[PostGIS] #3110: Use 64bit integers for identifiers
trac at osgeo.org
Mon Jul 14 19:57:32 PDT 2025
Reporter: strk | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.6.0
Component: topology | Version: master
Resolution: fixed | Keywords:
Changes (by Regina Obe <lr@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"43110503fda73aa1938e4eddccd92785f82d094e/git"
43110503/git]:
{{{#!CommitTicketReference repository="git"
revision="43110503fda73aa1938e4eddccd92785f82d094e"
Topology support for big int
Closes #3110 for PostGIS 3.6.0
References https://git.osgeo.org/gitea/postgis/postgis/pulls/242
Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/242
References https://github.com/postgis/postgis/pull/822
* Update c types to support int64 instead of int32 for IDs -
face,edge,node,element,topogeo
* Modify the pre and post scripts including the restore, uninstall and
upgrade script generators
* Upgrade core elements to support bigint - topoelement, topoelementarray
and topogeometry
* Modify createtopogeom to support bigint including tests
* Modify createtopology - consolidate into single function and add large
ids support
* Modified addtopogeomcolumn - added support for bigint including tests
* Modify topology query methods that need bigint
* Modify topology sql functions that require bigint for input or output
(including tests)
* Modify validatetopology to support large ids. Also modified copytopology
and topologysummary including tests
* Add dedicated tests for large id topologies
* Add topology.upgradetopology function
* Update NEWS
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3110#comment:9>
