[SCM] PostGIS branch master updated. 3.5.0-456-g65fb3f7dd
git at osgeo.org
git at osgeo.org
Mon Jul 14 12:48:33 PDT 2025
the project "PostGIS".
via 65fb3f7dd3a192d04836f29742b7fcf7dc054324 (commit)
from ad9bca5e498ec098d0838c173119e21bf09859ef (commit)
revisions in full, below.
commit 65fb3f7dd3a192d04836f29742b7fcf7dc054324
Author: Weblate <noreply at weblate.org>
Date: Mon Jul 14 19:44:43 2025 +0000
Update translation files
Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/da/postgis-manual.po b/doc/po/da/postgis-manual.po
index 76b45c859..2d7c26793 100644
--- a/doc/po/da/postgis-manual.po
+++ b/doc/po/da/postgis-manual.po
@@ -7965,6 +7965,11 @@ msgstr ""
msgid "Artur Zakirov"
msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Ayo Adesugba"
+msgstr ""
#. Tag: member
#, no-c-format
msgid "Barbara Phillipot"
@@ -8767,6 +8772,11 @@ msgstr ""
msgid "Université Laval"
msgstr ""
+#. Tag: link
+#, no-c-format
+msgid "U.S. Census Bureau"
+msgstr ""
#. Tag: link
#, no-c-format
msgid "U.S. Department of State (HIU)"
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 8f99cc1e9..72cacbbfe 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10688,6 +10688,11 @@ msgstr "Arthur Lesuisse"
msgstr "Artur Zakirov"
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, fuzzy, no-c-format
@@ -11492,6 +11497,11 @@ msgstr "UC Davis Zentrum für durch Vektoren übertragene Krankheiten"
msgstr "Universität Laval"
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index d61a81f47..5137c8af8 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -9065,6 +9065,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -9869,6 +9874,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index cb6a5194c..72dc7c1a5 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -10641,6 +10641,11 @@ msgstr "Arthur Lesuisse"
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -11446,6 +11451,11 @@ msgstr "UC Davis Center for Vectorborne Diseases"
msgstr "Université Laval"
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index c310cefb2..82bfcd905 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -9227,6 +9227,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -10032,6 +10037,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 0c8a18e81..e67e4d040 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -12,8 +12,8 @@ msgstr ""
"POT-Creation-Date: 2025-05-18 00:48+0000\n"
"PO-Revision-Date: 2025-07-14 10:47+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
-"postgis-manual/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
+"manual/ja/>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
@@ -10184,6 +10184,11 @@ msgstr "Arthur Lesuisse"
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -10988,6 +10993,11 @@ msgstr "カリフォルニア大デービス校節足動媒介感染症センタ
msgstr "ラヴァル大学"
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
@@ -16197,16 +16207,17 @@ msgid ""
", <xref linkend=\"ST_CoverageSimplify\"/>, <xref "
"linkend=\"ST_CoverageClean\"/>, <xref linkend=\"ST_Union\"/>"
msgstr ""
-", <xref linkend=\"ST_CoverageSimplify\"/>, <xref linkend=\"ST_CoverageClean\""
-"/>, <xref linkend=\"ST_Union\"/>"
+", <xref linkend=\"ST_CoverageSimplify\"/>, <xref "
+"linkend=\"ST_CoverageClean\"/>, <xref linkend=\"ST_Union\"/>"
#. Tag: refpurpose
#, no-c-format
msgid ""
"Computes a clean (edge matched, non-overlapping, gap-cleared) polygonal "
"coverage, given a non-clean input."
-msgstr "きれいな (エッジが合致し、オーバーラップがなく、隙間がない) "
-"ポリゴンカバレッジを、きれいでない入力から計算します。"
+msgstr ""
+"きれいな (エッジが合致し、オーバーラップがなく、隙間がない) ポリゴンカバレッ"
+"ジを、きれいでない入力から計算します。"
#. Tag: para
#, no-c-format
@@ -16219,8 +16230,8 @@ msgid ""
msgstr ""
"ポリゴンカバレッジのエッジを変更して、ポリゴンのオーバーラップを無くし、隙間"
"をスナップして除き、全ての共有エッジが同じものにすることを確実にするウィンド"
-"ウ関数です。結果は <xref linkend=\"ST_CoverageInvalidEdges\""
-"/>のような評価関数にパスするクリーンなカバレッジです"
+"ウ関数です。結果は <xref linkend=\"ST_CoverageInvalidEdges\"/>のような評価関"
+"数にパスするクリーンなカバレッジです"
#. Tag: para
#, no-c-format
@@ -16240,8 +16251,8 @@ msgid ""
"to turn off all snapping."
msgstr ""
"<parameter>snappingDistance</parameter>は近隣ノードを一つにまとめるスナップの"
-"制御のためのものです。デフォルト設定 (-1) "
-"では、入力制御に基づき算出されたスナップ距離が自動的に適用されます。"
+"制御のためのものです。デフォルト設定 (-1) では、入力制御に基づき算出されたス"
+"ナップ距離が自動的に適用されます。"
#. Tag: para
#, no-c-format
@@ -16256,7 +16267,8 @@ msgstr ""
#, no-c-format
msgid ""
"<code>MERGE_LONGEST_BORDER</code> chooses polygon with longest common border"
-msgstr "<code>MERGE_LONGEST_BORDER</code> 共通境界線が最も長いポリゴンを選択します"
+msgstr ""
+"<code>MERGE_LONGEST_BORDER</code> 共通境界線が最も長いポリゴンを選択します"
#. Tag: para
#, no-c-format
@@ -16271,7 +16283,8 @@ msgstr "<code>MERGE_MIN_AREA</code> 最小面積のポリゴンを選択しま
#. Tag: para
#, no-c-format
msgid "<code>MERGE_MIN_INDEX</code> chooses polygon with smallest input index"
-msgstr "<code>MERGE_MIN_INDEX</code> 入力の要素番号が最も小さいポリゴンを選択します"
+msgstr ""
+"<code>MERGE_MIN_INDEX</code> 入力の要素番号が最も小さいポリゴンを選択します"
#. Tag: para
#, no-c-format
@@ -26516,8 +26529,8 @@ msgid ""
msgstr ""
"不正な入力を操作することができ、出力は常に妥当なポリゴンジオメトリです。距離 "
"0によるバッファ生成は時々不正なポリゴンの修復方法として使われます。. <xref "
-"linkend=\"ST_MakeValid\""
-"/>の方がマルチポリゴンも扱えるので、この目的に使うのにより適切です。"
+"linkend=\"ST_MakeValid\"/>の方がマルチポリゴンも扱えるので、この目的に使うの"
+"により適切です。"
#. Tag: para
#, no-c-format
@@ -28759,8 +28772,9 @@ msgstr "ラスタ リファレンス"
msgid ""
"<varname>raster</varname> is a PostGIS type for storing and analyzing raster "
"data."
-msgstr "<varname>raster</varname>は、ラスタデータを格納、解析するためのPostGIS型です"
+msgstr ""
+"<varname>raster</varname>は、ラスタデータを格納、解析するためのPostGIS型で"
+"す。"
#. Tag: para
#, no-c-format
@@ -28776,7 +28790,8 @@ msgstr ""
msgid ""
"Some examples in this reference use a raster table of dummy data, created "
"with the following code:"
-msgstr "このリファレンスで使うダミーデータのラスタテーブルの作り方は次の通りです:"
+msgstr ""
+"このリファレンスで使うダミーデータのラスタテーブルの作り方は次の通りです:"
#. Tag: para
#, no-c-format
@@ -28784,7 +28799,8 @@ msgid ""
"The functions below are ones which a user of PostGIS Raster is likely to "
"need. There are other raster support functions which are not of interest to "
"a general user."
-msgstr "下に示す関数はPostGISラスタのユーザにとって必要そうなものです。他にも一般的な"
+msgstr ""
+"下に示す関数はPostGISラスタのユーザにとって必要そうなものです。他にも一般的な"
"ユーザにとって興味のないラスタ対応関数があります。"
#. Tag: title
@@ -28938,15 +28954,17 @@ msgstr ""
msgid ""
"A composite type used as input into the ST_Reclass function defining the "
"behavior of reclassification."
-msgstr "ST_Reclass関数への入力として使われる再分類のふるまいを定義する複合型です。"
+msgstr ""
+"ST_Reclass関数への入力として使われる再分類のふるまいを定義する複合型です。"
#. Tag: para
#, no-c-format
msgid ""
"A composite type used as input into the <xref linkend=\"RT_ST_Reclass\"/> "
"function defining the behavior of reclassification."
-msgstr "<xref linkend=\"RT_ST_Reclass\""
-"/>関数への入力として使われる再分類のふるまいを定義する複合型です。"
+msgstr ""
+"<xref linkend=\"RT_ST_Reclass\"/>関数への入力として使われる再分類のふるまいを"
+"定義する複合型です。"
#. Tag: para
#, no-c-format
@@ -33268,9 +33286,9 @@ msgid ""
"max for a given raster band of a set of raster. Band 1 is assumed if no band "
"is specified."
msgstr ""
-"集約関数。与えられたラスターのバンドの集合のcount, sum, mean, stddev, min, ma"
-"xからなる統計情報のサマリーです。バンドを指定しない場合には、1番と仮定します"
+"集約関数。与えられたラスターのバンドの集合のcount, sum, mean, stddev, min, "
+"maxからなる統計情報のサマリーです。バンドを指定しない場合には、1番と仮定しま"
+"す。"
#. Tag: para
#, no-c-format
@@ -35659,8 +35677,8 @@ msgid ""
"band 1 is assumed."
msgstr ""
"<varname>reclassexpr</varname>によって定義される入力ラスター (<varname>rast</"
-"varname>)の再分類処理を適用して新しいラスターを生成します。<varname>band</var"
-"name>を指定しない場合には、1番を仮定します。"
+"varname>)の再分類処理を適用して新しいラスターを生成します。<varname>band</"
+"varname>を指定しない場合には、1番を仮定します。"
#. Tag: para
#, no-c-format
diff --git a/doc/po/ka/postgis-manual.po b/doc/po/ka/postgis-manual.po
index 433300ce9..b78fd2da8 100644
--- a/doc/po/ka/postgis-manual.po
+++ b/doc/po/ka/postgis-manual.po
@@ -7948,6 +7948,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -8750,6 +8755,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index 84b4dcd1c..2746f3755 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
@@ -9386,6 +9386,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -10190,6 +10195,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index 6ffd6c6d6..5bfc6de43 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
@@ -7987,6 +7987,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -8791,6 +8796,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index ebe4cce6e..ba2e2118e 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
@@ -9510,6 +9510,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -10314,6 +10319,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index 51b4f2b7d..350b1114c 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
@@ -7983,6 +7983,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -8785,6 +8790,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index 37817e14a..9772e1206 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
@@ -7985,6 +7985,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -8787,6 +8792,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index 5c9679292..c7a1ddf1b 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -7,8 +7,8 @@ msgstr ""
"PO-Revision-Date: 2025-07-09 20:47+0000\n"
"Last-Translator: Daniel Nylander <daniel at danielnylander.se>\n"
-"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/"
-"postgis-manual/sv/>\n"
+"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/postgis-"
+"manual/sv/>\n"
"Language: sv\n"
@@ -1797,7 +1797,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "(token number <code>0</code>): Unparsed building identifiers and types."
-msgstr "(tokennummer <code>0</code>): Oparsade byggnadsidentifierare och typer."
+msgstr ""
+"(tokennummer <code>0</code>): Oparsade byggnadsidentifierare och typer."
#. Tag: para
#, no-c-format
@@ -10399,6 +10400,11 @@ msgstr "Arthur Lesuisse"
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -11203,6 +11209,11 @@ msgstr "UC Davis Center för vektorburna sjukdomar"
msgstr "Universitet Laval"
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
@@ -16565,8 +16576,8 @@ msgid ""
msgstr ""
#. Tag: refpurpose
#, no-c-format
@@ -16589,8 +16600,8 @@ msgstr ""
"En fönsterfunktion som ändrar kanterna på en polygonal täckning för att "
"säkerställa att ingen av polygonerna överlappar varandra, att små luckor är "
"bortklippta och att alla delade kanter är exakt identiska. Resultatet är en "
-"ren täckning som kommer att klara valideringstester som <xref linkend="
-"\"ST_CoverageInvalidEdges\"/>"
+"ren täckning som kommer att klara valideringstester som <xref "
+"linkend=\"ST_CoverageInvalidEdges\"/>"
#. Tag: para
#, no-c-format
@@ -24496,9 +24507,9 @@ msgstr ""
"Returnerar EWKB-representationen ( <link linkend=\"EWKB_EWKT\">Extended Well-"
"Known Binary</link> ) av geometrin med SRID-metadata. Den första "
"funktionsvarianten använder som standard kodning med servermaskinens endian. "
-"Den andra funktionsvarianten tar ett textargument som anger endian-kodningen:"
-" antingen 'NDR' för little-endian eller 'XDR' för big-endian. Om du anger "
-"okända argument kommer utdata att resultera i little-endian."
+"Den andra funktionsvarianten tar ett textargument som anger endian-"
+"kodningen: antingen 'NDR' för little-endian eller 'XDR' för big-endian. Om "
+"du anger okända argument kommer utdata att resultera i little-endian."
#. Tag: para
#, no-c-format
@@ -29703,8 +29714,8 @@ msgid ""
msgstr ""
-"En sammansatt typ som används som indata till funktionen <xref linkend="
-"\"RT_ST_Reclass\"/> som definierar beteendet vid omklassificering."
+"En sammansatt typ som används som indata till funktionen <xref "
+"linkend=\"RT_ST_Reclass\"/> som definierar beteendet vid omklassificering."
#. Tag: para
#, no-c-format
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 367e83b11..2048f014b 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
@@ -7950,6 +7950,11 @@ msgstr ""
msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -8752,6 +8757,11 @@ msgstr ""
msgstr ""
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 4efa64884..77bbfcd88 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -9482,6 +9482,11 @@ msgstr "Arthur Lesuisse"
+#. Tag: member
+#, no-c-format
+msgstr ""
#. Tag: member
#, no-c-format
@@ -10285,6 +10290,11 @@ msgstr "UC Davis Center for Vectorborne Diseases"
+#. Tag: link
+#, no-c-format
+msgstr ""
#. Tag: link
#, no-c-format
Summary of changes:
doc/po/da/postgis-manual.po | 10 ++++++
doc/po/de/postgis-manual.po | 10 ++++++
doc/po/es/postgis-manual.po | 10 ++++++
doc/po/fr/postgis-manual.po | 10 ++++++
doc/po/it_IT/postgis-manual.po | 10 ++++++
doc/po/ja/postgis-manual.po | 70 +++++++++++++++++++++++++---------------
doc/po/ka/postgis-manual.po | 10 ++++++
doc/po/ko_KR/postgis-manual.po | 10 ++++++
doc/po/pl/postgis-manual.po | 10 ++++++
doc/po/pt_BR/postgis-manual.po | 10 ++++++
doc/po/ro/postgis-manual.po | 10 ++++++
doc/po/ru/postgis-manual.po | 10 ++++++
doc/po/sv/postgis-manual.po | 35 +++++++++++++-------
doc/po/uk/postgis-manual.po | 10 ++++++
doc/po/zh_Hans/postgis-manual.po | 10 ++++++
15 files changed, 197 insertions(+), 38 deletions(-)
hooks/post-receive
