[SCM] PostGIS branch master updated. 3.5.0-452-g1690dc211
git at osgeo.org
git at osgeo.org
Fri Jul 11 14:28:03 PDT 2025
the project "PostGIS".
via 1690dc211ad7f287cbb6a8d679040a86e9043aad (commit)
from 60b0e880d24ffcdf2d17ab22bc8109549f69fd16 (commit)
revisions in full, below.
commit 1690dc211ad7f287cbb6a8d679040a86e9043aad
Author: Paul Ramsey <paul.ramsey at snowflake.com>
Date: Fri Jul 11 14:27:46 2025 -0700
ST_PointFromText cannot create geometries with M (References #5902)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 38d009eac..50c9ba732 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5594,7 +5594,7 @@ CREATE OR REPLACE FUNCTION ST_WKTToSQL(text)
CREATE OR REPLACE FUNCTION ST_PointFromText(text)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1)) = ''POINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1)) = ''ST_Point''
THEN @extschema at .ST_GeomFromText($1)
ELSE NULL END
@@ -5606,7 +5606,7 @@ CREATE OR REPLACE FUNCTION ST_PointFromText(text)
CREATE OR REPLACE FUNCTION ST_PointFromText(text, integer)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''POINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1, $2)) = ''ST_Point''
THEN @extschema at .ST_GeomFromText($1, $2)
ELSE NULL END
@@ -5617,7 +5617,7 @@ CREATE OR REPLACE FUNCTION ST_PointFromText(text, integer)
CREATE OR REPLACE FUNCTION ST_LineFromText(text)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1)) = ''LINESTRING''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1)) = ''ST_LineString''
ELSE NULL END
@@ -5628,7 +5628,7 @@ CREATE OR REPLACE FUNCTION ST_LineFromText(text)
CREATE OR REPLACE FUNCTION ST_LineFromText(text, integer)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''LINESTRING''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1, $2)) = ''ST_LineString''
THEN @extschema at .ST_GeomFromText($1,$2)
ELSE NULL END
@@ -5639,7 +5639,7 @@ CREATE OR REPLACE FUNCTION ST_LineFromText(text, integer)
CREATE OR REPLACE FUNCTION ST_PolyFromText(text)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1)) = ''POLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1)) = ''ST_Polygon''
ELSE NULL END
@@ -5650,7 +5650,7 @@ CREATE OR REPLACE FUNCTION ST_PolyFromText(text)
CREATE OR REPLACE FUNCTION ST_PolyFromText(text, integer)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''POLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1, $2)) = ''ST_Polygon''
ELSE NULL END
@@ -5676,7 +5676,7 @@ CREATE OR REPLACE FUNCTION ST_MLineFromText(text, integer)
RETURNS geometry
AS '
SELECT CASE
- WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''MULTILINESTRING''
+ WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1, $2)) = ''ST_MultiLineString''
ELSE NULL END
@@ -5687,7 +5687,7 @@ CREATE OR REPLACE FUNCTION ST_MLineFromText(text, integer)
CREATE OR REPLACE FUNCTION ST_MLineFromText(text)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1)) = ''MULTILINESTRING''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1)) = ''ST_MultiLineString''
ELSE NULL END
@@ -5712,7 +5712,7 @@ CREATE OR REPLACE FUNCTION ST_MultiLineStringFromText(text, integer)
CREATE OR REPLACE FUNCTION ST_MPointFromText(text, integer)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''MULTIPOINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1, $2)) = ''ST_MultiPoint''
THEN ST_GeomFromText($1, $2)
ELSE NULL END
@@ -5723,7 +5723,7 @@ CREATE OR REPLACE FUNCTION ST_MPointFromText(text, integer)
CREATE OR REPLACE FUNCTION ST_MPointFromText(text)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1)) = ''MULTIPOINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1)) = ''ST_MultiPoint''
ELSE NULL END
@@ -5741,7 +5741,7 @@ CREATE OR REPLACE FUNCTION ST_MultiPointFromText(text)
CREATE OR REPLACE FUNCTION ST_MPolyFromText(text, integer)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''MULTIPOLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1, $2)) = ''ST_MultiPolygon''
ELSE NULL END
@@ -5752,7 +5752,7 @@ CREATE OR REPLACE FUNCTION ST_MPolyFromText(text, integer)
CREATE OR REPLACE FUNCTION ST_MPolyFromText(text)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1)) = ''MULTIPOLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1)) = ''ST_MultiPolygon''
ELSE NULL END
@@ -5778,7 +5778,7 @@ CREATE OR REPLACE FUNCTION ST_GeomCollFromText(text, integer)
RETURNS geometry
AS '
SELECT CASE
- WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''GEOMETRYCOLLECTION''
+ WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1, $2)) = ''ST_GeometryCollection''
ELSE NULL END
@@ -5790,7 +5790,7 @@ CREATE OR REPLACE FUNCTION ST_GeomCollFromText(text)
RETURNS geometry
AS '
SELECT CASE
- WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1)) = ''GEOMETRYCOLLECTION''
+ WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1)) = ''ST_GeometryCollection''
ELSE NULL END
@@ -5815,7 +5815,7 @@ CREATE OR REPLACE FUNCTION ST_GeomFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_PointFromWKB(bytea, int)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1, $2)) = ''POINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1, $2)) = ''ST_Point''
THEN @extschema at .ST_GeomFromWKB($1, $2)
ELSE NULL END
@@ -5826,7 +5826,7 @@ CREATE OR REPLACE FUNCTION ST_PointFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_PointFromWKB(bytea)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1)) = ''POINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1)) = ''ST_Point''
THEN @extschema at .ST_GeomFromWKB($1)
ELSE NULL END
@@ -5837,7 +5837,7 @@ CREATE OR REPLACE FUNCTION ST_PointFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_LineFromWKB(bytea, int)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1, $2)) = ''LINESTRING''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1, $2)) = ''ST_LineString''
ELSE NULL END
@@ -5848,7 +5848,7 @@ CREATE OR REPLACE FUNCTION ST_LineFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_LineFromWKB(bytea)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1)) = ''LINESTRING''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1)) = ''ST_LineString''
ELSE NULL END
@@ -5859,7 +5859,7 @@ CREATE OR REPLACE FUNCTION ST_LineFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_LinestringFromWKB(bytea, int)
RETURNS geometry
AS '
ELSE NULL END
@@ -5870,7 +5870,7 @@ CREATE OR REPLACE FUNCTION ST_LinestringFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_LinestringFromWKB(bytea)
RETURNS geometry
AS '
ELSE NULL END
@@ -5881,7 +5881,7 @@ CREATE OR REPLACE FUNCTION ST_LinestringFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_PolyFromWKB(bytea, int)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1, $2)) = ''POLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1, $2)) = ''ST_Polygon''
ELSE NULL END
@@ -5892,7 +5892,7 @@ CREATE OR REPLACE FUNCTION ST_PolyFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_PolyFromWKB(bytea)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1)) = ''POLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1)) = ''ST_Polygon''
ELSE NULL END
@@ -5903,7 +5903,7 @@ CREATE OR REPLACE FUNCTION ST_PolyFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_PolygonFromWKB(bytea, int)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1,$2)) = ''POLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1,$2)) = ''ST_Polygon''
ELSE NULL END
@@ -5914,7 +5914,7 @@ CREATE OR REPLACE FUNCTION ST_PolygonFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_PolygonFromWKB(bytea)
RETURNS geometry
AS '
ELSE NULL END
@@ -5925,7 +5925,7 @@ CREATE OR REPLACE FUNCTION ST_PolygonFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_MPointFromWKB(bytea, int)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1, $2)) = ''MULTIPOINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1, $2)) = ''ST_MultiPoint''
ELSE NULL END
@@ -5936,7 +5936,7 @@ CREATE OR REPLACE FUNCTION ST_MPointFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_MPointFromWKB(bytea)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1)) = ''MULTIPOINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1)) = ''ST_MultiPoint''
ELSE NULL END
@@ -5947,7 +5947,7 @@ CREATE OR REPLACE FUNCTION ST_MPointFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_MultiPointFromWKB(bytea, int)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1,$2)) = ''MULTIPOINT''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1,$2)) = ''ST_MultiPoint''
ELSE NULL END
@@ -5958,7 +5958,7 @@ CREATE OR REPLACE FUNCTION ST_MultiPointFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_MultiPointFromWKB(bytea)
RETURNS geometry
AS '
ELSE NULL END
@@ -5969,7 +5969,7 @@ CREATE OR REPLACE FUNCTION ST_MultiPointFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_MultiLineFromWKB(bytea)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1)) = ''MULTILINESTRING''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1)) = ''ST_MultiLineString''
ELSE NULL END
@@ -5980,7 +5980,7 @@ CREATE OR REPLACE FUNCTION ST_MultiLineFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_MLineFromWKB(bytea, int)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1, $2)) = ''MULTILINESTRING''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1, $2)) = ''ST_MultiLineString''
ELSE NULL END
@@ -5991,7 +5991,7 @@ CREATE OR REPLACE FUNCTION ST_MLineFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_MLineFromWKB(bytea)
RETURNS geometry
AS '
ELSE NULL END
@@ -6003,7 +6003,7 @@ CREATE OR REPLACE FUNCTION ST_MLineFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_MPolyFromWKB(bytea, int)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1, $2)) = ''MULTIPOLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1, $2)) = ''ST_MultiPolygon''
ELSE NULL END
@@ -6014,7 +6014,7 @@ CREATE OR REPLACE FUNCTION ST_MPolyFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_MPolyFromWKB(bytea)
RETURNS geometry
AS '
- SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1)) = ''MULTIPOLYGON''
+ SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1)) = ''ST_MultiPolygon''
ELSE NULL END
@@ -6024,7 +6024,7 @@ CREATE OR REPLACE FUNCTION ST_MPolyFromWKB(bytea)
CREATE OR REPLACE FUNCTION ST_MultiPolyFromWKB(bytea, int)
RETURNS geometry
AS '
ELSE NULL END
@@ -6035,7 +6035,7 @@ CREATE OR REPLACE FUNCTION ST_MultiPolyFromWKB(bytea, int)
CREATE OR REPLACE FUNCTION ST_MultiPolyFromWKB(bytea)
RETURNS geometry
AS '
ELSE NULL END
@@ -6047,7 +6047,7 @@ CREATE OR REPLACE FUNCTION ST_GeomCollFromWKB(bytea, int)
RETURNS geometry
AS '
SELECT CASE
- WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1, $2)) = ''GEOMETRYCOLLECTION''
+ WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1, $2)) = ''ST_GeometryCollection''
ELSE NULL END
@@ -6059,7 +6059,7 @@ CREATE OR REPLACE FUNCTION ST_GeomCollFromWKB(bytea)
RETURNS geometry
AS '
SELECT CASE
- WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromWKB($1)) = ''GEOMETRYCOLLECTION''
+ WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromWKB($1)) = ''ST_GeometryCollection''
ELSE NULL END
@@ -6156,7 +6156,7 @@ BEGIN
geom := @extschema at .ST_BuildArea(mline);
- IF @extschema at .GeometryType(geom) != 'POLYGON'
+ IF @extschema at .ST_GeometryType(geom) != 'ST_Polygon'
THEN
RAISE EXCEPTION 'Input returns more then a single polygon, try using BdMPolyFromText instead';
END IF;
Summary of changes:
postgis/postgis.sql.in | 76 +++++++++++++++++++++++++-------------------------
1 file changed, 38 insertions(+), 38 deletions(-)
hooks/post-receive
