[SCM] PostGIS branch master updated. 3.5.0-448-ge3e7ae72c
git at osgeo.org
git at osgeo.org
Thu Jul 10 21:33:23 PDT 2025
the project "PostGIS".
via e3e7ae72c1863fd1369ff23555d0acf495d196c9 (commit)
via 1fcce085b4f4be3f0f51c93d7b37514ae14ce91a (commit)
via 39601c33a64116dcb2447705e4276d957e9dfa01 (commit)
via cf378d24aa3e89d1e628927ac42ecd534b6facc6 (commit)
via 54012ef1659aaab0b30e43823ddc6a34a6a6ce5d (commit)
from b077696e7f0cad9361be3d43392a340d77365643 (commit)
revisions in full, below.
commit e3e7ae72c1863fd1369ff23555d0acf495d196c9
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date: Thu Jun 5 10:38:14 2025 +0200
doc(NEWS): Add entry for ST_NumGeometry/ST_GeometryN changes
diff --git a/NEWS b/NEWS
index 583a31c6b..3ebeae776 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,8 @@ Daniel Nylander (Swedish Team)
- #5799, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)
- #5829, remove constraint checking from geometry_columns view (Paul Ramsey)
- #3373, GT-255 [topology] Support for upgrading domains (Ayo Adesugba, U.S. Census Bureau)
+ - GT-252, ST_NumGeometries/ST_GeometryN treat TIN and PolyhedralSurface as unitary geometries,
+ use ST_NumPatches/ST_PatchN for patch access (Loïc Bartoletti)
* Deprecated signatures *
@@ -36,7 +38,7 @@ Daniel Nylander (Swedish Team)
- [raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages
and routes them into the PostgreSQL logging system. (Paul Ramsey)
- #5841, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)
- - Add ST_CoverageClean to edge match and gap remove polygonal
+ - Add ST_CoverageClean to edge match and gap remove polygonal
coverages (Paul Ramsey) from GEOS 3.14 (Martin Davis)
- Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)
commit 1fcce085b4f4be3f0f51c93d7b37514ae14ce91a
Date: Thu Jun 5 09:59:52 2025 +0200
test(PolyhedralSurface): Add tests for NumGeometries and GeometryN
diff --git a/regress/core/polyhedralsurface.sql b/regress/core/polyhedralsurface.sql
index 7c05b3118..dc58cb92d 100644
--- a/regress/core/polyhedralsurface.sql
+++ b/regress/core/polyhedralsurface.sql
@@ -27,3 +27,14 @@ SELECT 'patchN_02', ST_AsEWKT(ST_patchN('POLYHEDRALSURFACE(((0 0,0 0,0 1,0 0)))'
SELECT 'patchN_03', ST_AsEWKT(ST_patchN('POLYHEDRALSURFACE(((0 0,0 0,0 1,0 0)))'::geometry, 0));
SELECT 'patchN_04', ST_AsEWKT(ST_patchN('POLYHEDRALSURFACE(((0 0,0 0,0 1,0 0)))'::geometry, 2));
SELECT 'patchN_05', ST_AsEWKT(ST_patchN('POLYHEDRALSURFACE(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))'::geometry, 2));
+-- ST_NumGeometries
+SELECT 'numgeometries_01', ST_NumGeometries('POLYHEDRALSURFACE EMPTY'::geometry);
+SELECT 'numgeometries_02', ST_NumGeometries('POLYHEDRALSURFACE(((0 0,0 0,0 1,0 0)))'::geometry);
+SELECT 'numgeometries_03', ST_NumGeometries('POLYHEDRALSURFACE(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))'::geometry);
+-- ST_GeometryN
+SELECT 'geometryN_01', ST_AsEWKT(ST_GeometryN('POLYHEDRALSURFACE EMPTY'::geometry, 1));
+SELECT 'geometryN_02', ST_AsEWKT(ST_GeometryN('POLYHEDRALSURFACE(((0 0,0 0,0 1,0 0)))'::geometry, 1));
+SELECT 'geometryN_03', ST_AsEWKT(ST_GeometryN('POLYHEDRALSURFACE(((0 0,0 0,0 1,0 0)))'::geometry, 0));
+SELECT 'geometryN_04', ST_AsEWKT(ST_GeometryN('POLYHEDRALSURFACE(((0 0,0 0,0 1,0 0)))'::geometry, 2));
diff --git a/regress/core/polyhedralsurface_expected b/regress/core/polyhedralsurface_expected
index 7700c04b5..cbfcfa90d 100644
--- a/regress/core/polyhedralsurface_expected
+++ b/regress/core/polyhedralsurface_expected
@@ -14,3 +14,10 @@ patchN_02|POLYGON((0 0,0 0,0 1,0 0))
patchN_03|
patchN_04|
patchN_05|POLYGON((0 0 0,0 1 0,1 0 0,0 0 0))
+numgeometries_01|0
+numgeometries_02|1
+numgeometries_03|1
+geometryN_01|
+geometryN_02|POLYHEDRALSURFACE(((0 0,0 0,0 1,0 0)))
+geometryN_03|
+geometryN_04|
commit 39601c33a64116dcb2447705e4276d957e9dfa01
Date: Thu Jun 5 09:59:26 2025 +0200
fix(lwgeom_ogc): rewrite NumGeometries and GeometryN and add fuctions to NumPatches and PatchN
TIN and PolyhedralSurface are now treated as unitary geometries:
- ST_NumGeometries() returns 1 for non-empty TIN/PolyhedralSurface
- ST_GeometryN() returns the whole geometry for index 1
- ST_NumPatches() preserves original patch counting behavior
- ST_PatchN() provides access to individual patches
- Added lwgeom_has_patches() helper function
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index c7f2633ed..847a1ff6e 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -907,6 +907,11 @@ extern int lwgeom_is_collection(const LWGEOM *lwgeom);
extern int lwgeom_is_unitary(const LWGEOM *geom);
+ * Check if geometry type contains patches
+extern int lwgeom_has_patches(const LWGEOM *geom);
* Is this a type that has rings enclosing an area, but is
* not a collection of areas? (triangle, polygon, curvepolygon)
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 1b26752ee..a40181423 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -1122,6 +1122,20 @@ lwgeom_is_unitary(const LWGEOM *geom)
+int
+lwgeom_has_patches(const LWGEOM *geom)
+ switch (geom->type)
+ case TINTYPE:
+ case POLYHEDRALSURFACETYPE:
+ return LW_TRUE;
+ break;
+ default:
+ return LW_FALSE;
int
lwgeom_has_rings(const LWGEOM *geom)
diff --git a/postgis/lwgeom_ogc.c b/postgis/lwgeom_ogc.c
index bf3b81424..6e9f26912 100644
--- a/postgis/lwgeom_ogc.c
+++ b/postgis/lwgeom_ogc.c
@@ -55,8 +55,12 @@ Datum geometry_geometrytype(PG_FUNCTION_ARGS);
Datum LWGEOM_numpoints_linestring(PG_FUNCTION_ARGS);
/* ---- NumGeometries(geometry) */
Datum LWGEOM_numgeometries_collection(PG_FUNCTION_ARGS);
+/* ---- NumPatches(geometry) */
+Datum LWGEOM_numpatches(PG_FUNCTION_ARGS);
/* ---- GeometryN(geometry, integer) */
Datum LWGEOM_geometryn_collection(PG_FUNCTION_ARGS);
+/* ---- PatchN(geometry, integer) */
+Datum LWGEOM_patchn(PG_FUNCTION_ARGS);
/* ---- Dimension(geometry) */
Datum LWGEOM_dimension(PG_FUNCTION_ARGS);
/* ---- ExteriorRing(geometry) */
@@ -233,6 +237,42 @@ Datum LWGEOM_numpoints_linestring(PG_FUNCTION_ARGS)
PG_RETURN_INT32(count);
+ * Count geometries with patches option
+ * patches_as_geometries = true: count patches as separate geometries (for ST_NumPatches)
+ * patches_as_geometries = false: treat TIN/PolyhedralSurface as unitary geometries (for ST_NumGeometries)
+static int32
+lwgeom_count_geometries(LWGEOM *lwgeom, bool patches_as_geometries)
+ int32 ret = 0;
+ if (lwgeom_is_empty(lwgeom))
+ ret = 0;
+ else if (lwgeom_is_unitary(lwgeom))
+ /* If it's a TIN or PolyhedralSurface and we want to count patches */
+ if (lwgeom_has_patches(lwgeom) && patches_as_geometries)
+ LWCOLLECTION *col = lwgeom_as_lwcollection(lwgeom);
+ ret = col ? col->ngeoms : 1;
+ else
+ ret = 1;
+ else
+ ret = col->ngeoms;
+ return ret;
PG_FUNCTION_INFO_V1(LWGEOM_numgeometries_collection);
@@ -241,24 +281,93 @@ Datum LWGEOM_numgeometries_collection(PG_FUNCTION_ARGS)
int32 ret = 0;
lwgeom = lwgeom_from_gserialized(geom);
- if (lwgeom_is_empty(lwgeom))
- ret = 0;
- else if (lwgeom_is_unitary(lwgeom))
- ret = 1;
- else
- LWCOLLECTION *col = lwgeom_as_lwcollection(lwgeom);
- ret = col->ngeoms;
+ /* TIN and PolyhedralSurface count as 1 geometry, not their patch count */
+ ret = lwgeom_count_geometries(lwgeom, false);
lwgeom_free(lwgeom);
PG_FREE_IF_COPY(geom, 0);
PG_RETURN_INT32(ret);
+PG_FUNCTION_INFO_V1(LWGEOM_numpatches);
+ GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P(0);
+ LWGEOM *lwgeom;
+ int32 ret = 0;
+ lwgeom = lwgeom_from_gserialized(geom);
+ if (!lwgeom_has_patches(lwgeom))
+ lwgeom_free(lwgeom);
+ PG_FREE_IF_COPY(geom, 0);
+ elog(ERROR, "ST_NumPatches only supports TIN and PolyhedralSurface geometries");
+ ret = lwgeom_count_geometries(lwgeom, true);
+ PG_RETURN_INT32(ret);
+ * Extract geometry at given index with patches option
+static LWGEOM*
+lwgeom_extract_geometry_n(LWGEOM *lwgeom, int32 idx, bool patches_as_geometries)
+ LWCOLLECTION *coll = NULL;
+ LWGEOM *subgeom = NULL;
+ /* Empty returns NULL */
+ return NULL;
+ /* Unitary geometries */
+ if (lwgeom_is_unitary(lwgeom))
+ /* If it's a TIN or PolyhedralSurface and we want to access patches */
+ coll = lwgeom_as_lwcollection(lwgeom);
+ if (!coll)
+ /* Single patch case */
+ if (idx == 1)
+ return lwgeom;
+ else
+ return NULL;
+ else
+ /* Standard unitary geometry handling */
+ if (idx == 1)
+ return lwgeom;
+ else
+ return NULL;
+ else
+ if (!coll)
+ return NULL;
+ /* Handle out-of-range index value */
+ idx -= 1;
+ if (idx < 0 || idx >= (int32) coll->ngeoms)
+ return NULL;
+ subgeom = coll->geoms[idx];
+ return subgeom;
/** 1-based offset */
PG_FUNCTION_INFO_V1(LWGEOM_geometryn_collection);
@@ -267,36 +376,58 @@ Datum LWGEOM_geometryn_collection(PG_FUNCTION_ARGS)
LWGEOM *lwgeom = lwgeom_from_gserialized(geom);
GSERIALIZED *result = NULL;
int32 idx = PG_GETARG_INT32(1);
- LWCOLLECTION *coll = NULL;
- /* Empty returns NULL */
+ /* TIN and PolyhedralSurface are treated as unitary geometries */
+ subgeom = lwgeom_extract_geometry_n(lwgeom, idx, false);
+ if (!subgeom)
PG_RETURN_NULL();
- /* Unitary geometries just reflect back */
- if (lwgeom_is_unitary(lwgeom))
+ /* If returning the original geometry */
+ if (subgeom == lwgeom)
+ PG_RETURN_POINTER(geom);
+ subgeom->srid = lwgeom->srid;
+ /* COMPUTE_BBOX==TAINTING */
+ if (lwgeom->bbox) lwgeom_add_bbox(subgeom);
+ result = geometry_serialize(subgeom);
+ PG_RETURN_POINTER(result);
+/** 1-based offset */
+PG_FUNCTION_INFO_V1(LWGEOM_patchn);
+ LWGEOM *lwgeom = lwgeom_from_gserialized(geom);
+ GSERIALIZED *result = NULL;
+ int32 idx = PG_GETARG_INT32(1);
- if ( idx == 1 )
- PG_RETURN_POINTER(geom);
- else
- PG_RETURN_NULL();
+ elog(ERROR, "ST_PatchN only supports TIN and PolyhedralSurface geometries");
- coll = lwgeom_as_lwcollection(lwgeom);
- if (!coll)
- elog(ERROR, "Unable to handle type %d in ST_GeometryN", lwgeom->type);
+ /* Access patches individually */
+ subgeom = lwgeom_extract_geometry_n(lwgeom, idx, true);
- /* Handle out-of-range index value */
- idx -= 1;
- if ( idx < 0 || idx >= (int32) coll->ngeoms )
+ if (!subgeom)
PG_RETURN_NULL();
- subgeom = coll->geoms[idx];
- subgeom->srid = coll->srid;
- if ( coll->bbox ) lwgeom_add_bbox(subgeom);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 6df42c397..38d009eac 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5487,24 +5487,15 @@ CREATE OR REPLACE FUNCTION ST_PointN(geometry,integer)
-- Availability: 2.0.0
CREATE OR REPLACE FUNCTION ST_NumPatches(geometry)
RETURNS integer
- AS '
- SELECT CASE WHEN @extschema at .ST_GeometryType($1) in (''ST_PolyhedralSurface'', ''ST_Tin'')
- THEN @extschema at .ST_NumGeometries($1)
- ELSE NULL END
- LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
+ AS 'MODULE_PATHNAME', 'LWGEOM_numpatches'
+ LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_LOW;
CREATE OR REPLACE FUNCTION ST_PatchN(geometry, integer)
RETURNS geometry
- AS '
- THEN @extschema at .ST_GeometryN($1, $2)
- ELSE NULL END
- _COST_LOW;
+ AS 'MODULE_PATHNAME', 'LWGEOM_patchn'
+ LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
-- PostGIS equivalent function of old StartPoint(geometry))
CREATE OR REPLACE FUNCTION ST_StartPoint(geometry)
commit cf378d24aa3e89d1e628927ac42ecd534b6facc6
Date: Tue May 13 09:27:56 2025 +0200
fix(Collection): PolyhedralSurface and TIN are not collections
index e7cea3de3..1b26752ee 100644
@@ -1112,6 +1112,8 @@ lwgeom_is_unitary(const LWGEOM *geom)
case COMPOUNDTYPE:
case CIRCSTRINGTYPE:
case TRIANGLETYPE:
+ case TINTYPE:
return LW_TRUE;
break;
@@ -1156,7 +1158,7 @@ lwtype_is_collection(uint8_t type)
case MULTICURVETYPE:
case MULTISURFACETYPE:
- case TINTYPE:
+ case TINTYPE:
return LW_TRUE;
break;
commit 54012ef1659aaab0b30e43823ddc6a34a6a6ce5d
Date: Tue May 13 07:17:08 2025 +0200
fix(TIN): Add support for ST_NumPatches and ST_PatchN
index 51fba0988..6df42c397 100644
@@ -5488,7 +5488,7 @@ CREATE OR REPLACE FUNCTION ST_PointN(geometry,integer)
RETURNS integer
AS '
- SELECT CASE WHEN @extschema at .ST_GeometryType($1) = ''ST_PolyhedralSurface''
+ SELECT CASE WHEN @extschema at .ST_GeometryType($1) in (''ST_PolyhedralSurface'', ''ST_Tin'')
ELSE NULL END
@@ -5499,7 +5499,7 @@ CREATE OR REPLACE FUNCTION ST_NumPatches(geometry)
RETURNS geometry
AS '
ELSE NULL END
Summary of changes:
NEWS | 4 +-
liblwgeom/liblwgeom.h.in | 5 +
liblwgeom/lwgeom.c | 18 +++-
postgis/lwgeom_ogc.c | 177 +++++++++++++++++++++++++++-----
postgis/postgis.sql.in | 17 +--
regress/core/polyhedralsurface.sql | 11 ++
regress/core/polyhedralsurface_expected | 7 ++
7 files changed, 201 insertions(+), 38 deletions(-)
hooks/post-receive
