[SCM] PostGIS branch master updated. 3.5.0-470-g6fa083969
git at osgeo.org
git at osgeo.org
Tue Jul 15 23:53:25 PDT 2025
the project "PostGIS".
via 6fa083969d46eaa322e864ef1561e964513d67a3 (commit)
via f1071cb35eb31c2642e6c97599d8e90e93eb265e (commit)
from 3484c5071f918c44a4418883b1860e20f32c0378 (commit)
revisions in full, below.
commit 6fa083969d46eaa322e864ef1561e964513d67a3
Author: Regina Obe <lr at pcorp.us>
Date: Wed Jul 16 02:51:45 2025 -0400
Try to get berrie64 compile with SFCGAL
Use GEOS 3.11 which is same as GDAL is compiled with
To prevent GDAL-GEOS / GEOS conflict
References #5945
diff --git a/ci/berrie64/configs.sh b/ci/berrie64/configs.sh
index 8cc3a7aa8..397c4f30f 100644
--- a/ci/berrie64/configs.sh
+++ b/ci/berrie64/configs.sh
@@ -1,5 +1,5 @@
export WORKSPACE=/home/jenkins/workspace
-export GEOS_VER=3.14.0
+export GEOS_VER=3.11.6
export SFCGAL_VER=master
export OS_BUILD=64
@@ -8,10 +8,10 @@ export GEOS_PATH=${WORKSPACE}/geos/rel-${GEOS_VER}
export SFCGAL_PATH=${WORKSPACE}/sfcgal/label/${label}/rel-sfcgal-${SFCGAL_VER}
#export GEOS_PATH=~/geos/rel-${GEOS_VER}
export PGPATH=${WORKSPACE}/pg/label/${label}/rel/pg${PG_VER}w${OS_BUILD}
-export PATH=${PGPATH}/bin:${PGPATH}/lib:${GEOS_PATH}/bin:${GEOS_PATH}/lib:${SFCGAL_PATH}/bin:${SFCGAL_PATH}/lib:${PATH}
+export PATH=${PGPATH}/bin:${PGPATH}/lib:${SFCGAL_PATH}/bin:${SFCGAL_PATH}/lib:${GEOS_PATH}/bin:${GEOS_PATH}/lib:${PATH}
-export PKG_CONFIG_PATH="${GEOS_PATH}/lib/pkgconfig:${SFCGAL_PATH}/lib/pkgconfig"
+export PKG_CONFIG_PATH="${SFCGAL_PATH}/lib/pkgconfig:${GEOS_PATH}/lib/pkgconfig"
export PGPORT=55434
export PGDATA=$PGPATH/data_${PGPORT}
export PGHOST=localhost
-export LD_LIBRARY_PATH="${GEOS_PATH}/lib:${PGPATH}/lib"
+export LD_LIBRARY_PATH="${SFCGAL_PATH}/lib:${GEOS_PATH}/lib:${PGPATH}/lib"
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index 730b15382..35221bb3d 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
@@ -14,8 +14,7 @@ export CONFIG_FILE="$CUR_DIR/configs.sh"
echo $PATH
sh autogen.sh
-./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config --with-library-minor-version --enable-lto \
- --with-sfcgal=${SFCGAL_PATH}/bin/sfcgal-config \
+./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config --with-library-minor-version \
--without-interrupt-tests --prefix=${PGPATH}
#make clean
make
commit f1071cb35eb31c2642e6c97599d8e90e93eb265e
Date: Tue Jul 15 22:01:43 2025 -0400
Fix for GEOS GeometryFactory memory leak
Contributed by: Megan Ma
References #5943 for PostGIS 3.6.0
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 98c4af7b5..4c41ff144 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -310,6 +310,7 @@
<member>Maxime Guillaud</member>
<member>Maxime van Noppen</member>
<member>Maxime Schoemans</member>
+ <member>Megan Ma</member>
<member>Michael Fuhr</member>
<member>Mike Toews</member>
<member>Nathan Wagner</member>
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index ed3c314b8..102ed604d 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -723,7 +723,7 @@ lwgeom_intersection_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
g3 = GEOSIntersection(g1, g2);
- if (!g3) GEOS_FREE_AND_FAIL(g1);
+ if (!g3) GEOS_FREE_AND_FAIL(g1, g2);
GEOSSetSRID(g3, srid);
if (!(result = GEOS2LWGEOM(g3, is3d))) GEOS_FREE_AND_FAIL(g1, g2, g3);
@@ -1145,7 +1145,7 @@ lwgeom_buildarea(const LWGEOM* geom)
/* If no geometries are in result collection, return NULL */
if (GEOSGetNumGeometries(g3) == 0)
- GEOS_FREE(g1);
+ GEOS_FREE(g1, g3);
return NULL;
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index 0ad18f4ed..092795921 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -1001,7 +1001,11 @@ Datum relate_full(PG_FUNCTION_ARGS)
POSTGIS_DEBUGF(3, "%s", GEOSGeomToWKT(g2));
relate_str = GEOSRelateBoundaryNodeRule(g1, g2, bnr);
- if (!relate_str) HANDLE_GEOS_ERROR("GEOSRelate");
+ if (!relate_str) {
+ GEOSGeom_destroy(g1);
+ GEOSGeom_destroy(g2);
+ HANDLE_GEOS_ERROR("GEOSRelate");
result = cstring_to_text(relate_str);
GEOSFree(relate_str);
Summary of changes:
ci/berrie64/configs.sh | 8 ++++----
ci/berrie64/postgis_regress.sh | 3 +--
doc/introduction.xml | 1 +
liblwgeom/lwgeom_geos.c | 4 ++--
postgis/lwgeom_geos_predicates.c | 6 +++++-
5 files changed, 13 insertions(+), 9 deletions(-)
hooks/post-receive
