[PostGIS] #5942: mingw64 issue get working with new mingw64 chain
PostGIS trac at osgeo.org
Sun Jul 13 15:52:35 PDT 2025
 Reporter:  robe    |      Owner:  strk
     Type:  defect  |     Status:  new
 Priority:  medium  |  Milestone:  PostGIS 3.6.0
Component:  build   |    Version:  master
 Keywords:          |
 I haven't swapped in my gcc13 mingw64 cause it's failing on typmod test
 with error
 can't write to:
 /projects/postgis/tmp/3.6.0dev_pg18_geos3.14_gdal3.9.2w64/pgis_reg_tmp//test_1_tmp
 If I hardcode the path in the typmod.sql test to:
 SELECT * FROM
 tm.insert_all('C:/ming64/projects/postgis/tmp/3.6.0dev_pg18_geos3.14_gdal3.9.2w64/pgis_reg_tmp/test_1_tmp');
 It works.  So I guess the new one can only read the windows path and not
 the msys path.
 I feel like I've had this kind of issue before and not sure how I fixed
 last time.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5942>
