[PostGIS] #5946: FindTopology(toTopoGeom) crashing on berrie64 garden tests Infinite Point
trac at osgeo.org
Fri Jul 18 00:31:00 PDT 2025
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.6.0
Component: topology | Version: 3.5.x
Resolution: | Keywords:
Comment (by strk):
It looks like I could reproduce locally, from the master branch, by
running `make garden`:
PostGIS Topology garden tests in progress (it will take time)
psql -X -ad postgis_garden < \
../doc/topology_gardentest_36.sql \
> topology_garden_result.txt 2>&1 || { \
tail -n 20 topology_garden_result.txt; false; }
SELECT 'GeometryFindTopology Infinite Point: Start
Testing';
?column?
GeometryFindTopology Infinite Point: Start Testing
(1 row)
INSERT INTO topology_garden_log36(log_label, func, g1, log_start,
log_sql)
VALUES('FindTopology(topogeom)Geometry
Infinite Point ','FindTopology', 'Infinite Point', clock_timestamp(),
'SELECT
FindTopology(topology.toTopoGeom(foo1.the_geom, ''topo_test'', 1, 0.001))
As result
FROM ((SELECT
''0101000020E6100000000000000000F07F000000000000F07F''::geometry AS
the_geom ) ) As foo1 LIMIT 10;');
INSERT 0 1
BEGIN;
BEGIN
INSERT INTO topology_garden_log36_output(logid, log_output)
SELECT logid, query_to_xml(log_sql,
false,false,'') As log_output
FROM topology_garden_log36 ORDER BY
logid DESC LIMIT 1;UPDATE topology_garden_log36 SET log_end =
clock_timestamp()
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
connection to server was lost
make[1]: *** [Makefile:123: garden] Error 1
And then reducing:
strk at postgis_garden=*# SELECT
FindTopology(topology.toTopoGeom(foo1.the_geom, 'topo_test', 1, 0.001))
As result
FROM ((SELECT
'0101000020E6100000000000000000F07F000000000000F07F'::geometry AS the_geom
The connection to the server was lost. Attempting reset: Failed.
Will verify myself the fix is effective
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5946#comment:2>
