/configoptions.html\">Configuration Options</"
+"link>."
 msgstr ""
 #. Tag: para
@@ -14659,8 +14763,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Additional information about GDAL_SKIP is available at GDAL's <link xlink:"
-"Options</link>."
+"link>."
 msgstr ""
 #. Tag: para
@@ -14758,10 +14862,10 @@ msgstr ""
 #, no-c-format
 msgid ""
 "A string configuration to set options used when working with an out-db "
-"raster. <link xlink:href=\"https://gdal.org/user/"
-"configoptions.html\">Configuration options</link> control things like how much "
-"space GDAL allocates to local data cache, whether to read overviews, and "
-"what access keys to use for remote out-db data sources."
+"raster. <link xlink:href=\"https://gdal.org/user/configoptions."
+"html\">Configuration options</link> control things like how much space GDAL "
+"allocates to local data cache, whether to read overviews, and what access "
+"keys to use for remote out-db data sources."
 msgstr ""
 #. Tag: para
@@ -18984,8 +19088,9 @@ msgid ""
 "Returns the OGC/ISO <link linkend=\"OpenGISWKBWKT\">Well-Known Binary</link> "
 "(WKB) representation of the geometry. The first function variant defaults to "
 "encoding using server machine endian. The second function variant takes a "
-"text argument specifying the endian encoding, either little-endian ('NDR') "
-"or big-endian ('XDR')."
+"text argument specifying the endian encoding: either 'NDR' for little-"
+"endian; or 'XDR' for big-endian. Supplying unknown arguments will result in "
+"little-endian output."
 msgstr ""
 #. Tag: para
@@ -19071,8 +19176,9 @@ msgid ""
 "Returns the <link linkend=\"EWKB_EWKT\">Extended Well-Known Binary</link> "
 "(EWKB) representation of the geometry with SRID metadata. The first function "
 "variant defaults to encoding using server machine endian. The second "
-"function variant takes a text argument specifying the endian encoding, "
-"either little-endian ('NDR') or big-endian ('XDR')."
+"function variant takes a text argument specifying the endian encoding: "
+"either 'NDR' for little-endian; or 'XDR' for big-endian. Supplying unknown "
+"arguments will result in little-endian output."
 msgstr ""
 #. Tag: para
@@ -21146,10 +21252,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Buffer output is always a valid polygonal geometry. Buffer can handle "
-"invalid inputs, so buffering by distance 0 is sometimes used as a way of "
-"repairing invalid polygons. <xref linkend=\"ST_MakeValid\"/> can also be "
-"used for this purpose."
+"Buffer can handle invalid inputs and the output is always a valid polygonal "
+"geometry. Buffering by distance 0 is sometimes used as a way of repairing "
+"invalid polygons. <xref linkend=\"ST_MakeValid\"/> is more suitable for this "
+"process as it can handle multi-polygons."
 msgstr ""
 #. Tag: para
@@ -23008,17 +23114,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"The functions given below are the ones which a user of PostGIS Raster is "
-"likely to need and which are currently available in PostGIS Raster. There "
-"are other functions which are required support functions to the raster "
-"objects which are not of use to a general user."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<varname>raster</varname> is a new PostGIS type for storing and analyzing "
-"raster data."
+"<varname>raster</varname> is a PostGIS type for storing and analyzing raster "
+"data."
 msgstr ""
 #. Tag: para
@@ -23031,8 +23128,16 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"For the examples in this reference we will be using a raster table of dummy "
-"rasters - Formed with the following code"
+"Some examples in this reference use a raster table of dummy data, created "
+"with the following code:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The functions below are ones which a user of PostGIS Raster is likely to "
+"need. There are other raster support functions which are not of interest to "
+"a general user."
 msgstr ""
 #. Tag: title
@@ -23155,15 +23260,15 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
-"<refpurpose>A composite type used as input into the ST_Reclass function "
-"defining the behavior of reclassification.</refpurpose>"
+"A composite type used as input into the ST_Reclass function defining the "
+"behavior of reclassification."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"<para>A composite type used as input into the ST_Reclass function defining "
-"the behavior of reclassification.</para>"
+"A composite type used as input into the <xref linkend=\"RT_ST_Reclass\"/> "
+"function defining the behavior of reclassification."
 msgstr ""
 #. Tag: para
@@ -26539,7 +26644,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Returns summarystats consisting of count, sum, mean, stddev, min, max for a "
-"given raster band of a raster or raster coverage. Band 1 is assumed is no "
+"given raster band of a raster or raster coverage. Band 1 is assumed if no "
 "band is specified."
 msgstr ""
@@ -26607,7 +26712,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Aggregate. Returns summarystats consisting of count, sum, mean, stddev, min, "
-"max for a given raster band of a set of raster. Band 1 is assumed is no band "
+"max for a given raster band of a set of raster. Band 1 is assumed if no band "
 "is specified."
 msgstr ""
@@ -28435,8 +28540,8 @@ msgstr ""
 msgid ""
 "Examples utilize the katrina raster loaded as a single tile described in "
 "<link xlink:href=\"https://gdal.org/user/drivers/raster/postgisraster."
-"html\">https://gdal.org/user/drivers/raster/postgisraster.html</link> and then "
-"prepared in the <xref linkend=\"RT_ST_Rescale\"/> examples"
+"html\">https://gdal.org/user/drivers/raster/postgisraster.html</link> and "
+"then prepared in the <xref linkend=\"RT_ST_Rescale\"/> examples"
 msgstr ""
 #. Tag: para
@@ -28467,21 +28572,26 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Creates a new raster formed by applying a valid PostgreSQL algebraic "
-"operation defined by the <varname>reclassexpr</varname> on the input raster "
-"(<varname>rast</varname>). If no <varname>band</varname> is specified band 1 "
-"is assumed. The new raster will have the same georeference, width, and "
-"height as the original raster. Bands not designated will come back "
-"unchanged. Refer to <xref linkend=\"reclassarg\"/> for description of valid "
-"reclassification expressions."
+"Creates a new raster formed by applying a reclassification operation defined "
+"by the <varname>reclassexpr</varname> on the input raster (<varname>rast</"
+"varname>). Refer to <xref linkend=\"reclassarg\"/> for the description of "
+"reclassification expressions. If no <varname>band</varname> is specified "
+"band 1 is assumed."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"The bands of the new raster will have pixel type of <varname>pixeltype</"
-"varname>. If <varname>reclassargset</varname> is passed in then each "
-"reclassarg defines behavior of each band generated."
+"The new raster will have the same georeference, width, and height as the "
+"original raster. The bands of the new raster have pixel type of "
+"<varname>pixeltype</varname>. If <varname>reclassargset</varname> is "
+"specified then each <varname>reclassarg</varname> defines the type of the "
+"target band. Bands not designated are returned unchanged."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Example: Basic"
 msgstr ""
 #. Tag: para
@@ -28526,6 +28636,51 @@ msgid ""
 "<xref linkend=\"RT_ST_Value\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Creates a new raster composed of bands reclassified from original, using a "
+"1:1 mapping from values in the original band to new values in the "
+"destination band."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"by the <varname>inputvalues</varname> and <varname>outputvalues</varname> "
+"arrays. Pixel values found in the input array are mapped to the "
+"corresponding value in the output array. All other pixel values are mapped "
+"to the <varname>nodatavalue</varname>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The output pixel type defaults to float, but can be specified using the "
+"<varname>pixeltype</varname> parameter. If no <varname>bandnumber</varname> "
+"is specified band 1 is assumed."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"original raster. Bands not designated are returned unchanged."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Create a small raster and map its pixels to new values."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"RT_ST_AddBand\"/>, <xref linkend=\"RT_ST_Band\"/>, <xref "
+"linkend=\"RT_ST_MakeEmptyRaster\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -29948,10 +30103,10 @@ msgstr ""
 #, no-c-format
 msgid ""
 "To control this behavior, GDAL provides the following environment variable: "
-"<link xlink:href=\"https://gdal.org/user/"
-"configoptions.html#config-GDAL_DISABLE_READDIR_ON_OPEN\">GDAL_DISABLE_READDIR_ON_OPEN</"
-"link>. Set <varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> to <varname>TRUE</"
-"varname> to disable directory scanning."
+"<link xlink:href=\"https://gdal.org/user/configoptions.html#config-"
+"GDAL_DISABLE_READDIR_ON_OPEN\">GDAL_DISABLE_READDIR_ON_OPEN</link>. Set "
+"<varname>GDAL_DISABLE_READDIR_ON_OPEN</varname> to <varname>TRUE</varname> "
+"to disable directory scanning."
 msgstr ""
 #. Tag: para
Summary of changes:
 doc/po/templates/postgis-manual.pot | 255 +++++++++++++++++++++++++++++-------
 regress/core/coverage.sql           |   4 +-
 regress/core/coverage_expected      |   1 -
 3 files changed, 207 insertions(+), 53 deletions(-)
hooks/post-receive
